Results 1 to 20 of 27
Thread: 95 grand cherokee lerado broken down need help trany just died
    Mar 2014
    Southwold, Ontario Canada
    Time Online: 1 Wk 5 Days 23 Hrs 44 Mins 50 Secs
    Angry 95 grand cherokee lerado broken down need help trany just died
    Ok everyone I have 95 ZJ with a 42re trasmission that has just lost every gear except 1st gear I am on Powers Rd. just outside St. Thomas Ontario looking at either help figuring out what has happened to mine ( jeep is my daily driver ) and or a replacement for a good price and close by. you can reach me here but best off texting or calling me direct at ( 613 ) 661-8824. the sooner the better
    Jul 2009
    Time Online: 1 Wk 1 Day 22 Hrs 13 Mins 34 Secs
    Avg. Time Online: 44 Secs
    Just seeing this. I presume you got home by now?
    Ron
    '05 GMC Highrider ZR2
    OF4WD#5914
    Mar 2014
    Quote Originally Posted by Bow_Tied View Post
    Ya we got home with a borrowed car my jeep is still at my dad's on Powers Rd and it will not shift out of first when in drive or when I manually put it in first and shift up first and reverse is all I have
    Jul 2009
    Does it stay in 1st or shift to neutral? Just wondering if it is in limp mode and a battery disconnect would reset it. Though I thought limp mode was second gear...
    Sent from my shoe phone.
    Mar 2014
    Time Online: 10 Mths 3 Wks 5 Days 6 Hrs 28 Mins 58 Secs
    - Check all of the fuses to make sure none are blown. There might be a PCM circuit for tranny control that popped a fuse and could put it in limp mode.
    - Make sure the TV cable didn't break.
    - Check codes. The governor pressure solenoid can be an issue on the 42RE which, when it screws up, I believe may affect the ability for the trans to upshift.
    Mar 2014
    I just tried the battery disconnect and it didn't seem to help but not sure if it is in first or second for sure but at 35 km /hr I am hitting 2500-3000 rpm with no hint of a shift no mater what I do. I am going to check the fuses next and go from there and check my service manual for any ideas as I now have access to it when I am at my jeep.
    Mar 2014
    checking that next
    and this
    as for the code it might not throw a code just after doing the battery reset??
    Thanks for your ideas
    Quote Originally Posted by ferretman View Post
    You might be right but if the conditions that triggered the code are still present after the reset, the code will be triggered again.
    Mar 2014
    ok fuses are all visually good (all that I could find) just took it for another test run after doing the battery reset and now have a bit better idea of what it is doing. ok on test drive it does seem to be in limp mode what feels like first to me but it might be second because I can downshift into first and it does seem to shift into second if I go from drive to second and to first, but if I start out in first and shift to second there is no change and I have nothing above second from what I can tell but this is my first 4x4 and first jeep.
    The TV cable seems fine and in one piece and I just adjusted it again just to make sure it is right . As for the codes I cannot seem to get it to give me a code unless I am doing it wrong. From what I understand it is off, on, off, on, off, on then leave it on but I get no code through the engine light or overdrive light.
    I am willing to try just about everything.
    yes fluid level is good and fluid is clean.
    Dec 2009
    burlington
    Devilish
    Time Online: 1 Wk 3 Days 12 Hrs 36 Mins 58 Secs
    Avg. Time Online: 51 Secs
    Check the TPS?? if the spring inside is crapped out or the points are messed up. I had my GC stuck in 1st / 2nd gear and it was cause of a faulty TPS. My code ready could not read the voltage but a better scanner could and it showed the TPS not sending out proper signals.
    Birdman
    ditch the bitch! let's go muddin'
    Mar 2014
    Quote Originally Posted by birdman View Post
    ummm sorry still working on the proper terminology whats is the TPS and where would I locate it?? sorry for sounding like a newbie
    Port Elgin
    Time Online: 3 Mths 3 Wks 3 Hrs 8 Mins 9 Secs
    Avg. Time Online: 9 Mins 8 Secs
    i believe he is talking throttle position sensor, to me it sounds like a crapped out valve body/solinoid, fluid is still good and its in limp mode, try to get it someplace where you can work on it.
    KUSS
    Stupid Fukin Nature
    OF4WD# 2660
    Mar 2014
    Quote Originally Posted by biohazard View Post
    thank you I did figurethat much out and have just located it but not sure how to test it or anything at this point.
    Port Elgin
    find someone with a good code reader. when a solinoid goes its codes like low voltage or high voltage to, i dont know if an off teh shelf CT scanner will decifer the PCM codes to the tranny or just throw a generic trans trouble code. Just went through this with a 46re got lucky and only needed a new valve body but my scaner didnt give me the nessessary info needed a snap-on on with proper dodge softwear
    ^ I don't think the key cycling to retrieve codes works on a 95 ZJ.
    Mar 2014
    anyone have a good code reader I could borrow that is close by??? I don't even have a volt meter to use right now
    Mar 2014
    I just tried to get the code and I did get it to work and believe it is coming up with code 12 ( one flash, pause, two close flashes and then it just repeats ) Now to look up what code 12 is.
    Jul 2009
    If I remember code 12 is battery disconnected. :/ it does sound like limp mode to me. Good luck.
    Mar 2014
    yes you are right code 12 is battery disconnect but it didn't throw a code when it messed up
    still trying to narrow it down but seems to be limp mode to me as well
