Thread: JKU homemade HiLift mount
    Mar 2013
    Georgetown
    Time Online: 1 Wk 2 Days 17 Hrs 23 Mins 53 Secs
    Avg. Time Online: 47 Secs
    Hi guys,
    Just waiting for the paint to dry on my new homemade bumper so I thought I'd show what's been keeping me busy.
    I saw a hilift mount from a company called Jeepswag and fell in love with them........but, I'm very cheap, so I figured I'd just save my money and make my own.
    Whipped these up in an afternoon and I think they turned out great. Jack is in there solid, I've hung my entire weight off them and wiggled around, just a bit of flex in the actual "i" beam of the jack itself!
    Thanks for looking and if anyone wants me to post a photo of my cardboard template (it'll get you close), just ask.
    Dan
    OF4WD member #7498
    Oct 2013
    Smithville, ON
    Time Online: 1 Mth 2 Wks 2 Days 20 Hrs 9 Mins 55 Secs
    Avg. Time Online: 3 Mins 51 Secs
    Damn, you're on a roll with finished projects!!!
    another well done job sir!!
    '99 XJ Sport - Black - BUILD THREAD
    '13 Ram 1500 QC - Black Gold
    Shocker #5
    OF4WD #8158
    Avg. Time Online: 1 Hr 4 Mins 31 Secs
    mounted high up .is it easy to get at standing on the ground
    Avg. Time Online: 28 Mins 55 Secs
    Need better pics of the brackets and how they attach to the cage...I need to find a decent way to mount a "Smashy Smashy Face Breaker Finger Eater"...
    Mar 2013
    Georgetown
    @ whiplash......thanks man, I've been wanting to do these for a while. I gave the bedliner you recommended a try and it came out pretty nice! Good call!
    @ Piratexpress1369a.....The turndown bar in the rear cargo area isn't that far from the back so I haven't had any problems getting to it yet....I'm also 6'4"........
    @ Jeff......I'll try to get out there later and grab some pics of the mounting stanchions.
    Aug 2010
    brampton
    Does this interfere with the soft top brackets at all?
    Sent from my SGH-I747M using Tapatalk
    Mar 2013
    Georgetown
    it might, but I'm not sure....the one I copied is supposed to work with the factory soft top (you just have to remove the jack itself for each up and down of the top), but I don't have a soft top so I can't say for sure if mine does.
    Mar 2013
    Georgetown
    This is for Jeff and anyone else who is interested. The picture shows the bracket mounting at the top of the angle bar of the roll cage. There is an existing M8(not 100%) bolt on each side at the top that is used to connect the rear part of the stock cage to the backseat area. It is the top bolt shown. Below, aft and angled out of it, there is an unthreaded stanchion that, happily, accepts a 1/2 x 20 tap. I threaded the hole (its the same one that the rear seatbelts attach to) with the hardtop on, with only a little difficulty.
    I then had to slice and bend the mating surface of the bracket to get it to fit on the holes properly, after that it was just a few heat-bends and voila, hi-lift mount.
ID:	97220Click image for larger version.
    Mar 2013
    Georgetown
    @ dft.....I see you're in brampton, if you go to a BAJA meet or the Milton tuesday nights you're welcome to have a look and see if it clears.
    May 2012
    Flamborough
    Time Online: 1 Mth 1 Wk 3 Days 19 Hrs 52 Mins 36 Secs
    Avg. Time Online: 3 Mins 21 Secs
    looking good man!
    2012 JKU Sahara, SD HP60 Front, GM 14 Bolt shaved rear, 5.38s, locked/Spooled, 4 link front 3 link rear, Oris, TR Double Beadlocks, 42" tsl sx2, PSC Full Hydro, D3 bumpers, D3 skids, D3 Rock Rails, D3 Cage, and lots more...
    OF4WD #5252
