Thread: HEI oil leak
    By the lake
    Time Online: 1 Mth 3 Wks 5 Days 1 Hr 42 Mins 37 Secs
    Avg. Time Online: 4 Mins 36 Secs
    HEI oil leak
    I bought a used :2- and was wondering if there is supposed to be a o ring or gasket where it drops into the whole?
    Originally when I installed it, I put an o ring on the shaft. It leaks.
    Removing it right now and was wondering if I could put some RTV or the "right stuff" around the shaft where it drops in and wait til it sets and then tighten it down or use nothing?
    If I use nothing is there a chance of mucking up the gears from tightening it down too far?
    BTW, amc 360
    Thanks.
    Georgetown
    Time Online: 5 Mths 3 Wks 5 Days 23 Hrs 16 Mins 16 Secs
    Avg. Time Online: 14 Mins 33 Secs
    there should be a flat paper gasket
    see step #9
    http://www.4wd.com/Instructions/PD/DUI_Install.pdf
    By the lake
    I knew there had to be something in between both surfaces.
    Just tried a real thin bead of the" right stuff". Hope this will fix it.
    Yikes! just read that link. thanks pav.
    Georgetown
    that will be squishy and could put too much for on the gears and wear them out.....don't want to change a cam.
    better get a paper gasket in there....check out step #9 in the instructions.
