Results 1 to 20 of 39
Thread: Engine Seized on 2009 Wrangle 3.8 L , 78K - options
    Aug 2005
    Time Online: 2 Hrs 13 Mins 8 Secs
    Heading back from the cottage, 20 mins from home , and the oil light comes on , and then the engine shuts down minutes later
    Get it towed to a local shop, and the engine is seized. (It did not go to a dealership, forgot we had roadside coverage)
    Last oil change was around 65K
    Options ???
    - is it covered under the power train warranty 5 yrs / 100k
    - replace it another 3.8
    - replace it with something else , are there other options ?
    One payment left and then we owned it ...
    Thanks for the suggestions and help
    Avg. Time Online: 13 Mins 9 Secs
    Generally if the oil light comes on its too late but if you can get your hand up to shut off the key quick enough it may survive.
    What are the specified oil change intervals?
    As far as other engine options how deep are your pockets ?
    Toronto, ON
    Fine
    Time Online: 1 Mth 1 Wk 2 Days 16 Hrs 55 Mins 22 Secs
    Avg. Time Online: 3 Mins 16 Secs
    13k since the last oil change? The 'CHANGE OIL' warning comes on every 4500-5000km in my 2010, though I think the Jeep reco is 10k.
    I tried going that long once, and the oil was down 1L after 6k. 5W-20 flows like water. I do my own change every 5k now.
    You can try your luck with the warranty. Otherwise the 5.7 hemi apparently fits the JK engine compartment. Or you could go diesel with a 4BT swap. Both are a little more pricy than replacing the minivan engine.
    Coley - 2010 JKU - Deep Water Blue
    http://www.youtube.com/user/ColeyLikesBacon
    Avg. Time Online: 12 Mins 26 Secs
    First thing I would do is call a dealer/Jeep regardless of what else you plan to do. If you knew you could get a freebie engine, you'd be nuts to not do so.
    Any chance of negligence of any sort?
    Toronto, ON
    Fine
    Quote Originally Posted by hustler View Post
    The first thing the dealer will probably do is drain the oil to see how much is left, how much sludge there is in the bottom end (now that he's seen only 2-3L drain of the 5-6 it takes to fill)... I don't now if there's any hiding that.
    I don't want to slag the op, but for the 13k since the last oil change, when was the last time you checked the dipstick?
    Milfhaven (Beach)
    Time Online: 1 Wk 5 Days 18 Hrs 19 Mins 34 Secs
    Avg. Time Online: 1 Min 3 Secs
    My dealer recommends changing the oil every 5000 km and that's what i have been doing since i bought her in 2009. I find that i have to add a litre between oil changes. She's not burning oil, it's just a Chrysler engine thing. Had the same with my PT Cruiser. Good luck, hope it works out for you.
    Anybody else out there with a JK, you need to check your oil between oil changes.
    "i like the way the line goes up the back of those stockings"
    #6182 OF4WD & JEEPKINGS MEMBER RETREAD # 007
    Avg. Time Online: 4 Mins 45 Secs
    Quote Originally Posted by Coley View Post
    A couple problems with this option...
    1. Doesn't meet emissions
    2. Serious lack of HP (only 120hp)
    3. Physical constraints of the engine (both tall and heavy)
    Time Online: 2 Mths 4 Days 13 Hrs 42 Mins 54 Secs
    Avg. Time Online: 5 Mins 19 Secs
    Quote Originally Posted by EngineerJoe View Post
    Plus I believe under the emmissions guidlines for anything 2000+ you can NOT install and engine of anykind that is not equal or newer then the model year but our Resident E-test Guru would know best on this one
    May 2011
    eganville
    Avg. Time Online: 1 Min 9 Secs
    13k on the same oil is long but not that bad. my thoughts find a scrap yard find a salvage jk that has been rear ended or something and get the 3.6 it is plug and play and better than the 3.8l
    91 Renagade
    Windsor On.
