Thread: Safety question
    Beamsville
    Safety question
    Can anyone answer for sure if a car can/will pass a safety if the ABS light is on?
    Professional lunatic
    Time Online: 10 Mths 3 Wks 5 Days 35 Mins 58 Secs
    Technically, no, it should not pass with the light on as that typically implies that the ABS is not functioning and switched itself off because of a problem.
    Pull the cluster and remove the offending bulb would be the best bet. lol
    May 2011
    eganville
    as long as the breaks work most shops will let it pass but to be safe follow CTD'S advice
    91 Renagade
    Colborne, Ontario
    Time Online: 2 Wks 2 Days 5 Hrs 49 Mins 30 Secs
    Depends on the mechanic. They're not suppose to pass it because it is part of the braking system. Which is suppose to function fully for safety.
    But some mechanics are old school and check everything else.
    Do like CTD says. Worse that'll happen is they will notice the bulb missing and make you replace it. And then find out what is wrong with the ABS system. If this is a '96 or newer, you should be able to pull the code with a OBD II code reader.
    '88 Wagoneer, 4.0, Auto, 6.5" longarm lift, Locked rear, on 33x12.5x15. '95 Grand Cherokee,(wifes) 4.0, Auto, 3.5" Tuff Country on 32" BFG M/Ts. '95 YJ, 2.5, AX5, 2" spring & 2" body, riding on 33s. More to come.
    Member of
    4-Lo Offroad, 4Wildrides
    OF4wd #5896
    Beamsville
    So right from the MTO website. Posting here in case anyone searches for this in the future.
    •Vehicles manufactured after July 1, 2011 with Anti-Lock Brakes (ABS) must have ABS inspected and operating as intended to pass the inspection. On January 1, 2014 all vehicles originally equipped with anti-lock brakes will required the ABS operating as intended to pass inspection
    So my 2005 should be good to pass with the ABS light on.
    We have recently been advised that the updated Safety Standards book, which will include new ABS requirements, has been delayed. We & most others are still using the old book, which does not require ABS to be functional.
    Re: Safety question
    Suddenly I'm glad the LJ didn't come with abs...
