Thread: Gauge Cluster
    Toxic River?
    Time Online: 4 Mths 2 Wks 14 Hrs 50 Mins 32 Secs
    Avg. Time Online: 11 Mins 6 Secs
    Gauge Cluster
    I have a couple questions about guage clusters and engine swaps.
    I currently have a 05 TJ 4.0L and am considering a newer GM V8 swap.
    When doing this engine swap would I be required to swap out the Jeep's gauge cluster?
    Would the GM ECM be compatible with the cluster?
    If cluster was swapped out how would "vehicle odometer" work?
    If the cluster was/has to be swapped out any suggestions on what to use?
    Thanks in advance!
    Windsor On.
    Time Online: 1 Mth 2 Wks 6 Days 2 Hrs 24 Mins 27 Secs
    Avg. Time Online: 4 Mins 7 Secs
    You need to match the ECM communications with the cluster communications. A 2005 TJ uses PCI bus so any dodge/jeep PCI bus engine swap can use the OE cluster, if you preferred to use a CCD bus swap you can swap the cluster from an earlier TJ (pre 2002 if I remember correctly)by splicing the earlier connectors. I am not aware of any way to use non chrysler product and have the cluster function. I believe aftermarket gauges are your best bet.
    The brave man may not live long but the cautious man never lives at all.
    May 2011
    eganville
    Avg. Time Online: 1 Min 9 Secs
    why not drop in a 5.7 hemi its more plug and play
    91 Renagade
    Time Online: 2 Mths 14 Hrs 47 Mins 44 Secs
    Avg. Time Online: 4 Mins 59 Secs
    Staangs fab makes a replacement cluster that holds aftermarket gauges.. they did a 5litre swap.. used all autometer gauges. Speed/odometer was able to be recalibrated to your tire size. it was pretty cool
