Results 1 to 7 of 7
Thread: Need some help with axle identity
    Time Online: 3 Wks 6 Days 3 Hrs 57 Mins 57 Secs
    Avg. Time Online: 2 Mins 14 Secs
    A friend of mine has an axle in a 2003 GMC 3500 Van. It looks massive and has Dana stamped on the housing and on the cover. It does not have 4" axle tubes, and it has 12 bolts on the cover. But the BOM # doesn't match anything online. The VIN at the dealer only tells us its a 10.5 with 373 gears. We can't seem to find out any other info for this axle anywhere and I was hoping someone could help me make some sense of it. I've got some pictures hopefully I can figure this out.
    I pushed the any key
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1377970917091.jpg   uploadfromtaptalk1377970953054.jpg   uploadfromtaptalk1377971135209.jpg   uploadfromtaptalk1377971163339.jpg
    98 TJ 34" TSL Super 30/35 e-lockers 488 gears
    89 YJ 4.0L SYE SOA D44/Ford 9" 514/513 gears Detroit Lockers D300 Twin Stick etc etc etc
    Time Online: 10 Mths 3 Wks 5 Days 6 Hrs 18 Mins 14 Secs
    Second generation GM spec D70.
    Thanks Cheyne...think its worth hanging on to?
    If you have the space and it isn't in your way, it's worth keeping. It is not particularly valuable or sought after. I believe it is characterized as a "Super 70"since it is from an 03 and up Savanna Van Those do use adjuster nuts on the carrier bearing instead of shims so they are a bit easier for setting up gears. I couldn't tell you what carrier type that 70 is but a little researching could come up with it, I'm sure. I'm not sure what allows for the "Super" designation other than the adjuster nuts....could be a different carrier and bearing combo...
    the nuclear waste depository
    Time Online: 1 Wk 1 Day 13 Hrs 17 Mins 56 Secs
    do a quick search on "Randy's ring and pinion" Find out how much part support there is. is you can't get a locker or gears I say scrap it
    11 F150 tow rig/ DD
    87 Sami buggy
    99 XJ RIP
    91 XJ RIP
    86 CJ5 RIP
    Quote Originally Posted by BLSXJ View Post
    Yes, that is a handy site for axle parts info for sure. http://www.ringpinion.com/b2c/PartCa...D=3&DiffID=262 - The Super 70 uses standard D70 gears but it looks like the carrier might be a problem...they are only listing a Dana Trac-Loc posi.
    Very helpful link....thanks
