Results 1 to 20 of 23
Thread: "wobble" when turning
    Toronto, ON
    Fine
    Time Online: 1 Mth 1 Wk 2 Days 18 Hrs 3 Mins 53 Secs
    Avg. Time Online: 3 Mins 15 Secs
    Just over the past week I've noticed what feels like a 'wobble' in my front when making tight turns.
    Rotated the tires and replaced the front brakes, had no effect. While I had the corners in the air I gave each tire a good wiggle to check for worn bearings/ball joints/TRE's but I think everything is fine. Ujoints appear good as well, at least no looseness or missing caps.
    It almost feels like 4WD is engaged... but I'm 100% sure it's not.
    Any suggestions before I get a buddy to hop in and make some turns while I watch the suspension from outside the Jeep?
    Coley - 2010 JKU - Deep Water Blue
    http://www.youtube.com/user/ColeyLikesBacon
    By the lake
    Time Online: 1 Mth 3 Wks 5 Days 2 Hrs 25 Mins 28 Secs
    Avg. Time Online: 4 Mins 36 Secs
    Are you getting any noise? Bearings grinding?
    When you say it seems like its in 4wd. Makes me think you have a bad hub.
    Scarborough
    Time Online: 2 Days 5 Hrs 30 Mins
    Avg. Time Online: 10 Secs
    If everything checks out ok as far as ball joints, tie rods ,drag link ,steering box bolts , control arm bushings, etc. Its most likely from the u-joints in the axle. How much of a tight turn are we talking here ?? Any JEEP I've had or been in will always do that if you crank the wheel to the stop. Do the front wheels tilt inward slighlty at the top ?? Bad bearings !!!. How about your toe in, is it close to where it should be ???
    Just North of Sudbury
    Time Online: 8 Mths 1 Wk 2 Days 12 Hrs 4 Mins 30 Secs
    Avg. Time Online: 20 Mins 28 Secs
    X2 Bad U-joint in front axle shafts (at the knuckles)
    03 Rubicon with stuff to make it gooder
    "Bite my Shiny Metal ass!"
    Retread #19
    Aug 2012
    Clarington Ontario
    Time Online: 1 Wk 1 Day 9 Hrs 6 Mins 35 Secs
    Avg. Time Online: 41 Secs
    Hey. I'm having the exact same issue. I've been told it could be ball joints. U joints. Tie rod holes being hallowed out by the bolts causing loose feeling. The exact thing you're describing I have. Let us know
    Toronto, ON
    Fine
    Not turning so tight that my tires rub the sway bar. I'll to a walk-beside tomorrow and see if I can see anything moving. No noise... I've had a dud U-Joint before a couple times and it's always been more of a knock than a wobble feeling.
    I'll report back tomorrow.
    Time Online: 1 Mth 2 Wks 1 Day 1 Hr 19 Mins 2 Secs
    Avg. Time Online: 3 Mins 41 Secs
    A bad u joint seizing up will make the steering feel funny when turning. Getting before it breaks the ears off.
    Sent from iThingy
    83 CJ9 LS5.3/4L60E/231/B4R/D300, 8274,D60/14b,ARBs,15"airbags susp, 18"stretch 39"PITBULLS
    09 Nissan
    Ford F350 CrewCab Long box 4x4 TowPIG/dd 165"wheelbase
    Mar 2010
    www.jeepcentral.ca
    Time Online: 3 Wks 5 Days 1 Hr 40 Mins 29 Secs
    Avg. Time Online: 2 Mins 8 Secs
    Toronto, ON
    Fine
    Well after a walk-along I definitely have a worn end at the steering box end of the drag link. Probably reason enough to beef up all my steering with the Currie package.
    Bearings seem fine, but I'm going to pop everything off this afternoon and check out the ujoints.
    edmonton alberta
    Time Online: 5 Mths 6 Days 18 Mins 19 Secs
    Avg. Time Online: 12 Mins 48 Secs
    before you do that , jack up the front end and spin the tires and see if one has a shifted belt or a slight egg to it on the inner or outer tread may be a bent wheel as well but start there before you take it apart
    Toronto, ON
    Fine
    Would have caught that with the tire rotation. It'll be in the air anyway. I'll double check.
    Toronto, ON
    Fine
    Most definitely the front drivers u joint. I've broken caps before but never had one siezed.
    Toronto, ON
    Fine
    The outer half of the drivers side u joint was seized solid.
    With just a toolbox and a little f'n sledge I managed to swap it in an hour and a half.
    CAA guy from the hammer was parked across the road for 20 after dropping off a Subaru next door. He was watching me hammer away for a while before asking if I remembered to remove the c-clips. Duh. As soon as he wandered up the driveway to supervise the last cap finally popped out. Click image for larger version.
ID:	89274. Rusty as f%ck.
    Quick test drive and we'll see if that solved the problem.
    Jun 2010
    X
    Time Online: 2 Days 6 Hrs 32 Mins 39 Secs
    Avg. Time Online: 11 Secs
    Quote Originally Posted by Coley View Post
    Just picking up on this thread (I know it's been here for awhile). I think I have the same problem and am considering replacing both front end u-joints myself. Any pointers? How difficult was it? I've got a 2008 JK unlimited and really the only thing that could cause a problem is the rust. The dealership was really good at helping me figure out the problem but mentioned that there may be an issue with the wheel bearing when putting it all back together.
    "Just because I don't know something, doesn't mean I'm not an expert"
    Toronto, ON
    Fine
    Problem solved. Steering feels light as a feather now too. Didn't realize how seized it was.
    Bingo. U-joints seizing is pretty common when they stopped putted grease nipples on em.
    Sent from iThingy
    Time Online: 4 Mths 1 Wk 11 Hrs 32 Mins 45 Secs
    Avg. Time Online: 10 Mins 27 Secs
    New ujoint you installed Coley,
    was it greasable or not?
    Billy
    Toronto, ON
    Fine
    No, they didn't have a greasable one at Partsource.
    you'll be fine. I didnt notice much difference in axle u joint life with either one (and I never broke either type)
    Jan 2007
    Windsor,Ontario
    Time Online: 1 Day 13 Hrs 30 Mins 50 Secs
    Yup U-Joints.Just had mine replaced $$$
