Thread: 4 banger tub on a 4l chassis
    Feb 2007
    Cottam, Ont.
    Time Online: 1 Day 4 Hrs 36 Mins 17 Secs
    The body of my 92 YJ with a 4.0l was rotted out. So i found a 91 YJ with a blown 2.5 but a good tub. pulled it off and put it on my 6 cyl chassis hook everything up and turned the key and nothing, no feul pump, no gauges, no crank. if i jump the starter i will get spark when turning over. Is the wiring in the tub different from the 4 to the 6?
    did use the 4.0l computer.
    Time Online: 8 Mths 3 Days 23 Hrs 9 Mins 33 Secs
    Avg. Time Online: 20 Mins 3 Secs
    under the hood will be different, but under the dash is the same. Was yours the 4.2? If so then there will be a ton of differences. But if it was a 4l and you used the 4litre wiring harness and computer, then it simply plugs into the fire wall. I jnow as I have done it
    Feb 2007
    Cottam, Ont.
    just swapped tubs. kept all the wires on the engine and frame.
    Cottam, ONT
    Time Online: 4 Wks 1 Day 9 Hrs 30 Mins 51 Secs
    Avg. Time Online: 2 Mins 25 Secs
    Have you checked the relays? does it turn over if you jumper the starter relay?
    Essex County Jeep Club
    -1999 TJ "50 Shades of Jeep"
    Avg. Time Online: 13 Mins 7 Secs
    You did plug the column harness back in correct?
