Thread: Rear Inner Fender Wall Removal
    Niagara Falls, ON
    Time Online: 2 Days 9 Hrs 25 Mins 43 Secs
    Avg. Time Online: 11 Secs
    I am going to replace my front and rear fender flares and am asking anyone what tool I am going to need to remove the rear inner fender walls on my 04 TJ. Is there a thread out there where someone has already asked the questions?
    Tool?
    Clips - if broken where can I get replacements?
    Ken, VA3KNE
    04 TJ Sport, 4.0L, 5 Spd, 4" lift, 33's
    JEEPERS DO IT ON ALL 4's
    HaltonHills
    Dead
    Time Online: 2 Mths 4 Days 2 Hrs 39 Mins 48 Secs
    Avg. Time Online: 5 Mins 17 Secs
    I pulled mine out then sprayed rust primer and bed liner inside and under the flares. Used a flayed flat head screwdriver intended for pulling plastic clips. The clips can be replaced at your local bestbuy.ca or automotive supplier just keep one to match up at the store - some reason prices vary for identical items depending on the listed intent on the package.
    I think I have info or pics in my build thread. Can't remember 100% - ADHD causes short term memory issues.
    I BE GETTING BUILDING ME A REAL JEEP.....
    Click here for details.
    Niagara Falls, ON
    I was in to Part Source (Canadian Tire), they have the flare tips but not the tool, can order from Canadian Tire...don't carry it...what a joke...but if you need it you only have a choice here in Ontario...Auto Source in NY
    Feb 2011
    Aurora
    Time Online: 3 Wks 6 Days 21 Hrs 40 Mins 40 Secs
    Avg. Time Online: 2 Mins 18 Secs
    A socket set, a pair of channel locks, and patients...
    Signed with an X
    May my YJ RIP
    Building an SAS Xterra...slowly
    Time Online: 3 Mths 2 Days 4 Hrs 14 Mins 38 Secs
    small trim remover from home depot and a grinder to cut a slot in it....
    hamilton
    Time Online: 3 Wks 5 Days 18 Hrs 33 Mins 54 Secs
    Avg. Time Online: 2 Mins 12 Secs
    i used to use a pair of side cutters to pull them out. the removal tool is sold at princess auto. the push pins are .20 cents each at parts source. and around a dollar at the dealer. just cut them and put new in
    Niagara Falls, ON
    Exactly what I did, used an old steak knife and cut them out. Pulled out the inner wall for now, installed the new 7" fender flares. Next I plan to clean the surface rust and then spray it with underspray before putting the inner walls back in.
    Lanark, ON
    Time Online: 4 Wks 1 Day 21 Hrs 14 Mins 14 Secs
    Avg. Time Online: 2 Mins 27 Secs
    Side cutters work well. Don't plan on putting mine back in just painted black
    Niagara Falls, ON
    I've read on other forums the same. Clean up the surface and agree with you, paint or undercoat it black.
