Page 1 of 15 123456789101112131415 LastLast
Results 1 to 20 of 281
Thread: 1 tonning JK's
    May 2012
    Flamborough
    Time Online: 1 Mth 1 Wk 3 Days 19 Hrs 52 Mins 36 Secs
    1 tonning JK's
    Hey guys a lot of you know me or have wheeled with me in my white JK!
    Been in the game a while and build all the time but that is for another discussion this thread will be to share some insite for all us canadians... In the states its very common for guys to one ton their jks with junkyard axles!
    This is a conbined thread as both our jeeps are getting built so ill toss it all in one!
    Vehicles:
    2012 JKU Sahara 4" Evo coils, Custom arms (3link front/rear), Custom steering, 40-42" tires, 2007 HP60 Superduty, 2002 AAM 14bolt,
    2009 JKU Sahara 14" Coil overs, Custom arms (3link front/traingulated 4 link rear), Custom steering, 44" tires, 2004 HP60 Superduty, 2002 AAM 14bolt,
    Axles:
    2007 HP60 Sueprduty front, Currie unit bearing with 52 tooth abs tone ring and JK abs harness, Yukon 35spline manual hubs, 35 spline shafts inner and outter, yukon U-joints, 5.38s, grizzly locker, Artec truss with 3 link mount, Custom highsteer arms, 8x6.5 pattern, Ford brakes,
    2002 HP60 Superduty Front - Same parts roughly...
    2002 AAM 14 Bolt, 5.38s, air locker, disk brakes, custom made ABS tone rings pressed onto hubs using stock JK abs harness, Artec truss, 8x6.5 pattern, chevy brakes,
    These axles are pure beef and will handle everything we plan to throw at them when done! The superduty 60s are MASSIVE on the 2007 housing guys are running 2.5ton rockwell shafts and u joints they are so big just to give you perspective...
    Both the jeeps when complete will be turn key like factory no lights on the dash... ABS, Traction control, Cruise control everything will work as though the stock axles are under the jeep..
    Both jeeps will be getting a lot more work then just axles but I only plan to actually document the axles for guys on here who ever plan to go bigger someday!
    The best part about the build is the plan from what we calculated will be getting both tons under the each jeep for under $6000 a jeep. Now if you go look at a Dynatrac pro rock 60 thats $12,500 canadian for one axle, look at Currie rock jock its a little less and so on... so to do both and have it run as though nothing was changed for half the price of one brand name is an excellent goal to strive for!
    Stay tuned for pics and updates as we go, This will be a many month long build as we are very busy with everything else so I will do my best to stay on top with pics and info!
    Cheers
    2012 JKU Sahara, SD HP60 Front, GM 14 Bolt shaved rear, 5.38s, locked/Spooled, 4 link front 3 link rear, Oris, TR Double Beadlocks, 42" tsl sx2, PSC Full Hydro, D3 bumpers, D3 skids, D3 Rock Rails, D3 Cage, and lots more...
    OF4WD #5252
    May 2012
    Flamborough
    1 tonning JK's
    This is the 2007 super duty front hp60
    This is the 2004 hp60 ready for blast!
    Mar 2013
    Georgetown
    Time Online: 1 Wk 2 Days 17 Hrs 55 Mins 32 Secs
    Avg. Time Online: 47 Secs
    Yaaaaaaaaaaaaaaaaaaaaaaaaaa! Awesome! This is exactly the information (from a reputable source, no less) that I was looking for.
    OF4WD member #7498
    May 2012
    Flamborough
    haha yeah I will try and keep stuff updated will be a few month process as we are really busy in the shop with builds so I will do my best!
    May 2012
    Flamborough
    Some Front end Info:
    99-04 Ford HP60 Axle Leaf Sprung F250,350
    Axle listed by: 248 or Std. (248mm = 9.75" Ring Gear)
    Tube Diamter - 3 1/8"
    Tube Thicknes - 3/8"
    Ring Gear - 9.75" Dia.
    Inner shafts - 35 spline
    Stub Shafts - 30 spline
    U-Joint - 1480 (SPL 55) Allows for 38* of turning Measures 4 3/16" Across cups
    WMS - 72"
    2005+ Superduty HP 60 Coil Sprung F250,350,450,550
    Axle Listed by : 256 - Which is Ring gear size in mm (256mm =10")
    Tube Diameter - 3.75"
    Tube Thickness - 1/2"
    Ring Gear - this seems to vary from one to another from what i have read they range from 9.75" to 10" people came out with a nick name saying the Super60 has a 10" ring gear BUT the "Super60" 10" ring gear WILL fit in the 99-04 housing for better contact area and strength so not to worry we will run 10" in both
    Inner shaft - 35 spline
    Stub Shaft - 35 Spline
    U-Joint - 1550 (SPL70) Measure 5" Across cups 43* turning (Although some axles did come with 1480 Ujoints so be careful)
    WMS - 74"
    Keep in mind the F450, and 550 trucks are 10 lug and 84" wide you can take all that off and run the 8 lug off smaller trucks no problem and you loose 10" of width!
