Results 1 to 20 of 32
Thread: Building A New Tire Carrier
    Guelph
    Back in May sometime i started to make a tire carrier. It got put on hold for awhile but I finally got some time and I hate going wheel'n with out a spare or have to find room to bring it.
    So this is how it looks so far.
ID:	82345Click image for larger version.
ID:	82346Click image for larger version.
ID:	82348Click image for larger version.
ID:	82349Click image for larger version.
ID:	82350Click image for larger version.
ID:	82351Click image for larger version.
ID:	82352Click image for larger version.
ID:	82359Click image for larger version.
    Guelph
ID:	82382Click image for larger version.
    Got a bit more done today finally cut off the square tube in the middle and tack in the rest of the bars.
    Now to figure out how to latch it to the body.
    Any Ideas would be great.
    Beamsville
    Time Online: 3 Mths 4 Days 15 Hrs 57 Mins 30 Secs
    interesting way to notch a tube, is that a heavy duty drill press?
    Professional lunatic
    Toxic River?
    Time Online: 4 Mths 2 Wks 1 Day 2 Hrs 1 Min 11 Secs
    i like the way it turned out! Nice, clean and simple.
    What size tire are you carrying? 35?
    What about making a set of corner guards and mounting it tho them? Or like half guards where they wrap around the corner and go about 15" forward.
    Have you thought about not only having it swing out but maybe also swing down?
    Guelph
    No Actually its one from PA . it works, but not the best. I wouldn't want to do a full cage with it. Not quite enough power.
    ^It's hard to tell but i have already put corner gaurds on. I made them out of 1/8th plate of steel, I painted them to match cause I didn't want them to stand out to much like the checker plate ones.
    I'm running 37's but i put my buddy's 35 in and it will fit too.
    I think I want to make it so i can close it, and screw a pin down threw so it won't rattle.
    Guelph
    Well got some more done today.
ID:	82459Click image for larger version.
ID:	82460Click image for larger version.
ID:	82461Click image for larger version.
ID:	82462Click image for larger version.
ID:	82463Click image for larger version.
ID:	82464Click image for larger version.
    Just wondering if anyone knows where I can get a tappered rubber piece to attach the tire?
    it has to be 4 1/2" wide atleast and down to 2" at the end.
    I wish I saw that notching idea before I bought my knotcher well before my jeep times.
    As for rubber all I can suggest is buying a 5" dia piece from mcmastercarr and machining it. That what I would do but I have the means.
    Guelph
    What and where or who is mcmastercarr LOL.
    Is there any place that sells the ones for the tire changing machines by chance that you know of.
    I was to cheap to buy a knotcher. It does have some flaws but with a bit of fabing to the vise and a better drill press it would work alot better.
    Cambridge, ON
    Time Online: 6 Mths 1 Wk 3 Days 8 Hrs 34 Mins 26 Secs
    Avg. Time Online: 15 Mins 38 Secs
    McMaster-Carr is a company that sells a whole bunch of everything. They are US based and no longer ship to Canada unless it is a business address. I had to order my stuff through the company address(and therefore the company account) to get the stuff shipped here.
    Tire carrier looking good D.
    1952 Jeep M38 project
    Apr 2011
    Etobicoke
    Time Online: 1 Mth 22 Hrs 49 Mins 48 Secs
    Avg. Time Online: 2 Mins 32 Secs
    Quote Originally Posted by DWG View Post
    Maybe rubber wheel chocks will work? These are at PA......
Name:	wheel chock.jpg
    Wave Killen' 4dr
    OF4WD Member # 6449
    Sep 2010
    petawawa....
    Time Online: 2 Mths 2 Wks 10 Hrs 39 Mins 8 Secs
    Avg. Time Online: 6 Mins 7 Secs
    you could probably build one out of wood would take a bit of time if you dont have a lathe but it could work
    The only way to get smarter is to play a smarter opponent!!
