Page 5 of 20 FirstFirst 1234567891011121314151617181920 LastLast
Results 81 to 100 of 388
Thread: Project buggy revive
  1. #81
    Feb 2005
    Simcoe
    Time Online: 1 Mth 1 Wk 3 Days 15 Hrs 1 Min 52 Secs
    Avg. Time Online: 3 Mins 21 Secs
    More pics
    [IMG] photo 20150601_150519_zpscb4v3wtg.jpg[/IMG]
    was not fun welding on your back and running vertical pool.
    92 RENEGADE
    82 Toyota long bed
  2. #82
    Feb 2005
    Simcoe
    Control arms shortened with new bushings. Final arms Eye to eye is 41'', it was 43''
    [IMG] photo 20150608_224803_zpsy8kqpyi3.jpg[/IMG]
    [IMG] photo 20150608_224819_zpstjc1i1rs.jpg[/IMG]
  3. #83
    Feb 2005
    Simcoe
    Fuel starvation SOLUTION.
    [IMG] photo 20150604_064658_zpsmgxloznr.jpg[/IMG]
    [IMG] photo 20150527_095108_zpsbmyvq1k8.jpg[/IMG]
    All plumb in. I used 5/16'' brake line with single flare. Orientation as you see it. Two pick up tubes in the rear, I figure we DO INCLINED climbs majority of time.
    AN fitting mixed connection.
    [IMG] photo 20150605_173321_zps8wpylnpz.jpg[/IMG]
  4. #84
    Feb 2005
    Simcoe
    4 blocks of foam.
    [IMG] photo 20150605_194533_zpspsq4eygx.jpg[/IMG]
    Internal fuel Roll over valve. I'm also running back up external ball valve flavour.
    [IMG] photo 20150605_133210_zpsfwiaihlf.jpg[/IMG]
  5. #85
    Feb 2005
    Simcoe
    Sparkplug insulator.
    Fuel line insulator at engine bay.....no pics
    Fuel pressure gauge.
    [IMG] photo 20150524_191223_zpszggfnmti.jpg[/IMG]
    [IMG] photo 20150523_085515_zpskymiham6.jpg[/IMG]
  6. #86
    Feb 2005
    Simcoe
    I have few more things to finish so I can go for my 2ND SHAKE down this weekend LOL. Install arms and splash fuel into cell so I can work in the garage tonight after work.
    I need to install aluminum roof, forecast are calling for rain Friday........booooooo
    headlights
    CB
    Wire heater
    ROCK lights
    and the long list goes on and on................................................ .................................................. .............................
  7. #87
    Time Online: 3 Mths 1 Wk 3 Days 13 Hrs 43 Mins 30 Secs
    Repair to the frame looks fantastic! It was nice to meet you at crawlfest. hope this shakedown goes smoothly.
  8. #88
    Feb 2005
    Simcoe
    I enjoy meeting you as well, I'm sorry I forgotten your name. Thanks again for the can of fuel.
    Bernie
  9. #89
    Mississippi Mills
    Time Online: 6 Days 21 Hrs 29 Mins 55 Secs
    Avg. Time Online: 34 Secs
    What fuel pump? Where is it mounted, specifically in relation to the pickup line in the tank? Running the stock fuel regulator in the rails I presume based on the picture? If it was boiling, was the fuel tank hot?
    Why the foam? I'd be worried about the foam breaking down and clogging the Walbro's myself. Holley's new hydramat would have been a pimp solution.
  10. #90
    Quote Originally Posted by Kunker View Post
    It looks like the perfect solution until you see the price. It's ridiculous.
  11. #91
    Feb 2005
    Simcoe
    Fuel pump looks like Airtex/E2000. It's mounted on the frame rail maybe 3feet from the cell. Yes stock fuel rails.
    I didn't check fuel cell for temp but noted.
    I put the foam in to battle fuel sloshing around.
  12. #92
    Mississippi Mills
    The smaller versions were a little more reasonable to me, the first large mat they released pricing for was retarded.
    EDIT: I'm still waiting to see how the testing with the different Ford socks works out as well on PBB - it looked like a potential cheap solution that gave the same results.
  13. #93
    Mississippi Mills
    Quote Originally Posted by PRIORITY 4 View Post
    Wayne's baffles won't break down like the foam does, although they are a little pricy as well:
    http://www.alltechmotorsports.com/accessories.html
    Is the pump below the cell? I presume the feed previously was coming out of the front/sump of the tank as well? What size is the feed line into the pump?
    If the fuel is getting hotter, it's going to boil much easier in the vacuum conditions it's seeing at the suction line, so having the pump as close as possible with low restriction in would be ideal. That said, I'm not sure if it was necessarily a boil situation vs no feed from sloshing/location of the old pickup.
  14. #94
    The original intent behind the hydramat is that it covers most or all of the bottom of the cell. Therefore, no foam or baffles are required to keep the pick up from sucking air at any time no matter what happens. It was supposed to be a simple and eloquent solution to a somewhat complex problem. While it is, using the hydramat in the manner it was intended makes it extremely costly. Using a hydra mat that is smaller than what is required to adequately cover the bottom of the cell is counter-intuitive to me.
    At that point, why not just stick with baffles and snowmobile pick ups?
    FWIW, I have used the Ford pump pick up sock for years with my own internal one-way pump sump. It works beautifully.
  15. #95
    Mississippi Mills
    If I can use the Holley + design, or ideally something in a |-| configuration to hit all the corners without the cost of the entire cell being covered, I'd be willing to risk it. That would pretty much be the same as the Walbro pickups. My concern is more how much it really aerates (spl?) the fuel when it's really sloshing around in the cell.
    What type of pump are you using in your system? I'm guessing it's a lower pressure setup than the LS engines like as I *think* you're running a MPFI setup on a BBC, right? I'm going with the 255lpm pump from Walbro externally for now, but keep thinking I should have spent the coin on Goatbuilt's stock GM intank setup.
  16. #96
    Feb 2005
    Simcoe
    2nd shake down went well in ARDBEG this pass weekend. My Walbro pick up I put in worked like a champ. I had the buggy sideways, steep inclined and declined. I'm going to wrap my headers to keep engine bay lower, they sure give out a lot of heat.
    My arms and shoulders had a work out rowing gears on the old 435 tranny. I need to redesign shifter linkage and next year auto will be going in.
    [IMG] photo 20150613_082949_zpsait5acir.jpg[/IMG]
  17. #97
    Feb 2005
    Simcoe
    more of Adberg
    [IMG] photo 20150613_113000_zpsahe9sgli.jpg[/IMG]
  18. #98
    Feb 2005
    Simcoe
    more
    [IMG] photo 20150613_161053_zpsk44561dl.jpg[/IMG]
  19. #99
    Yeehaw!
  20. #100
    I missed this post earlier.
    I'm using a Walbro 392. It is the OEM manufacturer of most of the common domestic in tank / in line pumps. Like the e2000, etc. The 392 is the common/generic 255 LPH pump.
    And yes, it is feeding a MPFI 454. I have been using the one way swirl type pump sump with a 392 for 17 years (yikes) now.
