Results 1 to 19 of 19
Thread: 4.7L Stroker Engine Build/Install...
    Time Online: 2 Mths 4 Days 13 Hrs 45 Mins 57 Secs
    Avg. Time Online: 5 Mins 18 Secs
    Ok Well I have had this New 4.7L Stroker Engine in and Running now for just over 1500KM so Its time for an update...
    The Engine In My MJ was a Used Engine that I had been Running for around 8 Years and from the get go I had a small coolant loss issue that I could Never Find then One day I found the Problem...
    A Cracked Cylinder Wall which the Piston Ring didn't Like meeting...
    As many of You know here I have been planning a Stroker build for almost as long as I have Been a Jeepkings Member and had been building slowly a 4.7L Stroker for the past 4 years...
    The Head had work done but I didn't get pictures of it but it had Larger SS Valves installed because I will be Supercharging this Engine in the very near Future so internally she is ready for it...
    So I Decided to Finish building the Stroker rather then just throwing in a JY Engine...
    So A few Specialty Items Ordered up and painted to my colour choices...
    Brown Dog Engine Mount kit
    FlowKooler High Flow Water pump
    Degree able Timing Set From Hecso (I wouldn't ever recommend anyone order this as its a rip off and far cheaper to do now that I know thier secret)
    Harland Sharp Roller Rockers (non Adjustable)
    My Colour Combination
    Pretty Much all ready to go in
    Had the Intake Bored out to 70MM for my New 68MM TB
    Made a Custom Fan Mount for my Dual Electric fans as I hated having them zip tied to the rad...
    Then it was Time for the Exhaust Work....
    Magnaflow Hot Rod Kit and Magnaflow Muffler and OBDII Compliant Cat
    First Mock up of the Collector
    Finished Collector with Mocked up Cat
    Collector Installed
    Time to create the Tailpipe
    Still have some fine tuning to do as well as some other mods and upgrades but that's down the road...
    Now I just Need a Custom Torque Converter made and my trans will be happier...
    Port Elgin
    Time Online: 3 Mths 3 Wks 3 Hrs 8 Mins 9 Secs
    Avg. Time Online: 9 Mins 8 Secs
    what did you use or injectors?
    KUSS
    Stupid Fukin Nature
    OF4WD# 2660
    My recipe Called for 26lbs Injectors but I have found so far the my engine to be happier with my 24lbs Mustang 4 hole injectors but I am still playing with the sizing to get the A/F just Right..
    If your looking for Specific Injector Part numbers I don't have that info handy...
    I am fortunate to have many different size injectors and a few TB sizes to play around with and I run an A pillar A/F gauge and Fuel Pressure gauge to monitor my engine as I drive or make changes...
    Time Online: 3 Mths 2 Days 12 Hrs 56 Mins
    dam Alex, looks great..... I'm going to need to stop bye and see it soon!
    Thanks its Coming along... Slowly but its getting there...
    By the lake
    Time Online: 1 Mth 3 Wks 5 Days 1 Hr 42 Mins 37 Secs
    Avg. Time Online: 4 Mins 36 Secs
    Cool build Alex. What are your estimated hp and torque goals?
    A few years back I remember Jp magazine doing a stroker and think they had it cranking out 692hp or so. Crazy...
    84 CJ7
    03 Hummer H2
    Ottawa Valley
    Time Online: 2 Mths 4 Wks 21 Hrs 47 Mins 34 Secs
    Avg. Time Online: 7 Mins 18 Secs
    Very cool Alex! any interest in reproducing the fan mount? Also what are you using to control the fans?
    The OG HOISTWAGON
    99 XJ, CT Motorsports built, Tons, 37" MTR/Ks, TMR 3-link and Beadlocks, CrewFab Cage and Bumpers, PSC full hydro
    Thanks guys...
    I should be in the 300HP 300 ft/lbs area... Not going to know for sure till I do a Dyno run when I find somewhere around here should I like them that is since not just anyone touches my Trucks...
    Once I supercharge it that will bring me into the 400-450HP and ??? ft/lbs...
    The JP 692HP Turbo Engine was Cool and maybe I will aim there when I do my Next 5.0L Stroker but until then I think I will be happy with what I got...
    selkirk ont
    Time Online: 1 Yr 3 Mths 2 Wks 5 Days 2 Hrs 32 Mins 26 Secs
    Avg. Time Online: 38 Mins 59 Secs
    nice work alex!
    WHAT WOULD MACGYVER DO?
    2004 rubicon: 12,000 lb titan winch, 35" goodyear wranglers, staang's belly-up skid, cobra 29 cb, highline fenders, trailhead bumpers
    http://www.youtube.com/user/onehosereh#p/u
    VA3 HWG, OF4WD #5571, RETREAD #1
    Time Online: 2 Yrs 1 Mth 3 Wks 3 Days 21 Hrs 34 Mins 45 Secs
    Avg. Time Online: 1 Hr 4 Mins 32 Secs
    now that is cool alex
    Looking good.
    what combination did you use for the pistons/crank/rods? How much over did you go on the bore? and are you willing to share the secret?
    For the Most part there are no Secrets and the bore is 60 over which is what makes it a 4.7...
    4.2L Crank (Serpentine System so I didn't need to Machine the snout of the crank)
    4.0L rods (ARP rod bolts, weight matched with each other and then rotating assembly balanced)
    Forged KB-IC944 Pistons
    Comp Cams Cam
    Oct 2013
    Smithville, ON
    Time Online: 1 Mth 2 Wks 2 Days 20 Hrs 9 Mins 55 Secs
    Avg. Time Online: 3 Mins 51 Secs
    very cool!!
    looking forward to the results....and a detailed shopping list
    '99 XJ Sport - Black - BUILD THREAD
    '13 Ram 1500 QC - Black Gold
    Shocker #5
    OF4WD #8158
    selkirk ont
    who did your machining ?
    Quote Originally Posted by Jeepman View Post
    Degree able Timing Set From Hesco (I wouldn't ever recommend anyone order this as its a rip off and far cheaper to do now that I know their secret)
    this secret....
    Quote Originally Posted by onehoser View Post
    AutoService Did the Machining and assembly work but they have since sold off their shop and it merged with Hamilton Head and Block...
    I Will use your Buddy Dave for all future Machining...
    As for that secret well its basically they sell you a stock Timing set then add an Aftermarket degree set and drill out the roll pin alignment hole to 10MM kind of a Huge waste of money and a rip off buying one from Hesco so I wouldn't ever do that again and If I knew I would have went with the MOPAR double roller set and did the mod myself...
    25K KM on it and all is still Great, Now to find a way to keep the A/C and Squeeze the Supercharger under the hood...
    Pics will start when I get it started...
