Results 1 to 17 of 17
Thread: Titan Winches
    Sep 2003
    North Coast B.C
    Time Online: 9 Hrs 15 Mins 20 Secs
    Titan Winches
    Bought a Titan winch TW12 in 2011 has worked awesome for me!
    I recently ran into a problem with my wireless plug in as one of the male ends have broke off, due too corrosion.
    I phoned Titan winch only to find out they are no longer in business and are switching company's. They looked for the part I needed and had none, pretty much said I am out of luck and hope I find the parts im looking for.WTF?
    Anyways could anyone help me find this part, would any store work? I am from a small town with limited access to the big stores. Thanks Click image for larger version.
ID:	99566Click image for larger version.
    Just because I slept with you last night. Does not mean i will take you for a ride in my Jeep today!
    Silly girls..... Jeeps are for Boys
    J E E P = Just Empty Every Pocket
    Its not a Jeep.... If there is not something wrong with it
    Time Online: 3 Mths 2 Days 13 Hrs 5 Mins 40 Secs
    Avg. Time Online: 7 Mins 35 Secs
    I have seen where people have switched the plug to a 4 prong plug. Same one you would use on a trailer, easy to install, easy to get.... most crappy tires, P.A.
ID:	99567Click image for larger version.
    I believe this would work for you.
    Cambridge, ON
    Time Online: 6 Mths 1 Wk 3 Days 8 Hrs 38 Mins 10 Secs
    Avg. Time Online: 15 Mins 37 Secs
    Corrosion on these winches is not uncommon.
    I used about pictured item to fix my winch plug on a Superwinch
    1952 Jeep M38 project
    Sep 2012
    Time Online: 9 Mths 3 Wks 2 Days 15 Hrs 4 Mins 23 Secs
    Avg. Time Online: 24 Mins 5 Secs
    Buddie had a problem like that..... Tmr hooked him up with a new one.... Than we put it in the cab so it wouldn't happen again
    Quote Originally Posted by Dill the thrill View Post
    lol
    I wouldn't spend a bunch of money on a fancy plug cause your Titan is likely near its expiry date. Just use a cheapy trailer plug like Cheezy said
    Nov 2011
    St. Thomas
    Avg. Time Online: 33 Mins 22 Secs
    Re: Titan Winches
    Quote Originally Posted by Clipper View Post
    That would be me and it wasn't TMR that hooked me up. It was Titan, but I have a feeling I got the last one...
    But yes I did mount it into my dash for convenience and to avoid such problems from happening again.
    No to winch someone, I don't even have to get out to plug in my wired or wireless remote. All their mess and fuss. I just drive and operate the winch lol.
    Avg. Time Online: 1 Hr 4 Mins 23 Secs
    overkill do you have pic of that setup
    Nov 2011
    St. Thomas
    Re: Titan Winches
    Quote Originally Posted by Piratexpress1369a View Post
    No but I'll take some.
    cool
    selkirk ont
    Time Online: 1 Yr 3 Mths 2 Wks 5 Days 10 Hrs 10 Mins 51 Secs
    Avg. Time Online: 38 Mins 55 Secs
    had the same problem this spring, duncan and jeannie gave me a replacement no charge
    WHAT WOULD MACGYVER DO?
    Aug 2010
    brampton
    Avg. Time Online: 8 Mins 14 Secs
    Re: Titan Winches
    lol
    Did this to mine, still going strong. Word of advice, put the plug on the side of the control box and seal off hole where the old one is. That will help keep water out.
    Sent from my SGH-I747M using Tapatalk
    Nov 2011
    St. Thomas
    Re: Titan Winches
    Last pic is of the wire coming out of the side of the box. I used 4 wire trailer wire that comes in round casing and a grommet to see the box.
    The rest should be pretty self explanatory but feel free to as any questions you want.
    Attached Thumbnails Attached Thumbnails uploadfromtaptalk1414602608721.jpg   uploadfromtaptalk1414602749526.jpg   uploadfromtaptalk1414602708347.jpg   uploadfromtaptalk1414602658371.jpg
    well that works ..cool thanks
    Time Online: 1 Yr 5 Mths 2 Wks 1 Day 17 Hrs 52 Mins 5 Secs
    Had a winch I lost the remote for so I just wired up in cab controls. Just run 3 wires to the cab from where the pins on the winch control plug go. One will be powered full time, I put an on/off switch on that, then I put a momentary spdt (on/off/on) switch on the others with the line out from the first switch the the center pin of the second. Even now that I have a remote the only thing I have ever used it for was spooling the rope after cleaning.
    Avg. Time Online: 28 Mins 52 Secs
    Titan Winches
    ^ what he said. I added in cab controls this year and haven't pulled the remote out since. The only thing I can add to that is some winches require more than 3 wires to be run as they switch both power and ground to the solenoids at the same time. Not sure why but that's the way some are designed.
    ^ X eleventy. I have used a winch remote since I can remember.
    Sep 2003
    North Coast B.C
    I wish I was in time to get a replacement LOL Shit out of luck for me.
    thanks for all your help guys and if I have any more problems hooking it up I will be back CHEERS!
Tags for this Thread
