Results 1 to 4 of 4
Thread: Winter Tire Sizes
    Winter Tire Sizes
    My wife's 2011 Chryler T&C Minivan is in serious need of new tires and given the season change and that I have a set of aftemarket rim and tirwes that will fit it I want to put Winters on her stock 16" rims.
    Factory calls for a 235/60/16. They have already been replaced with an AllSeason 225/65/16 by the previous owner.
    I have gotten quotes from tire craft for a 235/60 and a 215/65 tire.
    I have a set of 215/55/16 Winters from her previous car.
    Is going from the suggested 235-225-215/65 to a 215/55 to much of a jump. I'm not sure on tire jumps on this car and normally would not think 2x on a jeep!
    In consideration to the new versious current size comparison.
    Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
    225/65-16 5.8in 13.8in 27.5in 86.4in 733 0.0%
    215/55-16 4.7in 12.7in 25.3in 79.5in 797 -8.0%
    Do this would save 600.00+ dollars!
    Time Online: 2 Wks 3 Days 6 Hrs 35 Mins 8 Secs
    I use the Miata .net calculator for tire comparisons. http://www.miata.net/garage/tirecalc.html
    The white outline will be your stock size and the black inlay is your new tire. With a 235/60 to a 215/55 it doesn't look like any clearance issues but it will throw off your speedo and I've heard of ABS problems, but that could just be using mismatched at the same time.
    Georgetown
    Crappy tire has goodyear snows the correct size at $120 a piece and sell the ones you have.....that's the route I would go.
    27.1 factory versus 25.3 on your snows....there's an inch and a half difference...to much on a minivan IMHO
    http://tires.canadiantire.ca/en/tire...inter/0062373/
    Sep 2012
    Time Online: 9 Mths 3 Wks 2 Days 15 Hrs 1 Min 9 Secs
    Avg. Time Online: 24 Mins 12 Secs
    Don't just factor in tire size difference.
    Also remember that load and speed ratings have a play on vehicles.
    Don't change tire size to save a couple bucks.
