Results 1 to 18 of 18
Thread: Cj5 build up
    Dec 2013
    Time Online: 1 Day 20 Hrs 42 Mins 47 Secs
    Avg. Time Online: 9 Secs
    Cj5 build up
    Picked up a cj 5 last month and going to start giving it a good go over with some mods..it's a fiberglass body 258 t150 with wide track axels..
    So far on the project the mostly everything has been pulled except the engine...the frame had some rot and that has all been welded up..going to try and do this rebuild while leaving the tub on..right now working on cleaning up the frame..be ready for painting but not sure what holds up well..don't want to spend a lot but would like something that will last..any suggestions
    Ohh and I'll start posting pics soon as I figure out how
    Dec 2013
    Dec 2013
ID:	95120Click image for larger version.
ID:	95121Click image for larger version.
ID:	95122Click image for larger version.
ID:	95123Click image for larger version.
    Dec 2008
    Time Online: 1 Mth 14 Hrs 25 Mins 12 Secs
    Avg. Time Online: 2 Mins 31 Secs
    Good luck with the build. My CJ5 took a long time to get where she is now. It is a never ending process.
    07 Commander 5.7L Hemi
    Dec 2013
    BB Code
    Dec 2013
    Thanks to Jim at rock spider for the new bds 4 " lift and goodies that will be going on
    Dec 2013
    G]http://www.jeepkings.ca/forums/attachment.php?attachmentid=95133&d=1390267084[/IMG
    Dec 2013
    some progress
    Jan 2013
    Midland ON
    Time Online: 4 Mths 2 Days 20 Hrs 24 Mins 28 Secs
    Time Online: 3 Mths 2 Days 10 Hrs 5 Mins 50 Secs
    looking good so far!
    Dec 2013
    bit more basically every things out now..going to clean the back end and paint..straighten up some wiring..frame is really solid..no repairs needed at back..im glad
    Dec 2013
    coming along
    some more pics
    Attached Thumbnails Attached Thumbnails image.jpg   image.jpg   image.jpg   image.jpg   image.jpg
    Dec 2013
    I'm thinking about removing the vapour canister up in the rear fender well..anyone have any problems after doing that?
    Dec 2013
    Dec 2013
    Dec 2013
    Havnt posted in a while been busy...but dosnt look like much but the frame has been primed twice then a high build rocker guard on top..lots of prep work..anyways running the new fuel line I decided to use a bit more rubber line than factory..just easier than bending up and over that shock mount which seemed impossible..I also decided to go through the frame a little..going to ad a protector for the rubber on the way in and out of the frame...I would have rather done steel almost to the tank but this is the way it's going to be..anyone see any issues..hopefully no vapour lock or problems
    Dec 2013
    Hopefully this isn't upside down
    Dec 2013
    Next step...install fuel tank