    Etobicoke
    Time Online: 5 Mths 1 Wk 2 Days 19 Hrs 18 Mins 26 Secs
    Avg. Time Online: 13 Mins 8 Secs
    Quote Originally Posted by mrduggit View Post
    Hey wake up before you start answering questions
    He's looking for a circular taper(like a cone)
    OF4WD #6222
    Dec 2008
    Just North of Sudbury
    Relaxed
    Avg. Time Online: 20 Mins 30 Secs
    Quote Originally Posted by southpw View Post
    Do you have a buddy at a tireshop? The old "antique" tire balancing machines used them....made of steel tho. Probably one they've boneyarded and the adapters are just lying around....?
    And BTW...your drillpress tube notching method does work well....I do the same thing but cut the tube long enough so that most of the hole cutter is cutting the tube....it stabilizes the bit. OR If you measure out the material right, ONE notch cut will give you 2 notched tubes.
    nice work on the carrier!
    "Bite my Shiny Metal ass!"
    Retread #19
    Jul 2012
    Time Online: 1 Wk 4 Days 11 Hrs 10 Mins 57 Secs
    Avg. Time Online: 56 Secs
    That looks sweet. Nice work.
    Guelph
    Quote Originally Posted by Dirty Money View Post
    Ya I will more then likely get a steel one made up or a flat peice with a hole in center and a few studs welded to it. A rubber one would be nice though.
    Ya my problem is my drillpress dosn't have enough power it will just stall out if I put to much pressure on it.
    And Thanks for the good feed back guys
    Guelph
    Getting closer to getting it done.
    Fabbed up some more brackets to lock it into place.
ID:	82755Click image for larger version.
ID:	82756Click image for larger version.
ID:	82757Click image for larger version.
ID:	82754Click image for larger version.
    Time Online: 1 Mth 3 Wks 4 Days 4 Hrs 51 Mins 45 Secs
    Avg. Time Online: 4 Mins 32 Secs
    Some nice work there and good ideas!
    94 YJ 5" lift with D44 35 x 12.5 on Steelies 4.0L 5 speed
    86 MJ 3" lift on 31" BFG's 4.0 HO 4x4 conversion - 96 Cherokee update
    More on the way
    OF4WD #6421
    Guelph
    ]^Thanks
    Got some more done tonight again, hopfully I will be able to prime and paint buy sunday.
    made up the centering piece for the tire, and the other locking bracket on the bottom just needs some grinding and weld and should be good to go.
ID:	82791Click image for larger version.
ID:	82799Click image for larger version.
ID:	82798Click image for larger version.
ID:	82797Click image for larger version.
ID:	82796Click image for larger version.
ID:	82795Click image for larger version.
ID:	82794Click image for larger version.
ID:	82793Click image for larger version.
ID:	82792Click image for larger version.
    Jul 2012
    Backwoods New Brunswick
    Bored
    Time Online: 4 Hrs 29 Secs
    I was going to make the suggestion of using the hub of an old front wheel bearing I assume the YJ take the same type front bearing as a TJ you could separate the assembly and weld a tube thru the center well that what I was thinking about using anyways but mine is still in the hmmmmm mental design process ok so I am a procrastinator
    Member NBJC......Behind the garage door, lies the addiction for which there is no cure..........
    Guelph
    ^ Thats a good idea but too late, lol and I am running a Scout D44 rear so i have to be able to match D30 front, and the rear bolt pattern.
    I picked up spacer awhile ago that will let me only use 1 spare. I adapted a piece to work with it, so i can mount both, either front or back on the carrier.
    finished up the rest today and started paint.
    After i was at a buddy's place getting dirty. then had to wash
    up for paint.
ID:	82823Click image for larger version.
ID:	82824Click image for larger version.
ID:	82825Click image for larger version.
ID:	82826Click image for larger version.
ID:	82827Click image for larger version.
ID:	82828Click image for larger version.
ID:	82829Click image for larger version.
ID:	82830Click image for larger version.
