Results 1 to 16 of 16
Thread: Frame priming and painting question
    May 2012
    Brantford ON
    Time Online: 6 Mths 2 Wks 2 Days 10 Hrs 26 Mins 32 Secs
    Avg. Time Online: 16 Mins 8 Secs
    Hey Guys, since I got my new rust free mint YJ frame from Blenheimboy I have wanted to coat it to make sure it stays that way for years to come as it will be my dd when I turn 16. Now yes people have told me to use epoxy primers but I can only seem to find them in the US and the ones here in canada are way over priced. Now I have found for a really good deal some regular frame primer that I was thinking of using. Now if I sprayed the frame down with a few coats of regular primer then a gloss paint over it will that protect the frame? The inside of the frame will be coated to ofcoars.
    Any feed back would be appreciated!!
    Dec 2008
    Just North of Sudbury
    Relaxed
    Avg. Time Online: 20 Mins 30 Secs
    POR15....spray prep (acid wash) brush it on good to go
    "Bite my Shiny Metal ass!"
    Retread #19
    May 2012
    Brantford ON
    I have thought about that but so far everyone I talk to is telling me not to use it as the uv rays fade it and it will chip on clean metal.
    By the lake
    Time Online: 1 Mth 3 Wks 5 Days 1 Hr 45 Mins 3 Secs
    I had this same question when I was doing my cj. I ended up picking up some acrylic enamel - gloss. Tough coat not easily scraped and adheres well to the primer. Compared to tremclad. Can be had cheap at any surplus store. Just make sure you buy a good quality primer from a body shop. This is most important. So far it has been standing up well but I don't wheel or drive it in the winter or rain and is garage kept. If this was going to see salt I definately would have went the por15 or epoxy route.
    With being your DD in mind and that you really only get one shot at this while it's apart. Save your money and do it right the first time.
    Look into having it galvanized dipped. its going to cost more, but the frame will last forever.
    Dec 2008
    Relaxed
    Quote Originally Posted by matt2299 View Post
    You CAN topcoat it with any paint/colour you want....but if your frame sees direct sunlight....you are spending too much time on the rollcage.
    I did a set of axles (no topcoat) 4 years ago.....rock rash of course, but no peeling - tough stuff
    Georgetown
    Avg. Time Online: 14 Mins 32 Secs
    Quote Originally Posted by buckinbullock View Post
    yep galvcast in Acton was only going to charge me $150.
    The frame will be coated inside and out.
    Colchester / Windsor
    Quote Originally Posted by pav1 View Post
    There is your answer! That is cheap and NOTHING will out perform in terms of rust protection.
    London, Ontario
    Time Online: 2 Wks 1 Day 7 Hrs 59 Mins 52 Secs
    Avg. Time Online: 1 Min 15 Secs
    how much did the frame cost? I might need one in a couple of years!
    Hot dip galv is usually in the range of $.40 - $.47 / LB. It will have to be cleaned thoroughly (blasting is best) or they will charge a lot more per pound if it has to sit in the acid tank longer prior to galvanizing. They may require som additional drain holes to be added for the acid and galv to drain properly so it is best to speak with the galvanizer with some pics in hand prior to sending the frame. This is definitely the way to go if you are seriously about frame protection. It is the only way to thoroughly treat the frame to prevent rot from the inside out.
    May 2012
    Brantford ON
    well I'v finally decided on epoxy priming the frame. Got a good deal on an epoxy priming kit and will also be using it on my axles and going to probably epoxy prime the body to prtect it for years to come. Getting it diped and galvanized is a nice idea but my dad doesn't want to move the frame around anymore ( moved it 3-4 times already and hurt his shoulder plus I killed his lawn)
    Avg. Time Online: 43 Mins 36 Secs
    What is this kit and where did you get it?
    May 2012
    Brantford ON
    The kit is 1 galon of epoxy, catalyst and reducer. total was 130$. Got it from Complete Coverage On harvester Road in Burlington
    Aug 2007
    Ingersoll ON
    That seems a little steep, I've bought 2 part epoxy primer before for $50 a gallon, just mix 2 parts and spray. Any body shop or paint supply place would have it. I've painted a street rod, a bagged mini truck and a Volkswagen cabrio and used epoxy primer on all of em' and it's tough as nails. You DO still need a top coat... But at that point even tremclad would do.
    May 2012
    Brantford ON
    Quote Originally Posted by pnut View Post
    sirriously?! crap... the epoxy its self is 73.89$. Were would you recomend for me to get it next time? Will be doing the body and axles with epoxy too.
    Aug 2007
    Ingersoll ON
    I don't know anywhere specific in your area, but look for body shop supply places, not like NAPA or UAP, a place that would sell product to the public as well as other shops.
    I just did a quick search and this one came up:
    http://www.canpages.ca/page/ON/burli...91-046800.html
    Might be worth a shot
