Thread: Two tj's and a trailer frame!
    Aug 2010
    brampton
    I saw rikkers build thread and uturn calling me out. So here's my trailer build based on the same truck u inspiration.
    The beginning
    The discovery of rot process
    The rot removal
    Stitching the tubs
    Sent from my SGH-I747M using Tapatalk
    Aug 2010
    brampton
    Re: Two tj's and a trailer frame!
    Framing
    Test fit
    The hookup
    Some donated parts
    A huge thanks to bullwinkletj, Redxj, mudrodent and uturn. All of you have contributed to this build.
    Aug 2010
    brampton
    New skin
    Nov 2011
    St. Thomas
    Avg. Time Online: 33 Mins 32 Secs
    Awesome!
    Time Online: 3 Mths 2 Days 10 Hrs 5 Mins 47 Secs
    looks great!
    Aug 2010
    brampton
    Thanks guys. The tubs were buried in snow when I bought them and the amount of rot in the one tub had me down for a bit. Then I just said Fawk it, push forward and figure it out. I formed the corners yesterday once I figured out how I was going to bend the sheet evenly. I rigged my own press using a large rachet strap, a 2x6 piece of wood standing on end and a propane torch.
    I measured from the center of the tailgate to the far side of the gas fill hole. Precut my sheet then clamped it to body. Stood the 2x6 vertically against the sheet. Then wrapped the rachet strap around the tub with the buckle on the wood. Slowly tighten the strap and add heat to the steal as the wood works its way around the corner.
