Results 1 to 15 of 15
Thread: Tire size on stock jeep don't want to put on a lift
    Sep 2015
    Waterdown on
    Time Online: 12 Hrs 14 Mins 21 Secs
    Avg. Time Online: 2 Secs
    Thumbs up Tire size on stock jeep don't want to put on a lift
    What's the biggest tire I can put on my jeep with out a lift? Rather put the $ to fenders and bumpers and other.... Just Jeeps told me I need A 2" lift for 33's and don't recommend a body lift just suspension Help out a new guy pls
    Jun 2012
    mississauga
    Asleep
    Time Online: 7 Mths 1 Day 9 Hrs 58 Mins 58 Secs
    Avg. Time Online: 17 Mins 24 Secs
    What model jeep?
    Jun 2008
    toronto
    Time Online: 2 Wks 16 Hrs 57 Mins 59 Secs
    Avg. Time Online: 1 Min 12 Secs
    May 2014
    Ingersoll
    Time Online: 2 Wks 11 Hrs 30 Mins 54 Secs
    Avg. Time Online: 1 Min 11 Secs
    That's wrong you can do 35's. Maybe larger. Depending what your willing to cut. But ya who knows if he even has a jk. Sounds like a tj.
    Jun 2008
    toronto
    Quote Originally Posted by Ghetti View Post
    on his profile ..... 2015 unlimited
    i hope you know what you are talking about
    May 2014
    Ingersoll
    Flat fenders and 35's I've stood next to it. So I'm pretty sure it's doable.
    Jun 2007
    Time Online: 5 Days 9 Hrs 33 Mins 5 Secs
    Avg. Time Online: 26 Secs
    The tire size question comes up a lot, I mean all the time, so you're best to do a search on the interweb or even on this site. Technically, you can fit whatever size tire you want provided you are willing to cut/trim body panels.
    However, I would assume you don't want to go that route. Therfore, trust what JustJeeps told you, they are a reputable source, to say the least.
    Sep 2015
    Waterdown on
    2015 wrangler sport unlimited
    Sep 2015
    Waterdown on
    This is what I've come up with after way to much time researching, lol. No lift with cooper Dis stat 295/70 on stock r17 rims with 1.5" spacers. (33x12) or save about $500 and go with Bf Goodrich mud/t km2. 255/80/r17. (33xcurent width). No mods needed With the idea to add spacers on later to improve the stance of the jk. Leaning more towards the Bf's. The mods I want to do for the jeep is more of a marathon then a sprint. Wife + kids = budget. Figure by the time I'm done I will need a new set of tires. Just still sitting on the fence. Thanks for the info
    Mar 2016
    Time Online: 21 Hrs 16 Mins 44 Secs
    Spend your money on a budget lift. Little 3 inch coil spacer, then tires, then fenders and bumpers
    Sent from my SM-N910W8 using Tapatalk
    99 Jeep Tj 4 Inch Lift With The Legendary Front Stinger/Rad Hoop
    96 GMC 6.5 Detroit Turbo Diesel- First Truck
    02 Cavalier- DD
    Let's Build Some Sh*t!
    Time Online: 1 Yr 5 Mths 2 Wks 1 Day 1 Hr 4 Mins 35 Secs
    Put your fenders of choice on or cut the stock ones then do the size tire you want. The reason JJ's says you need a lift is to prevent rubbing. Basically you will need an offset rim or spacers to prevent the larger tire rubbing the frame when you turn. That however puts the tire under the lip of the fender as opposed to inside it when you flex. With no lift that results in the tire hitting the fender and eventually ripping it off. Now, if you trim the fenders or do flat (or arched) fenders you don't have that same issue so no lift is required. Larger tires may also hit stock bumpers without a lift or trimming the bumper.
    Time Online: 2 Mths 4 Days 13 Hrs 43 Mins 45 Secs
    Avg. Time Online: 5 Mins 18 Secs
    If your not going to change flares then the norm rule of thumb for a JK would be:
    up to 33" tires and NO lift is needed (and cruise the mall with maybe some light wheelin)
    33's and a 2" lift (Go wheelin)
    35's and a 2" lift (Light wheelin)
    35's and a 4" lift (Go wheelin)
    37's and a 4" lift (Light Wheelin)
    Jan 2010
    Orillia Ont
    Time Online: 1 Wk 1 Day 15 Hrs 11 Secs
    I just put 33s on with no problem on stock rims . 35s would have been a problem with interfering on rear control arms.
    Wish i still had.. 1998 Cherokee XJ 4.0,Magnaflo Header and Exhaust
    3.5 Rough Country Lift , 1" Rear Shackles with 1" Front spring Spacers
    AA SYE,,Custom Front Bumper. D44 rear just in.Not locked yet
    33 x 12.5 x 15 Mickey Thompson Baja Claws
    Now have 2015 Wrangler Sport with 33" Federal Couragia MTs
    More mods come spring.
    Ajax Ont
    Cynical
    Time Online: 3 Wks 3 Days 6 Hrs 38 Mins 4 Secs
    Avg. Time Online: 1 Min 59 Secs
    Quote Originally Posted by CptCanada View Post
    what tires? ie. width? and on stock rims?
    Jeeps, Bitches and Guns... Nuf Said
    Sep 2009
    Clinton
    Time Online: 2 Days 22 Hrs 23 Mins 28 Secs
    Avg. Time Online: 14 Secs
    33s with 4.5" backspace. You could also use stock rims with a 1" spacer. Slight rub in reverse at full lock. Here's an interesting article for you: http://www.fourwheeler.com/how-to/su...jk-suspension/
