Results 1 to 16 of 16
Thread: plasma tourch
    Oct 2012
    Windsor,On
    Time Online: 10 Mths 1 Day 5 Hrs 51 Mins 9 Secs
    Avg. Time Online: 24 Mins 46 Secs
    plasma tourch
    I have a chinese plasma cutter that works great. it is called a cut 40. the problem is no more consumables support. so I go to my local welding supplier and he want som 600.00 for a new torch. ouch . I can find new chinese ones for around 200.00. My question is how difficult might it be to graft another tourch to the machine. I think its just 1) power 2) air and 3)trigger switch. shouldnt be that hard is it? Whats your opinions? am I missing something?
    I found a supplier
    Time Online: 2 Yrs 1 Mth 3 Wks 3 Days 21 Hrs 34 Mins 45 Secs
    Avg. Time Online: 1 Hr 4 Mins 32 Secs
    try talking to duncan maybe he can help .. www.titanwinches.com
    Avg. Time Online: 5 Mins 43 Secs
    OOUCH. I got a torch of ebay for 25.00 shipped and 150 consumables (electrode, tips) and a few Swirl Cups and such for another 45ish.
    Oct 2012
    Windsor,On
    I dont know what was wrong with my setup ,but i used to go through swirl cups like crazy. I stil have alot of the inner pieces tips collars etc.but Im down to 2 swirl cops. so I use it only when absolutly necessary. which isnt what I bought it for.I want to cut everything. I wonder if since they shipped me a cut 60 torch there were problems.IDN
    Avg. Time Online: 28 Mins 56 Secs
    Quote Originally Posted by Piratexpress1369a View Post
    This...
    Same people... www.everlastwelders.ca
    Can also be reached as username Jeannie or username Duncan here on JeepKings
    Great people, site sponsors, located in Burlington, Ontario, but will ship anywhere...I am sure they will be able to help you out at a reasonable cost.
    Time Online: 10 Mths 3 Wks 5 Days 6 Hrs 21 Mins 33 Secs
    Quote Originally Posted by jeeper52 View Post
    More often than not, this is an air issue. Inadequate air pressure and/or water in the air. Plasmas need very dry air. Depending on the quality of the air source, a water trap is not enough. You will probably need a dryer in line.
    Oh, and I 3rd the idea to call Jeannie and Duncan. They stock a lot of plasma parts and should have a torch assembly and consumables to meet your needs. They have the knowledge and experience to set you up right. One way or another, you will be able to run a torch assembly of your choosing on your machine.
    Oct 2012
    Windsor,On
    Already pmed him, thanks
    plasma tourch
    I would PM Jeannie. You might get a quicker response.
    Colchester / Windsor
    Time Online: 1 Mth 1 Wk 23 Hrs 25 Mins 56 Secs
    Avg. Time Online: 3 Mins 7 Secs
    I know my Hypertherm recommends a 1 micron air filter ($150). Right in their literature it says lack of proper filtration will affect consumable life and water in the line also affects consumable life dramatically. I have a filter after my compressor and a seperate one directly ahead of my plasma regulator with maybe 12-16" to the unit. I have had the unit for 6 months and am just ready to swap to a new consumable set (I use it at work in an industrial setting).
    Oct 2012
    Windsor,On
    Wow I didnt know it needed that much dryness and filtration. I have a standard filter at my compressor (Industrial 5 hp) and a water trap they sent me with the cutter. I will get a desicant dryer before the plasma cutter filter. Thank you very much for the info.
    For sure. We run several plasma cutters and one massive Hypertherm HYP400. The results of even small amounts of water can be catastrophic. As the amperage goes up, the damage gets larger. I have seen the end of the torch incinerate because of the presence of water when it gets mixed with a 5000 degree arc. The HYP400 runs an expensive automated drying, cleaning and monitoring system for the air source as a result. The importance of clean, dry air cannot be overstated here. You will notice better cut quality, control and increased consumable life with very dry air.
    Dec 2009
    burlington
    Devilish
    Time Online: 1 Wk 3 Days 12 Hrs 36 Mins 58 Secs
    Avg. Time Online: 51 Secs
    dude! where you getting your consumables from??
    hello I'm across the street now
    Birdman
    ditch the bitch! let's go muddin'
    Oct 2012
    Windsor,On
    My problem was the cup would crack and a big chunk would fall out. Now that you guys are talking about water, I can see a droplet causing the crack
    Quote Originally Posted by birdman View Post
    Nobody stocks the HYP400 torch consumables. We are on an owners program with Hypertherm for them. At the time, that was the best value way to do it.
    Aug 2005
    Cambridge
    Time Online: 1 Wk 2 Days 16 Hrs 41 Mins 14 Secs
    Avg. Time Online: 47 Secs
    Sorry to hijack your thread, but I have a friend that deals exclusively with Hypertherm industrial plasma systems. He specializes in automated systems and consumables and is local. I believe he is still on JK as "bender".
    Just a shameless plug for a friend, our plasma system supplier and a fellow jeeper.
    http://www.automated-cutting-machinery.com/
    1980 CJ7- kinda...
