Results 1 to 15 of 15
Thread: SYE + XJ Front DS + 8.8 Doable?
    Oct 2011
    Brantford Area
    Time Online: 2 Wks 2 Days 4 Hrs 30 Mins 41 Secs
    Iv been reading, and unfortunatly there are too many people with too many combonations to say yes or no. This is what I plan on :
    NP242 SYE <--> Ford 1310 Flange <--> XJ Front DS <--> Ford 1310 Flange <--> 8.8
    My setup is an Automatic w/ NP242. I will probably use the RE 1801 SYE, It uses the same flange as the ford Pinion flange.
    Does this make since to anyone else other then me??
    My Wife, By Boy
    My Bike, My Jeep, and My VW
    All the loves of my life.
    May 2004
    Windsor On.
    Time Online: 1 Mth 2 Wks 6 Days 2 Hrs 24 Mins 27 Secs
    The XJ front DS has a double cardan joint at the transfer case, you will need to use a CV style yoke on the SYE for this to work
    The brave man may not live long but the cautious man never lives at all.
    Oct 2011
    Brantford Area
    Thats where the 1310 yoke attached to the flange of the SYE comes into play. AS the Double cardan joint uses 1310 u-joints does it not?
    May 2004
    Windsor On.
    Yes a 1310 Cv uses 1310 joints but the flange you speak of has no provision for the centering ball
    Oct 2011
    Brantford Area
    To go from the Flange to the double cardan, there is no centering ball. Or am I not looking at it right.
    Ill just source the Double Cardan Flange yoke.
    May 2004
    Windsor On.
    That's the problem there is no centering ball
    Oct 2011
    Brantford Area
    Like CA : Click image for larger version.
    Thanks, I was kind of confused... But... Baring this issue... IT should work right??
    May 2004
    Windsor On.
    [/COLOR]All else being equal that looks like it would work
    Halton Hills
    Time Online: 3 Wks 1 Day 17 Hrs 48 Mins 14 Secs
    Avg. Time Online: 1 Min 52 Secs
    what im running
    couple jeeps
    Oct 2011
    Brantford Area
    Quote Originally Posted by DaveVmax View Post
    what im running
    Is that DS stock length? And wich yoke are you using on the TC end?
    Hamilton/Stoney Creek
    Time Online: 2 Mths 4 Days 13 Hrs 42 Mins 54 Secs
    Avg. Time Online: 5 Mins 19 Secs
    Quote Originally Posted by Hotwire View Post
    He most likely has an NP231 with the SYE so it uses a Standard Bolt On Yoke where as the SYE AKA Hack & Tap your likely using will use a Flange over a Yoke unless your going with the New Tom Woods NP242 SYE that is now available then you would use the same Yoke that he is useing....
    1983 Jeep CJ7: SOLD
    Google "go jeep xj". I did his np242 setup a few years ago before swapping to a d300. It take some parts from the RE kick depending on the year of t-case and uses a proper yoke and not a flange. Quite simple and only took me an hour or so to complete.
    Sent from my BlackBerry 8350i using Tapatalk
    Edit: Now on a computer here is the link: http://jeep-xj.info/HowtoSYEconversion.htm
    I have an RE flange seeing as at the time my only choise was to buy the whole kit.
    Oct 2011
    Brantford Area
    Im ordering up one of them yokes now. Thanks a ton!
    Anytime!
    Oct 2011
    Brantford Area
    Got my rear yoke, and XJ front drive shaft from the scrappers today, Im gonna need a 1310/1330 u joint. I also ordered the 3103-27CV yoke from Pats Driveline. Tomorrow Im going to see if I can order just the seal housing and seal from RE.