    Time Online: 1 Mth 2 Wks 6 Days 3 Hrs 20 Mins 55 Secs
    Avg. Time Online: 4 Mins 8 Secs
    [QUOTE=EngineerJoe;1325336]A couple problems with this option...
    Horsepower only sells cars... Torque drives them
    The brave man may not live long but the cautious man never lives at all.
    Burlington, ON
    Time Online: 6 Mths 2 Wks 2 Days 10 Hrs 18 Mins 21 Secs
    Avg. Time Online: 16 Mins 11 Secs
    okay first things first.
    1. why did you let it go 13K without an oil change? right there minimizes the dealer helping you out if the oil should have been changed every 5k or dealer/manufacturer specified.
    Go to your dealer and see if they will help you and if they can then get a new 3.8L installed ( if still covered under warranty and IF dealer helps you)
    The 3.8 really isn't a bad engine but as stated in the thread, if you have some money then look into the 3.6 Pentastar installed.
    Jun 2002
    Hockley Valley, ON
    Time Online: 4 Mths 2 Wks 6 Days 22 Hrs 22 Mins 4 Secs
    Avg. Time Online: 11 Mins 37 Secs
    I'd absolutely look into the warranty first, then decide on what to do.
    Aside from emissions, insurance can also be an issue if you switch engines. The diesel sounds good on paper, but I think you'll be disappointed.
    OF4WD 5982 & 5983
    13k is not that bad.... Call the OEM, you will have to Push to have them replace it. But IMHO its much cheaper than any other option.
    Canadian Rockies
    Devilish
    Time Online: 2 Wks 1 Day 17 Hrs 10 Mins 23 Secs
    Avg. Time Online: 1 Min 17 Secs
    i would have Chrysler roadside assistance tow it to dealer.
    i would state i was driving home form the cottage and oil light came on.
    i pulled over.
    engine quit and here we are.
    Let them figure it out, that is why you have warranty.
    Oak Ridges
    Time Online: 1 Wk 2 Days 4 Hrs 6 Mins 11 Secs
    Avg. Time Online: 45 Secs
    Manual recommends changing the oil every 10k, as someone else says, my computer tells me to do it every 4-6k. I usually ignore the computer and go with the 10k interval given I use synthetic oil. All that being said, I've been finding that for the past year or so, much like everyone else here, my JK goes through oil like I drink water. I'm 6k from my last oil change and have had to add 2l already. Hate to say it, but at 13k since your last one, you probably aren't going to have any oil left in the engine and dealership won't cover it because they'll claim neglect/negligence on your part.
    2009 Rubicon Unlimited
    Cobra 75wxst, Lightforce Striker 170's, Gobi rack, ACE rock sliders,
    RR XHD front winch bumper with 12000lbs Titan winch and front skid
    OF4WD #5561
    Quote Originally Posted by jeremi View Post
    This revision of Enzo Ferrari's quote holds some level of truth, but trust me when I say that the HP reduction will be felt by the driver and everyone stuck behind him.
    i put a 90 hp tdi in my jeep and i guarantee i would pull away from most 4.0's on this site..
    also 13k on oil is excessive, i am guessing your also using dino oil? i was doing 8k in my truck with synthetic..
    Jun 2010
    pontypool
    Time Online: 3 Wks 4 Days 2 Hrs 55 Mins 54 Secs
    Avg. Time Online: 2 Mins 4 Secs
    Re: Engine Seized on 2009 Wrangle 3.8 L , 78K - options
    Quote Originally Posted by H3lzsn1p3r View Post
    Where did you hear the 3.6 is plug and play. Ive heard the exact opposite.
    Sent from my SAMSUNG-SGH-I896 using Tapatalk 2
    RK 3.5 lift on 37" Toyos
    Lots of other stuff
    OF4WD #6644
    May 2011
    eganville
    Quote Originally Posted by Biggy View Post
    from what I have read and heard they are mostly plug and play
