Thread: Just Jeeps "Ballin To Brawlin" Jeep JK Build
    Brief Background:
    We were initially approached by a true "vehicle enthusiast" to change his ballin' 2dr JK with big rims and tiny tires into something a little more Jeep like. With his budget set in place we got to specking out what would be required to meet his expectations. This customer continuously makes waves in the custom car culture in Ontario and is known across North America for his charitable car shows. I know some of the mods may not be everyone's cup of tea but everyone should really sit back with an open mind and appreciate this for what it is. An incredible build that I think no one including us would hesitate to park in our garage or take out on the street or the trails to enjoy.
    The Customers Requirements:
    1. Clear 40" Tires
    2. Remain Close To Stock Handling
    3. Remain Reliable
    As you can see not really that easy of a task considering on the tire size choice. It's pretty amazing what the customer and our shop with the help of others in the industry has accomplished with this build considering everything is pretty much standard issue non custom fabricated. We did along the way add our own little touches just to improve on an already existing product but other than that most of the parts can be purchased over the counter as you see them. It really opened our eyes as a shop as to what is currently available out there in the market and how well things are engineered these days to work together. On to the exciting part the build list!
    Build List:
    Teraflex 6" LCG Long Arm Suspension Kit
    Teraflex LCG Speedbump Bump Stops
    Fox Pre-Runner Custom Spec'd Remote Reservoir Shocks
    Front Currie Rock Jock D60 With Yukon Zip Locker, 35 Spline Chromoly Shafts, 5.38 gears and Yukon Locking Hubs
    Rear Currie Rock Jock D60 With Yukon Zip Locker, 35 Spline Chromoly Shafts and 5.38 gears
    (Assisted By Jim@Rock Spyder 4x4)
    PSC Stage 4 Hydro Assist Firm Feel
    Derale Cooler
    Forgiato 24x13 5x5.5 Wheels
    Toyo Open Country MT 40x15.50R24
    ARB Deluxe Air Compressor
    ARB On Board Air Kit
    Klein Train Horn Kit With Remote Tank
    Rugged Ridge Front CV Driveshaft
    Rugged Ridge Rear CV Driveshaft
    Poison Spyder Front Brawler Lite Bumper
    Poison Spyder Rear Rock Brawler II Bumper With Tire Carrier
    Poison Spyder Rear License Plate Mount With LED
    Poison Spyder Brawler Brawler Rockers
    Poison Spyder Front Crusher Flares Regular width
    Poison Spyder Rear Crusher Corners
    Poison Spyder Rear Crusher Flares
    Poison Spyder Hood Louver
    Poison Spyder Trail Cage Kit
    Ripp Stage 2 Supercharger
    B&M Tranny Cooler
    AEM Wideband AFR
    AEM Boost Gauge
    Magnaflow RC Full SS Exhaust
    Diablo Intune Tuner
    Rigid 50" E2 Light Bar Combo Pattern
    Rigid 50" E2 Light Bar Combo Pattern (Yes Two)
    Poison Spyder Dual 50" Light Bar Mount
    Rigid 20" E2 Light Bar Spot Pattern
    Rigid 20" E2 Light Bar JK Hood Brackets
    Rigid Dually Pair Spot Beam Pattern
    Rigid D Series A-Pillar Mounts
    Rigid 10" E2 Light Bar Flood Pattern Amber
    TMR Shock Brackets (Used For Light Mount)
    TMR Zip Tie Tabs
    Painless Wiring Roll Bar Mounted Custom Switch Panel
    JW Speaker Front Headlights
    JW Speaker Fog Lights
    Lighting to be Continued....
    Off Camber Fabrications Roof Rack
    Off Camber Fabrications Roof Rack Basket
    Off Camber Fabrications Hi Lift Mount
    Rugged Ridge Engine and Tranny Skid Plate
    Rugged Ridge EVAP Canister Skid Plate
    Rugged Ridge Muffler Skid Plate (Muffler Deleted Used To Protect Air Accessories)
    Mastercraft Baja RS Adjustable Driver Seat
    Mastercraft Baja RS Adjustable Passenger Seat
    Mastercraft Seat Adapters (Retain Factory Brackets)
    Warn Zeon 10lbs Winch With Synthetic Line
    Hi-Lift Extreme Jack
    AEV Hawse Fairlead License Plate Mount
    Where Are We At?
