Results 1 to 17 of 17
Thread: 06 Tj rear passenger top shock bolts snapped!
    Mar 2014
    Time Online: 1 Day 4 Hrs 9 Mins 52 Secs
    a little background on the jeep. hardly driven 100 thou kms on her..
    we were doing a 2.5 suspension lift and the when it came to every part on the vehicle it was easy to work with.
    to say that least our luck ran out when i encountered the rear passenger top shock mount bolts. 13mm The bolts ended up snapping when i was trying to wiggle them loose.
    its now dark out so i coulnt get a picture, but the heads sheard off. the stud is still in the upper brace.
    what ive tried:
    -because the jeep also has a small body lift i attempted to stick a pair of vice grips on top of the stud but that didnt work they just kept slipping off.
    -i tried drilling them through so i could potentially use and "EZ out" but after several broken drill bits and only about 1/16 of an inch drilled i gave up after dark.
    right now ive literally drenched them in a special crane penetrating grease so hopefully they loosen over night.
    what im hopefully going to try tomorrow:
    going to heat them up with a torch (propane)(all i have) and see if i can rock them loose with the set of vice grips from the top.
    any suggestions would be great guys thanks in advanced.
    Feb 2013
    Port elgin ontario
    Time Online: 3 Wks 6 Days 9 Hrs 48 Mins 21 Secs
    Avg. Time Online: 2 Mins 15 Secs
    Don't use heat (flame) as gas tank is there ... I would get a colbalt drill bit... And keep drilling it ..... Anyone know the size of bolts tho? As I need soome lol
    OF4WD #7796
    Oct 2013
    Smithville, ON
    Time Online: 1 Mth 2 Wks 2 Days 20 Hrs 9 Mins 55 Secs
    Avg. Time Online: 3 Mins 51 Secs
    if the setup is anything like the XJ (there's space above the welded nut and "some" form of access) punch thru the welded nut and use a wire or mechanics wire to pull thru new bolts/washer from the top side. Then nut from the bottom rather than vice-versa...on the XJ i had enough room to hold the bolt with a wrench
    i just went thru this myself on the XJ:
    originally bolted from bottom, but once they all snapped off i was left with this. punched the broken bolts then taped the bolt to some 12ga wire and pull them thru
    actually, if you have enough room to access the top of the bolt with v-grips you could still run bolt up
    i'd try the cobalt drills first tho if you can save the threads, this is kind of a last resort save
    '99 XJ Sport - Black - BUILD THREAD
    '13 Ram 1500 QC - Black Gold
    Shocker #5
    OF4WD #8158
    Mar 2010
    www.jeepcentral.ca
    Time Online: 3 Wks 5 Days 1 Hr 40 Mins 29 Secs
    Avg. Time Online: 2 Mins 8 Secs
    Jun 2003
    Bowmanville
    Dead
    Time Online: 2 Wks 12 Hrs 45 Mins 27 Secs
    Avg. Time Online: 1 Min 11 Secs
    I replaced the shocks on my 05 LJ yesterday. Its a little late to be telling you now, but I have been soaking those upper bolts with PB Blaster for the past 3 weeks. They all came out, but I had to be VERY careful!
    Sorry about your luck.
    Wounds heal... Chicks dig scars...
    1984 CJ-8 Scrambler (Rust Free California Edition)
    2005 TJ Unlimited
    1946 Willys CJ-2a "Pa2niA" Featured in JPFreek (click me)
    Mar 2014
    Thanks for the replies..
    @whiplash
    You were able to just hammer the bolt trough the threads ?
    How hard were you hitting them ?
    Did you bent the crossmember ?
    Avg. Time Online: 12 Mins 24 Secs
    Rotate 90 and re-drill 2 new holes? I did that.
    Time Online: 8 Mths 3 Days 23 Hrs 9 Mins 33 Secs
    Avg. Time Online: 20 Mins 3 Secs
    I swapped out my 99s last year. I just put the heat to them with a propane torch spun right out
    Cottam, ONT
    Time Online: 4 Wks 1 Day 9 Hrs 30 Mins 51 Secs
    Avg. Time Online: 2 Mins 25 Secs
    The ones on my 99 were beyond saving so I had to cut access holes in my floor to get to the top and ground the tops off. I then put new bolts in and tacked them to the cross member to make life a little easier. Its not ideal but its all I had left
    Essex County Jeep Club
    -1999 TJ "50 Shades of Jeep"
    Midland, Ontario
    Time Online: 3 Wks 6 Days 9 Hrs 26 Mins 28 Secs
    my bolt heads snapped clean off .....drilled and tapped new holes ,had to use an extension on my tap handle though ....good luck
    OF4WD member 7468
    Lanark, ON
    Time Online: 4 Wks 1 Day 21 Hrs 14 Mins 14 Secs
    Avg. Time Online: 2 Mins 27 Secs
    Quote Originally Posted by Quantum_shell View Post
    I did the same thing makes life easier in the future.
    Oct 2013
    Smithville, ON
    no, i hammered out both the remaining bolt AND the welded nut...left me with just an open hole
    used an air hammer. It's not really a cross-member on the XJ, more an added floor support?? but no damage to it whatsoever
    i also had to remove a shackle bolt that had no access to replace a nut, i drilled it out with a few different sized bits until i was able to work it out.
    i couldn't find any over the weekend but something i would have tried first is leftie bits on a reversible drill...drill a pilot and possible the next size up bit will grab and back the bolt out
    Jun 2003
    Bowmanville
    Dead
    Quote Originally Posted by hustler View Post
    rotate 90 and re-drill 2 new holes? I did that.
    genius!!! (wish I did that when I swapped shocks on a TJ years ago.)
    Feb 2013
    Port elgin ontario
    What size of bolts did you use?
    OF4WD #7796
    Me?
    Dunno, I grab a whole bunch of Grade 8 miscellaneous nuts, bolts, washers when I'm at a bigger TSC and keep them in sorted bins at home. I just put something close to stock size in and tightened it up.
    Grade 8 stuff seems to hold up to rust better, even if the strength isn't needed. And, knowing that any bolt you have replaced on your Jeep is Grade 8 means you have good interchangeability in a pinch should something else break.
    Feb 2013
    Port elgin ontario
    Lmao I don't do that .. Lol
    OF4WD #7796
    Mar 2014
    Ok guys figured it out.. I ended up getting a Dremel in there and cut the weld holding the nuts on. In there place I grabbed a could 5/16 x 1.25 bolts and shes all set now .
    Thanks for all the sugestions.
