Results 1 to 11 of 11
Thread: 6.1 in an 89' yj?
    selkirk
    Time Online: 4 Days 21 Hrs 49 Mins 38 Secs
    Avg. Time Online: 24 Secs
    6.1 in an 89' yj?
    i'm looking at a work truck with a 6.1l out of a chevy 2500hd. want to use the axles also. anyone got any insite in this matter?
    If you can't get out you need more tentacles.
    Time Online: 2 Mths 1 Wk 2 Days 14 Hrs 23 Mins 47 Secs
    Avg. Time Online: 5 Mins 44 Secs
    More info. What year truck. Sure it isn't a 6.0l. Would it not have IFS making the front useless to a YJ. Keep fuel injection, going carb/propane? Trans? T-Case?
    Everything custom.
    As said, need more info. Unless it's an old 6.2/6.5 diesel, it would be a 6.0 (don't think the LS-ish 6.2 is in the 2500's yet). Lots of info around for 6.0 swaps and what is needed. Trans might be a bit long in a YJ without a stretch, but could be doable.
    Mar 2013
    Time Online: 4 Days 11 Hrs 40 Mins 24 Secs
    Avg. Time Online: 22 Secs
    i would assume you mean 6.0l because your saying a 2500hd. the motor will work fine as its the same size as the 5.3. but the tranny and transfercase will be a 4l80 being from a 2500hd which will be alot larger in size and heavier then a 4l60. might be tight for space length wise and height wise. the rear axle will be fine to use but the front will be ifs so it wont be any good to you
    selkirk
    thought it was a 6.1l but i must be mistaken. thanks for the info. as i get more i will post.
    selkirk
    Yup. 6.0l. 2004. What's with not being able to use the front axle?
    West Coast
    Time Online: 6 Mths 2 Wks 9 Hrs 24 Mins 5 Secs
    Avg. Time Online: 16 Mins 1 Sec
    Problem with the front is it is Independent isn't it, not a straight axle. Or are you trying to use the IFS for some reason?
    Time Online: 10 Mths 3 Wks 5 Days 38 Mins 51 Secs
    I've seen a GM IFS swapped into a heep. What a gayed up train wreck and waste of time. The very worst of both worlds.
    If you want an IFS heep, just buy a Liberty.
    Time Online: 1 Mth 2 Wks 1 Day 1 Hr 19 Mins 2 Secs
    6.1 in an 89' yj?
    Just slap the Yj body on the Chevy frame after you chop a couple feet out of it. Then you'll have the ultimate rainbowmobile.
    Sent from iThingy
    83 CJ9 LS5.3/4L60E/231/B4R/D300, 8274,D60/14b,ARBs,15"airbags susp, 18"stretch 39"PITBULLS
    09 Nissan
    Ford F350 CrewCab Long box 4x4 TowPIG/dd 165"wheelbase
    Apr 2014
    toronto
    Time Online: 18 Hrs 13 Mins 33 Secs
    or you could ignore those guys find a clean solid axle and set up the rear axle t-case and engine/trans....
    Cool
    Time Online: 3 Mths 4 Days 8 Hrs 36 Mins 1 Sec
    Avg. Time Online: 7 Mins 46 Secs
    Quote Originally Posted by iamcanadian View Post
    Or reply to a thread a year old!
    Professional lunatic
    TJ V3.0 in the works "This is only temporary, unless uhhhh..... it works."
    I get confused once numbers get bigger than I can count on my appendages. I'm only good up to 21!
    one quarter turn before something breaks is a good torque spec.