    So I'm sure the question is where are we at with this build since the photo at the top shows what looks like a completed build. We are basically at the final stages of final assembly. I figured it would be much better to slowly feature each part of the build after it's completed so we could share what worked what didn't work and what we would change if anything. Feel free to ask questions as I am sure many of you have some and stay tuned to this thread to see the process of building this monster!
    Adrian
    120 HARRY WALKER PKWY NORTH, UNIT 2, NEWMARKET ON
    Time Online: 2 Wks 23 Hrs 30 Mins 30 Secs
    Great looking spec sheet, look forward to following this build!
    TMR CUSTOMS - THE BRANDS YOU WANT FROM THE GUYS YOU TRUST!
    120 Harry Walker Pkwy N, Newmarket ON, L3Y 7B2 - www.tmrcustoms.ca - 905 235 8671 - sales@tmrcustoms.com
    Oct 2013
    Smithville, ON
    Time Online: 1 Mth 2 Wks 2 Days 20 Hrs 9 Mins 55 Secs
    Avg. Time Online: 3 Mins 51 Secs
    with all that lighting and OBA, might i suggest having a look at a couple of sPod modules??
    Looks like a killer build!!
    '99 XJ Sport - Black - BUILD THREAD
    '13 Ram 1500 QC - Black Gold
    Shocker #5
    OF4WD #8158
    Since you already acknowledged that you knew this was coming...
    Everything looks cool until I see the tire and rim choice...and the huge pile of LED light bars. I realize these things are great for car show rides so I understand the sentiment. Just a shame to see all of that impressive hardware on a show vehicle.
    But don't let my crusty ass get in the way of a good build thread. lol
    Apr 2013
    Time Online: 1 Mth 19 Hrs 36 Mins 11 Secs
    Avg. Time Online: 2 Mins 32 Secs
    This is a very cool build thread coming up. Now I was under the impression the pic above was a rc type toy and not an actual jeep.
    Question: Is the picture above the jeep that is being build or is it a toy/model of the one being built?
    Don't ask me cause I don't know.
    Quote Originally Posted by Whiplash View Post
    SPOD unfortunately wont meet our requirements. Also the fitting of the brain and switches is another issue with future plans.
    He wants us to take him wheeling when it's complete. I'm sure after one trip on the current wheel and tire setup he may change his mind to something a little bit better off-road. My suggestion is two sets of wheels and tires for the two purposes show and off-road. When he first came in I told him we were not interested in building a strictly show vehicle that i would make sure if he wanted to go off-road he could beat on it and it would be capable. He owns a wheel and tire company so part of the rim and tire choice currently reflects that.
    Quote Originally Posted by farookismail View Post
    It is the actual Jeep.
    Time Online: 3 Mths 2 Days 10 Hrs 5 Mins 50 Secs
    that looks awesome... great job. I am looking forward to more pictures of this beast.
    Time Online: 2 Yrs 1 Mth 3 Wks 3 Days 21 Hrs 34 Mins 42 Secs
    Avg. Time Online: 1 Hr 4 Mins 43 Secs
    nice build for sure
    ok ok i'll start updating..lol
    So if you have not read the above the Jeep came in to our surprise with 24" rims and low profile tires and the rare but not what we are after European bumpers. In our opinion not what the Jeep thing is all about. It is true we do appreciate everyone's tastes but lets be honest these are 4x4 vehicles they should stick to the ideas behind 4x4'ing. Upon discussing the final goals of this build it was decided to use Poison Spyder for all the armor/body work where possible.
    We chose to test fit everything before the customer delivered the parts to his powder coater. This allowed us to make any modifications required before final painting such as adding the light brackets and zip tie tabs to the front bumper from @TMR. To our pleasant surprise the build quality of the Poison Spyder stuff required little to no modification whatsoever to fit the contours of the JK body.
    i saw that green one when i stopped by a few weeks back ..dam that paint was bright green
