Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: 95 grand cherokee lerado broken down need help trany just died
  1. #21
    Mar 2014
    Southwold, Ontario Canada
    Time Online: 1 Wk 5 Days 23 Hrs 44 Mins 50 Secs
    just tried disconnecting the TPS and it ran like hell almost died but made no change to the transmission and it threw error code 12, 24, 55
  2. #22
    Owen Sound
    Time Online: 1 Mth 1 Wk 2 Days 6 Hrs 8 Mins 46 Secs
    Avg. Time Online: 3 Mins 14 Secs
    I had a similar problem a couple zj's ago, had 2nd and 3rd only, was a solenoid in the tranny,
    94 zj, 6" long arm lift, 35's
  3. #23
    Mar 2014
    Wink Daily driver still DOA
    Update my daily driver is still doa with a second problem on top of the tranny now it died when I was limping it home and ended up flat towing it home. I will give more details later on on the new problem
    now for the good news! I found myself a replacement tranny and guess what it came with a whole 96 jeep Grand Cherokee Laredo Wrapped around it!!!!!! and I drove it home! Big Score!!!! a ton of spare parts now
ID:	96834Click image for larger version.
ID:	96835Click image for larger version.
  4. #24
    Mar 2014
    update: daily driver now will run again with new ignition coil but still has transmission problem and jeep is back home and have now got a parts jeep that I might be fixing up to drive as well ( found a transmission with a whole jeep wrapped around it)
  5. #25
    Mar 2014
    Quote Originally Posted by biohazard View Post
    i believe he is talking throttle position sensor, to me it sounds like a crapped out valve body/solinoid, fluid is still good and its in limp mode, try to get it someplace where you can work on it.
    I now have it home to work on it but slow going ( garage not ready )
  6. #26
    Mar 2014
    - Check all of the fuses to make sure none are blown. There might be a PCM circuit for tranny control that popped a fuse and could put it in limp mode.
    - Make sure the TV cable didn't break.
    - Check codes. The governor pressure solenoid can be an issue on the 42RE which, when it screws up, I believe may affect the ability for the trans to upshift.
    ok I have the transmission pan off and transmission drained and filter out was thinking about swapping just the governor pressure Solenoid from the parts jeep before I do the transmission swap seeing as I will have to pull the pan and drain it to do the swap anyway . any thoughts whether it will work or not??
    __________________________________________________ ________________________
    I have no problem buying the beer but need a ride to the beer store.
  7. #27
    Mar 2014
    well solenoid is in pan back on with new filter installed filled fluid run through the gears. once checked fluid and repeated until level looked right. pulling it out into the driveway in the morning and letting it warm up for about 20 minutes going through the gears and checking the level before the road test. Any thoughts or suggestions are welcome. But anyway now that my jeep girl isn't under the jeep with me any more it is time for bed. Good night all.
