Results 1 to 17 of 17
Thread: Looking for advice
    May 2008
    Grimsby
    Amazed
    Time Online: 2 Mths 2 Wks 2 Days 22 Hrs 56 Mins 10 Secs
    Avg. Time Online: 6 Mins 20 Secs
    Looking for advice
    I pick up a 86 cj7. It has the 4.2 engine, T5 tranny, d300 transer case. AMC 20 rear axle with some sort of auto locker in the rear and dana 30 front axle. I want to buld it up as a trail rig with limited street use. I really don't know where to start.
    The current set up from what I can tell is
    1 inch body lift using hockey pucks
    stock springs ( need to be replaced or repaired)
    33x12.5x15 tires ( need to be replaced)
    stock drive shafts
    some nasty looking rancho shocks. ( need to be replaced)
    I really don't know if the shackles are stock or not.
    Disco swaybar links in the front.
    456 gears.
    It runs great and drives ok(some bushings need to be replaced). When I bought it, I drove it from Mississauga to Grimsby with no issues.
    http://www.jeepkings.ca/forums/showt...-1986-Jeep-CJ7
    I would like to run 35's and maybe 37's one day and the build will happen over time as I'm not made of money.
    I have ordered some gaskets and seals to deal with a couple of fluid leaks but that is it.
    I plan on replacing the stock tierod and drag link with something a little heavier duty.
    How would you proceed?
    2009 Sahara Unlimited
    2.5 Rough Counrty springs and shocks + 1" spacers
    Jks front and rear adjustable track bars
    Rugged Ridge light bar
    Daystar upper dash panel
    35x12.5x15 trxus MT - Black Rock Rims
    selkirk ont
    Time Online: 1 Yr 3 Mths 2 Wks 4 Days 7 Hrs 24 Mins 22 Secs
    Avg. Time Online: 39 Mins 2 Secs
    get some good tires, a winch then start wheeling it.
    WHAT WOULD MACGYVER DO?
    May 2008
    Grimsby
    Amazed
    I was planning on that! but the springs need to be replaced or repaired and if I'm going to do that should I buy lift springs?
    SOA stock YJ springs and build an antiwrap system. then do what tony said.
    JMO
    Hillsburgh
    Time Online: 5 Mths 3 Days 13 Hrs 31 Mins 41 Secs
    Avg. Time Online: 12 Mins 39 Secs
    4" lift yj springs SUA
    Proper 1" body lift
    Monroe f250 gas magnum rear shocks, 13" travel
    Ford f250 front shock towers
    sway bar disconnects
    lengthen the brake flex lines
    TJ fender flares
    lockrite lockers front and rear
    alloy shafts
    bumpers and armour
    a good winch!
    properly setup CB
    Damn I miss that jeep....
    Cigar chomper!
    Youth, health and skill are no match for age, experience and treachery
    Dana 60's do break when hitting stumps at 60kmh....
    Time Online: 10 Mths 3 Wks 5 Days 36 Mins 55 Secs
    Quote Originally Posted by GrimsbyAl View Post
    If the springs are hashed - junk them. Do not spend a dime trying to breathe new life into them. Spring steel has a finite fatigue life...any attempt to ressurect them is a band aid at best.
    I'm not sure how much work you are looking at putting into this thing but if your plan is to run some 35's, I'd grab a 3-4" spring lift kit - a simple and quick way to solve your spring issues and will help greatly with fitting 35's. Or, if you are into doing more fab work, do as Jack said and do the YJ spring over lift. This will get you around 5.5" lift but requires significantly more work and some fab to make work well. It is usually around the same money to do either lift but the spring over will offer a fair bit more compression and rebound travel. But it is not a simple and quick bolt on and requires notably more effort to make perform well.
    I'd say it really depends on what your intentions are for the build in its current state.
    May 2008
    Grimsby
    Amazed
    I don't mind spending some money but not all at once. I was thinking of these http://www.genright.com/ZoomImage.as...ductID=TFF1710.
    If I went with 4.5in lift I would need to address the drive shafts correct?
    Usually on a CJ7 with a manual tranny, the belly doesn't have to be dropped but the rear shaft joint angles can be at least somewhat questionable but certainly doable as is...there is no slip yoke rear output or CV to deal with that can casue issues with a lift on a CJ unlike other heeps. Typically, the stock length driveshafts will work as is.
    But on that note, the significantly increased rear rebound travel of a spring over could cause some slip travel and joint issues if left unchecked. Something to look out for, anyway. The 1.25" OD front CJ shaft is just about useless for serious offroad use - it is too damn small and long. It isn't that hard to fawk up one of those. Your best bet is to find a way to fit a 2" OD shaft in the front at some point if you are trying to build a seriously and reliable wheeler.
    Mar 2003
    Hamilton, ON, CA
    Time Online: 1 Wk 4 Days 8 Hrs 1 Min 9 Secs
    Avg. Time Online: 56 Secs
    Burn it and run for the hills Al.......run for the hills......
    May 2008
    Grimsby
    Amazed
    done
    Attached Thumbnails Attached Thumbnails 1DSC01522.jpg   silhouette_of_a_man_running_on_a_hill_1574r-26368.jpg
    May 2008
    Grimsby
    Amazed
    Did a little wiring this morning, it really cleans up the engine bay.
    Attached Thumbnails Attached Thumbnails 100_3191.jpg   100_3192.jpg   100_3194.jpg   100_3195.jpg   100_3151.jpg
    May 2008
    Grimsby
    Amazed
    I'm almost done the twin stick for the D300, just need to weld on the handles.
    Looks like a nice build up Al. More pics! We done reed gud.
    Sent from my iPhone using My thumbs
    May 2008
    Grimsby
    Amazed
    I'll try to remember to take more pics. Here is the pics that were posted when it was for sale.
    May 2008
    Grimsby
    Amazed
    Things I've done to date
    new rear pinion seal
    new rear main seal
    new 4 inch lift
    new shocks (this weekend)
    twin sticked d300 - stll need to weld on shifters
    Attached Thumbnails Attached Thumbnails DSC00024.JPG   DSC00023.JPG   DSC00021.JPG   Picture 001.jpg
    Apr 2004
    Grimsby, Ont.
    Avg. Time Online: 9 Mins 21 Secs
    Looking god bud. Will have to stop by and have a look soon.
    #20OF4WD#3476
    "Will roll over for treats"
    May 2008
    Grimsby
    Amazed
    Pics from a few weeks ago.
    Attached Thumbnails Attached Thumbnails IMG_20130707_162626.jpg   IMG_20130707_162728.jpg   IMG_20130707_162709.jpg
