Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: Our Toy Hauler Build
    May 2010
    In Niagara, closer to Hamilton
    Time Online: 4 Mths 3 Wks 5 Days 12 Hrs 8 Mins 1 Sec
    Avg. Time Online: 12 Mins 4 Secs
    39' RV trailer, gutted by fire and rebuilt from the ashes! Been a crapass summer and missed out on a lot of wheelin but hey....next season we'll be rockin in style
    This is what we started with. It was a high end luxury 5th wheel with all of the bells and whistles. Much of which we ended up removing because it was either destroyed or unnecessary for our intended use of the trailer.
    What saved this trailer was how it was constructed. It has a huge 10" I-beam chassis and the structure was framed with aluminum tubing with steel roof trusses and fiberglass exterior walls. Virtually nothing in the main structure is wood. Repairs and modifications were relatively straight forward and there isn't too much that can be water damaged as a result. A much better built trailer than many...and light years ahead of what we had prior which fell apart before our eyes.
    Some things were saved and restored, most was junked. Slides were removed and cut in half.
    This is what it looked like when we brought it home. It looked good on the outside but was a write-off inside:
    Sent from my GT-I9000M using Tapatalk 2
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1410476074094.jpg   uploadfromtaptalk1410476248000.jpg   uploadfromtaptalk1410476322744.jpg   uploadfromtaptalk1410476365460.jpg   uploadfromtaptalk1410476413268.jpg
    I don't have an attitude problem, you're just an asshole!!
    2004 Grand Cherokee Columbia edition
    OF4WD#6687 & 4928
    Fine
    Time Online: 5 Mths 1 Wk 4 Days 13 Hrs 49 Mins 29 Secs
    Avg. Time Online: 13 Mins 19 Secs
    Looks sweet
    6#DAERTER
    01 TJ
    May 2010
    Re: Our Toy Hauler Build
    Old trailer getting chopped for flat deck.
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1410477868097.jpg   uploadfromtaptalk1410477907829.jpg
    May 2010
    Kitchen slide chopped, cleaned, painted and ready to be installed. There was mostly smoke damage done to this slide. Fire damage was mainly on the ceiling and upper walls.
    Fridge was saved, only needing some parts replaced. Panels were sanded and painted black but saved.
    Slide two (dinnette) didn't fare out as well.
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1410478064263.jpg   uploadfromtaptalk1410478206783.jpg   uploadfromtaptalk1410478395163.jpg
    May 2010
    Trailer is now in a usable state, will eventually get caught up as I find the pics in proper order
    Time Online: 3 Mths 2 Days 10 Hrs 5 Mins 38 Secs
    awesome work you two!
    May 2010
    Thank you Cheezie
    But I also have to say thanks for all those that helped us. We wouldn't be as far as we are without all of ya's
    May 2010
    Slide out openings were shortened and moved forward as well as the entry door. The living space is being shortened. Slide out hydraulics also had to be cut out and moved to support new slide locations. That was a lot of work.
    New shortened slides installed and back portion is now ready to be chopped!
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1410479809430.jpg   uploadfromtaptalk1410479928256.jpg   uploadfromtaptalk1410479971255.jpg   uploadfromtaptalk1410480029239.jpg
    May 2010
    Back cap removed and set aside to be Modded.
    Back half cut and forklift in motion!
    Axle removed and welded to new roller location. Cheyne will have to jump in and put better build details into thread. Im just the camera girl and painter lol
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1410481039038.jpg   uploadfromtaptalk1410481064326.jpg   uploadfromtaptalk1410481085515.jpg   uploadfromtaptalk1410481104151.jpg   uploadfromtaptalk1410481134867.jpg
    May 2010
    Flat deck removed from old Hauler and welded to new build.
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1410481403165.jpg   uploadfromtaptalk1410481546512.jpg
    May 2012
    Burlington, ON
    Time Online: 6 Mths 2 Wks 2 Days 10 Hrs 18 Mins 21 Secs
    Avg. Time Online: 16 Mins 12 Secs
    Gee, that kid in the pics looks awfully familiar lol
    one hell of a Build you two Pulled off Sug! and only looking better and better now!
    was a great experience getting to help out and learning a little Much Appreciated!
    IT'S TWEETER B!TCHEZ
    "PIPPI APPROVED"
    Attachment 91983
    May 2010
    After hours upon hours of bleaching the soot off everything, the painting and sanding begins!
    We were able to save all the oak in the bedroom. Many hours of sanding and a few coats of clear stain. All of the veneer/lamented Crap had to be sanded and painted.
    Sink was saved in bedroom vanity. Some sanding and a few coats of Tile Doc and it looks like new. Counter top was pretty damaged so it got a few coats of mystic copper Krylon paint and clear coated.
    Walls starting to be replaced and counter built and sink installed. The whole center of the trailer was trashed where the fire started.
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1410481829740.jpg   uploadfromtaptalk1410482069445.jpg   uploadfromtaptalk1410482295502.jpg   uploadfromtaptalk1410482507587.jpg   uploadfromtaptalk1410482564103.jpg
    May 2010
    Back cap getting closer
    New frame welded and being fitting into place.
    May 2010
    Back cap Modded and finally put on....no more tsunami in the trailer...well on partially
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1410483009286.jpg   uploadfromtaptalk1410483071735.jpg
    Time Online: 2 Yrs 1 Mth 3 Wks 3 Days 21 Hrs 34 Mins 42 Secs
    Avg. Time Online: 1 Hr 4 Mins 44 Secs
    that is a hell of a job..what was wrong with the old trailer?
    May 2010
    A few days later and the tsunami floods, the back window got installed.
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1410483196664.jpg   uploadfromtaptalk1410483237279.jpg
    May 2010
    Filling in section under back cap.
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1410483354715.jpg   uploadfromtaptalk1410483500571.jpg
    May 2010
    Now to make sure Princess fits
    Sorry, no pics of all the tedious stuff. The whole trailer had to be fully rewired, plumbing redone and gas lines done. Hydraulic's for the slides had to be redone after their move. Cheyne can elaborate on that stuff.
    May 2010
    Quote Originally Posted by pippilongstocking View Post
    Matt, you were amazing help! Thanks a bunch...now lets finally go wheelin
    Still lots to do but its all internal stuff now. More walls, more paint, dinnette/table built, pantry and cupboards need to be built. Still need furnace and a/c units.....hopefully weather warms up for the end of September trip
    May 2010
    Quote Originally Posted by Piratexpress1369a View Post
    The old trailer had major structural damage from years of rot. It looked good from the outside but the entire structure, which was built with toothpicks, popsicle sticks and bubble gum, was toast. There was literally nothing to try and repair or rebuild. We reluctantly decided that it was not worth messing with.
    Once this build is done, the old one will be parted out or sold as it sits. All appliances, Roof air and furnace work great and are for sale.