    May 2012
    Flamborough
    Top Stub is a 2005+ 35 spline with actually 1.75" OD where the bearing rides which means you can run custom 40 splines withough changing bearing!!
    Middle 35 spline chromoly for 99-04
    Bottom is stock 30 spline 99-04 stub shaft
    May 2012
    Flamborough
    WB on the left is 2005+ uses larger splines with less count and larger bore
    WB on right is 99-04 smaller bore (needs machining for 35 spline) and uses smaller splines but more of them for the hub...
    These are not interchangeble betweeen the 99-04 and 05+ due to the fact that the entire knuckle on the 05+ is larger see below
ID:	100018 99-04 Knuckle
ID:	100019 05+ Knuckle! MASSIVE
Name:	2007 knuckle.jpg
    May 2012
    Flamborough
    I Should add early on in this thread that you need to pay CLOSE attention when sourcing these axles... from 99-03 Ford used a Dana50 in many vehciles which at first may look like a 60 but a trained eye will know it is not.
    The Dana50 has a shorter pinion gear and smaller diameter
    Also the axle shafts neck down at the carrier (prone to fail here)
    Other then that they look similar at a quick glance... best way to tell is by looking at the decal on the long axle tube if it still has the decal the bottom right corner of it will say 229 which is 229mm (ring gear size) smaller then a 60 its close to a D44 actually! If there is no decal left then you can tell by the diff housing on the top of the housing there is a sloped part along the pinion on a 50 it stops short and goes straight down due to a shorter pinion.. on a 60 it slopes all the way to the seal almost.
    So dont buy the wrong axle from 99-03! in 04 they were all 60s Ford phased out the 50 all together then in 05 they went bigger again and coil sprung
    Time Online: 10 Mths 3 Wks 5 Days 12 Hrs 32 Mins 11 Secs
    The D50 also has an overall smaller gear set, bearings and a D44 sized carrier. The Superduty D50 is a clusterfuk - you get the size and weight of a 60 in a significantly weaker package.
    May 2012
    Flamborough
    1 tonning JK's
    Yes don't get stuck with a super duty 50 I have one here if you want a glorified dana44 haha
    Oct 2013
    Smithville, ON
    Time Online: 1 Mth 2 Wks 2 Days 20 Hrs 9 Mins 55 Secs
    Avg. Time Online: 3 Mins 50 Secs
    ya, i think i'll be following this along very closely
    '99 XJ Sport - Black - BUILD THREAD
    '13 Ram 1500 QC - Black Gold
    Shocker #5
    OF4WD #8158
    Feb 2011
    Aurora
    Time Online: 3 Wks 6 Days 21 Hrs 46 Mins
    Avg. Time Online: 2 Mins 17 Secs
    Sub'd! This looks like it's going to be awesome!
    Signed with an X
    May my YJ RIP
    Building an SAS Xterra...slowly
    May 2012
    Flamborough
    1 tonning JK's
    This axle has a ton of cast parts crazy heavy duty nothing liquid wrench can't handle though!
    Once the rest get cut off and ground clean the knuckles and crap will come off and we will sand blast it
    Also we decided on drive flanges over locking hubs personal preferences that we feel will benefit us and our needs
    Stay tuned for more!
    Jun 2014
    Milton, ON
    Time Online: 2 Wks 14 Hrs 39 Mins 58 Secs
    Everythings looking awesome steve!
    May 2012
    Flamborough
    Thanks dude weve been busy haha
    Avg. Time Online: 1 Hr 4 Mins 23 Secs
    go big or go home ..this will be fun
    May 2012
    Flamborough
    1 tonning JK's
    Got a few minutes tonight to cut some brackets and clean it up a bit
    May 2012
    Flamborough
    We picked up our rear axles finally, we wanted to be different after all and do something most people dont.. So we wnt with the AAM14 bolt 11.5" axles for the back!
    2002 and 2003 Chevy Silverado 2500HD rear 14 bolt with disk brakes these things are massive... Comparable to a Dana80 in terms of gear size so we shouldnt ever have a problem witht them.
    Most guys dont run these as there are not a lot of aftermarket choices for parts, but we found 5.38's and lockers and shafts aftermarket so were good to go the rest like ABS and mounts we will make no biggy!
    Details:
    AAM 14 Bolt
    Ring Gear - 11.5" Diam.
    Ring gear bolts - 12
    Axle spline - 30
    Full Float axle
    G80 axle code - Eaton factory locker/LSD (depends who you talk to and how they interprit the diff) at 100rpm difference of the back wheel they lock up but under extreme load situation they will unlock so some call it a LSD some call it a locker...
    The axles are used in a lot of Diesel tow rigs and hold up to 1000hp and 600+ft/lb of torque so I belive a 4000lb jeep putting out 290hp will never break these haha maybe when an LS goes under the hood I will have to worry but I will be proud if i do grenade it!
    May 2012
    Flamborough
    1 tonning JK's
    Here is a pic of a hp60 front ring gear left beside the 14 bolt ring gear right
    Here is a jk dana30 front inside the 14 bolt
    what a difference ..go big or go home
