Results 1 to 20 of 37
Thread: Project Nameless - 1 Ton TJ Build
    Jul 2010
    Brooklin
    Time Online: 1 Wk 1 Day 9 Hrs 11 Mins 20 Secs
    Avg. Time Online: 41 Secs
    Project Nameless - 1 Ton JK Build
    So I wanted to upgrade my old YJ to something else and wanted to build something new to me. I purchase a 2001 TJ with a 4 ltr and an auto transmission. The plan for this jeep was to put a 5.3 Vortec into it and 1 tonnes under it this winter.
Name:	2012-02-05 14.00.08.jpg
    I fixed up the jeep so that I had a good starting base and something that I could drive topless around in during the summer. At some point I decided this jeep was just too nice to cut up and decided to try and sell it.
    While it was up for sale, I purchased another jeep from the forum
Name:	2012-09-30 18.47.15.jpg
    It was a 2.5, 5 Speed, with 4.10's
    Jul 2010
    Brooklin
    So, a little bit of history on this project I’ve been gathering parts since Feb 2012. And I had decided that I wanted to go with a Dana 60 / 14 bolt and turn to kijiji to find one. So, I was looking on kijiji for a 14 Bolt rear end and called Ryan who had one. We got talking a bit and told him I was looking for a Dana 60. He said, "Yea, I have one from a Ford F-250 1978 that I would be willing to sell you.
    We talked a bit and came up with the price for the Dana 60 and the 14 bolt. I was pretty happy with the deal. The best part is I didn’t need to drive out to the middle of nowhere to get it, it was just down the street in Oshawa.
    Front Axle
    - 1979 HP Ford Dana 60
    - 5.13 Gears
    - Zip Locker
    - Solid Diff. Cover
    - Upgraded 9/16 wheel Studs
    Unloading the axle from
Name:	2012-02-05 14.45.02.jpg
    Rear Axle
    - 1982 GM 14 Bolt
    - 5.13 Gears
    - Arb Locker
    - Upgraded Diff. Cover
    - Replaced Studs with Dorman 610-194 (9/16's)
Name:	2012-02-05 13.45.34.jpg
    Cool. I might suggest going right to 538's the highest/lowest ratio those axles will allow. Judging by the pics you were stating what your plans were not what was done correct?
    Sent from my iPhone using My thumbs
    Jul 2010
    Brooklin
    14 Bolt
    I started working on the 14 bolt first and just tearing it down. It was a bitch getting the drums off, and had to cut the backing plates to get them to release.
Name:	2012-02-07 19.48.29.jpg
    I did manage to get both drums off, and it took me a few days.
Name:	2012-02-07 20.19.00.jpg
    Jul 2010
    Brooklin
    Yea,
    I already had the gears done with the 5.13's so it's kinda late Wish I started this thread back in Feb 2012 as I have so much to put in and find it difficult to get the time line right now.
    Jul 2010
    Brooklin
    Dana 60
    Here's some pictures of the Dana 60 with the stock 4.10's. I had a hell of a time getting the kingpin's out and
    cut a grove into them as seen on pirate4x4.com
Name:	2012-03-17 20.02.34.jpg
ID:	85062Click image for larger version.
Name:	2012-05-12 21.21.29.jpg
ID:	85063Click image for larger version.
Name:	2012-05-12 21.21.41.jpg
ID:	85064Click image for larger version.
Name:	2012-05-12 22.01.17.jpg
    Jul 2010
    Brooklin
    So this week I was able to find time to install a 1" Daystar Body Lift that I picked up at RockSpyder4x4 the week before. I only had a single body bolt that took 4 hours to get out, the one directly below the passenger door.
    While I was installing the body lift I took some time to paint the mirror hings and door handles as they had pitted and rusted pretty badly. I used Flat black Tremclad Professional Rust Enamel that works very well.
Name:	2012-10-15 18.43.03.jpg
    So tonight I decided that I might as well take a look at the windshield frame as the windshield was cracked all to hell. I also had to take apart the wiper assembly and replace it so that my wipers would work.
Name:	2012-10-15 18.43.18.jpg
    I unbolt the windshield frame and folded it down to see what kind of rust damage I would be dealing with before I had a new windshield installed. And to my surprise the the frame is near perfect, just have a bit of touch up to do and I am good to go.
Name:	2012-11-02 21.09.34.jpg
    Tomorrow I will be replacing all the brake lines and fixing the font swap bar.
    Anyways here's a side shot with the body lift, you will also noticed I took a torch to the lower fender flare. Nice and black now.
Name:	2012-11-02 21.09.18.jpg
    Toxic River?
    Time Online: 4 Mths 2 Wks 14 Hrs 50 Mins 23 Secs
    Subscribed... What do you plan on putting behind the V8 for tranny and transfercase?
    Jul 2010
    Brooklin
    I am going to be using a 4L60E for the auto tranny, and a 241C with a 231J back half until I can afford an Atlas II.
    Jul 2010
    Brooklin
    So, got some time out in the garage today and was going to replace the brake lines. But, I decided to start playing with the blow torch and the black fender flares.
