Thread: dodge ram 3500 van - lost power steering
    Scarborough
    Time Online: 3 Mths 2 Wks 3 Days 8 Hrs 29 Mins 57 Secs
    Avg. Time Online: 8 Mins 49 Secs
    Hey there,
    I haven't looked at it yet in daylight, but my 99 dodge ram cargo can lost the power steering, there's very milky fluid in the reservoir, there is no pump straining sound when i drive and there's no leak currently - however there was a leak with fresh fluid when it happen i was told (a buddy had it) any ideas?
    thanks!
    m.
    OF4WD # 6856
    97 TJ - 101" wb, Clayton triangulated long arm, Bilstein's, Dana 44/hp30 locked w/ chromo's, 4.88's, 4:1 TC, PSC/Currie, 37" Toyo's, rollcage...
    2010 ES 350
    2004 GMC Astro AWD cargo van - 2" lift with 31's
    Time Online: 10 Mths 3 Wks 5 Days 6 Hrs 21 Mins 33 Secs
    Assuming the PS pulley and associated belt is intact, it isn't low on fluid and it didn't blow the high pressure hydraulic hose, then more than likely, the pump shaft broke. They have been known to snap in half and show no physical signs of failure other than a loss of power steering assist.
    Scarborough
    So i've replaced the power teering pump and it's still pretty hard to turn...could something have let go in the steering box?
    When you say "pretty hard to turn", is it acting like you have no power assist...like when the engine isn't running and you try to turn the wheel? Or do you have some power assist but it is weak?
    You could check if you have return flow from the box to the pump for starters. Does it have hydro boost as well?
    Scarborough
    so it seemed to work itself out - i think there must have been air in the pump/system then...I had a shop do it was i was busy...i think i should find another shop...lol
