Results 1 to 8 of 8
Thread: Cherokee XJ sluggish to shift Trans ?
    May 2012
    Brantford ON
    Time Online: 6 Mths 2 Wks 2 Days 10 Hrs 26 Mins 32 Secs
    Avg. Time Online: 16 Mins 8 Secs
    Okay so lately I have been paying more attention to the shifting of the Trans in my 1998 Cherokee XJ ( 4.0, aw4, 3 inch lift and 31's) and it seems a bit sluggish to shift and revs a tad high.
    Example: start from a red light and will go close to 3000 RPM stay for a sec then shift but slowly.
    Around town it's at 2150 rpm and that seems a bit high to me. Feels like it won't up shift. I compared it to the family friends cherokee that's the exact same and theirs shifts like it should and stays around 1200 rpm doing about 60 km/h.
    I have tried adjusting the TV cable but with little to no change in shifts. Fluid looks fine and is at proper level when warm.
    My question is, is there anything I can do to get it to shifter better and faster than it is now?
    Kinda stumped.
    IT'S TWEETER B!TCHEZ
    "PIPPI APPROVED"
    Attachment 91983
    Have you changed out the speedo gear? Mine shifted sluggish after going to 31's as well. I believed it to be the speed sensor sending incorrect info to the ECU due to the larger tire size. Speedo gear seemed to fix the issue and also improved fuel economy as a bonus.
    May 2012
    Brantford ON
    Quote Originally Posted by RBJeepThing View Post
    Nope actually never thought about that. From further research I had considered the TPS as well.
    Now should I upgrade the speedo gear ? Also where could I get it
    Just Jeeps may be able to get it for you just need to know what gear ratio you have.
    May 2012
    Brantford ON
    I have to pop the diffs anyways soon to do a fluid change so I guess I'll find out then ( don't know if PO did a gear swap with the lift )
    Quote Originally Posted by pippilongstocking View Post
    sounds good just pm when you know.
    edmonton alberta
    What transfer case do you got in that Cherokee pip. You could always go to kennys and pull a few speedo gears out to see what colour they are
    I thought life handed you lemons..... who the phuk is throwing them at my head !!!
    May 2012
    Brantford ON
    I have the NP231 command trac in it. What colour should I be looking for,?
