Results 1 to 20 of 37
Thread: yj stretch spring question
    rockwood, ontario
    Time Online: 1 Wk 6 Days 20 Hrs 10 Mins 45 Secs
    Avg. Time Online: 1 Min 8 Secs
    hey so i am wanting to stretch my yj. i need info because i have heard xj leaf springs are good. but i heard dakota springs are better. what way should i go
    thanks
    Guelph
    Time Online: 1 Mth 2 Wks 6 Days 5 Hrs 38 Mins 38 Secs
    Avg. Time Online: 4 Mins 7 Secs
    There was a post on here awhile back with all the springs length's and stuff but can't find it.
    Maybe someone will know where it is.
    Avg. Time Online: 33 Mins 21 Secs
    Re: yj stretch spring question
    Subscribed! I'm wanting to do a stretch this spring and just so happen to have a Durango I'm parting out. If I could just use the rear leafs from it then that would be awesome!
    Bowmanville
    Breezy
    Time Online: 1 Mth 3 Wks 5 Days 9 Hrs 50 Mins 26 Secs
    I have xj springs. They work pretty good. Antiwrap bar is a must.
    I also have a rear bumper with shackles to fit xj springs for sale.
    May even have old xj springs somewhere.
    #4700
    Rubi....
    buggy...
    rockwood, ontario
    i have found all the lengththe only thing i am worried about is the front frame mount i dont what to have to move it. i dont mind moving shackle
    thanks
    rockwood, ontario
    what you looking for bumper and style of it
    thanks
    Bowmanville
    Breezy
    with xj springs you leave the front mount stock and move your shackles back onto the bumper.
    they move your axle back 6 in . so you need to remove your gas tank.
    its just a 2x4 tube bumper with shackles on the bottom and flush receiver hitch.
    pm me your email i can send you some pictures.
    Oct 2012
    Windsor,On
    Time Online: 10 Mths 1 Day 5 Hrs 51 Mins 9 Secs
    Avg. Time Online: 24 Mins 42 Secs
    How much streach are you after? I used waggy springs an all 4 corners and got 2 inch streach 1" front and 1" rear. anymore than that and you need major work, ie fuel tank or steering etc.
    Feb 2011
    Aurora
    Time Online: 3 Wks 6 Days 21 Hrs 46 Mins
    Avg. Time Online: 2 Mins 17 Secs
    Quote Originally Posted by Sancza View Post
    I'd like to see pics of that bumper too. You have a PM.
    Signed with an X
    May my YJ RIP
    Building an SAS Xterra...slowly
    Time Online: 4 Mths 2 Days 18 Hrs 7 Mins 28 Secs
    Avg. Time Online: 10 Mins 4 Secs
    here is a picture that shows some lengths
    here is how I mounted my rears...
    and yes Anti wrap is a must have....
    have a look at my build thread (in the signature line) if you would like to see more of how I put it together.
    rockwood, ontario
    ok so moving gas tank isnt a problem i have already did that. i do have an very heavy duty bumper so i will just use that. if i used dakota spring will front mount have to be moved? if so i will just do xj springs. i do already have anti wrap bar i just broke a brunch cuase of pinon angle so i want to lower a big and stretch to make angle better
    What ever spring you choose to use for the stretch I would suggest that you redo the rear of the jeep to incorporate the bumper into the frame and make it solid. Unless your yj has a mint frame it will brake and cause a whole lot more issue.
    rockwood, ontario
    jeep has been strengthen up already added lots of support. i have just seen the pics of strectched yj and i love the look. i am also scared to get dakota springs and find out i have to move front mount. thats just something i dont want to do this year. if they don't fit as easy as xj one then i am going to do xj springs
    Jun 2011
    Vaughan
    Time Online: 2 Wks 2 Days 6 Hrs 16 Mins 20 Secs
    Avg. Time Online: 1 Min 20 Secs
    I did mine differently with XJ springs. I designed some flex shackles that drop when flexing. I have no track bar and the axle doesnt seem to shift from side to side. A wrap bar was a must as springs are very soft.
    I also did the pirate4x4 tank mod and didnt have to relocate it. So I still have my rear seats.
    For being a leafer flex is not bad
    Gas tank mod:
    Obsessed about offroading and moved from Spain to Vaughan.
    Owner of a never ending YJ project: BUILD THREAD
    Winter beater 1998 Toyota 4Runner
    Owner of a Suzuki Sammy back in Spain
    www.d-limit.com
    rockwood, ontario
    thank you for the pics and info i will be going with xj springs when i measured the dakota springs will make my tires hit my style of bumper
    rockwood, ontario
    now another question are you guys making hanger or buying? if buying what companies are better?
    thanks
    Feb 2011
    Aurora
    Quote Originally Posted by Herve-D-Limit View Post
    Those are dirty... I may just steal this ideal! Are they act as a revolver shackle?
    Oct 2012
    Windsor,On
    Quote Originally Posted by BigOrngYJ View Post
    Did you uses threaded rod for the shaft between halves
    OF4WD #7392 88 Romeo
    Jun 2011
    Vaughan
    Quote Originally Posted by jeeper52 View Post
    Princess Auto Bolt and nut. Welded the bolt in the square tube and nut to the other square tube. Hope this helps.
    Oct 2012
    Windsor,On
    I think tera-flex makes them but are excpensive, I think some 400.00