    If you are interested in trying this your self ensure that you clean the fenders before you take the blow torch to them. I used some rubbing compound to clean them up.
    They don't look bad
    Before
    After
    Close up
    Jul 2010
    Brooklin
    Brake Lines
    So, while I was out playing with the torch today. I managed to get the front brake lines off and bend up some new lines. The other lines where so bad that I could use a pair of side cutters and just clip them off
    Here's the Driver side line.
    Both front lines drying
    Tomorrow I hope to get the front lines installed, and the rear line bent up, painted and installed.
    Jul 2010
    Brooklin
    So, I got a picture text today from Jim at RockSpyder4x4 about my 14 Bolt. I skipped out of work at 3pm and headed over to see what was completed. And took some quick pictures.
Name:	2012-11-29 15.58.50.jpg
ID:	85938Click image for larger version.
Name:	2012-11-29 15.59.08.jpg
ID:	85939Click image for larger version.
Name:	2012-11-29 15.59.25.jpg
    Here's the hunk of metal that was removed.
Name:	2012-11-29 16.06.20.jpg
ID:	85941Click image for larger version.
Name:	2012-11-29 16.07.03.jpg
    Some more shots of the inside welding and outside.
Name:	2012-11-29 16.11.49.jpg
ID:	85944Click image for larger version.
Name:	2012-11-29 16.14.33.jpg
ID:	85945Click image for larger version.
Name:	2012-11-29 16.14.52.jpg
    While I was their we noticed that the copper ARB line was crushed in shipping by the weight of the carrier. The only real issue with this was now I need to call the US company and see about getting a replacement and driving to the boarder to pick it up. I would much rather said "Jim, looks like you've got an issue ". I think this is going to be more of a pain in the ass and any saving are now going to be lost. Jim the funny guy that he is, said "Well, I would have given you the same price. You didn't ask" Lesson learned.
Name:	2012-11-29 16.51.01.jpg
    Action shot
Name:	2012-11-29 17.28.02.jpg
    Jul 2010
    Brooklin
    Ring Gear Clearance
    Here's what the ring gear clearance looks like.
Name:	2012-11-29 17.01.24.jpg
    The other issue we ran into was the yoke was F***ED and the u-joint would slide back and forth. Glad Jim noticed this.
    WFO makes a nice U-bolt style yoke for the 14B it's 1350 joint. Nice product and reasonably priced. Good company to deal with. I know lots of guys running the strap style with no breakage but why not have a little more piece of mind with the good stuff. Less chance of the U-bolts stretching IMO.
    Jul 2010
    Brooklin
    Here's a picture of the 14 bolt on the milling machine. Jim needs a better cell phone camera.
    Jul 2010
    Brooklin
    TMR Black Friday - 15 % off !
    So,
    I hit the TMR website on Friday last week and picked up my 3 link kit, front towers for my ORI's and got 15% off. Today I went and picked up all my goodies.
Name:	2012-11-30 16.45.34.jpg
    The best part was Mike & Tim loaded everything into my car for me.
Name:	2012-11-30 13.52.31.jpg
    The Black Friday sale on TMR's website was the best discount they have ever offered !!! Wish I had some more $$$
    Going to start building the Front 60 this weekend.
    Oct 2012
    Windsor,On
    Avg. Time Online: 24 Mins 50 Secs
    Is it finnished or are you parting it out LOL hows it going?
    Jul 2010
    Brooklin
    Well,
    What has happened was I wasn't happy with the lighting in the garage so I added some more lights and this has taken a bit longer than I hoped. I still haven't picked up the 14 bolt from Jim as I am enjoying the FREE winter storage.
    The other thing is I am not happy with the current frame as I found a few holes at the very back. So, I am considering getting a new RUST FREE TJ frame.
    Delays, delays, delays...
    Re: Project Nameless - 1 Ton TJ Build
    Well if you are going with a clean frame nows the time.
    Jul 2010
    Brooklin
    Namesless - 1 Ton JK Build !!
    Wow, so much time has passed since I started this threaded, and I have changed my mind about 14 times (15 bolt was the final decision) . I was going to build a TJ with HP Dana 60 Front, 14 Bold Rear, ORI Struts in all four corners, long arms but decided against it.
    Jeeper52 asked if I was going to part it out as it was taking so long. And at one point I also most considered parting it out and just keeping a mild jeep for the weekends.
    The good news is I am not parting the project out, I have decided to get Jim over at RockSpyder4x4 build the project for me. The decision to use a 2002 TJ has been dropped in favor of a 2007 - 4 Door JK. I purchased a 2007 jeep Rubicon in Dec of 2013 and was driving it around all winter.
    The 4 Door JK is getting the HP Dana 60 in the front, and the 14 Bolt (shaved) that Jim built last year. The Dana 60 has a Zip Locker and the 14 Bolt has a ARB in it.
    What else is going into the JK ? Well here is a pallet of parts that was picked up on Friday.
Name:	2014-02-14 09.28.13.jpg
    Stay Tuned
