Results 1 to 20 of 20
Thread: GlennH Jeep JK Build
    Oct 2015
    Mississauga, ON
    Time Online: 15 Hrs 59 Mins 37 Secs
    Since I'm new and moving from Winnipeg to Mississauga, figured I would transfer my build up thread.
    I really want to get out and go wheeling in some rocks. Hopefully I find the right crew and we can be friends and hang out.
    Add me to Facebook: Glenn Harrison or 905-396-0063
    My JK Build Sheet - Updated July 2015
    Year:
    2009
    Model:
    Rubicon Unlimited
    Color:
    Stone White
    Transmission:
    Automatic
    Suspension:
    Teraflex 3" Lift Coils
    Teraflex 0.5" Front Upper Coil Spacer
    Dynatrac 1.00" Front Lower Bumperstop
    Teraflex 0.5" Rear Upper Coil Spacer
    Teraflex 2.75" Rear Lower Bumpstop
    Teraflex Rear Coil Spring Retainers
    Rock Krawler Rear Coil Spring Correction Wedges
    Teraflex Front Lower Adjustable Control Arms
    Teraflex Rear Upper Adjustable Control Arms
    Metalcloak Rear Lower Adjustable Control Arms
    Teraflex Rear Trackbar
    Teraflex Axle Side Rear Trackbar Bracket
    Teraflex Rear Swaybar Links
    Bilstein Front Steering Stabilizer with Synergy Tie Rod Clamp
    Synergy Steering Stabilizer Correction Bracket - not installed
    Synergy Adjustable Tierod with Synergy 1 Ton Tie Rod End's
    Synergy Adjustable Draglink w/ Flip Kit & Synergy 1 Ton Tie Rod End's
    Synergy Adjustable Front Trackbar w/ Synergy NEW DDB Bushing on frame side and Heim on diff side.
    Synergy Trackbar Bracket Welded to Dynatrac Housing
    Synergy Quick Disconnects with Relocation Brackets
    Crown Front Extended Brakelines
    Crown Rear Extended Brakelines
    Old Man Emu Sport NitroCharger Longtravel Shocks
    Wheels & Tires:
    MB Choas 5 Wheels (17x8.5, -6mm offset = 4.5" BS)
    35x12.5x17 Nitto Trail Grapplers
    Bumpers:
    Shrockworks JK Front Stubby Bumper with Winch Hoop & Grill Hoop
    Smittybilt Gen2 X20 10K Winch with Warn Zeon Winch Cover
    Cascadia 4x4 Front License Plate Holder / Flipper
    LoD Offroad Gen2 Signature Series Rear Bumper w/Tire Carrier, 3rd Brake Light & Rear Fog Lights with New Gen III Tire Carrier Adapter
    Armor:
    Poison Spyder Evap Skid Plate
    RedRock Fab Rock Rails
    Riddler Rear Diff Cover
    Offroad Evolution Rockstar Shock Relocators & Skid Plates
    Nemesis Front Lower Shock Relocators / Skid Plates
    Rugged Ridge Front Lower Control Arm Skid Plates
    Dynatrac Front Differential Cover
    Drivetrain:
    Dynatrac ProRock 44 Front Differential Housing
    Coast Front Driveshaft w/ U-bolt Yokes & Spicer 5-1310X U-Joints
    Coast Rear Driveshaft w/ U-bolt Yokes & Spicer 5-1310X U-Joints
    Yukon 5:13 Gears
    Stock Front Axles with Spicer 5-7166X U-Joints and Full Spare Set
    Ten Factory Chromoly Rear Axle Shafts and Full Spare Set
    RCV Front Outer Axle Tube Seals
    Timken Front Unit Bearings
    Alloy USA Ball Joints
    Performance:
    AEV ProCal
    MBRP Exhaust - Modded Under Driver's Side Passenger Seat with Flopro Tube Muffler
    B & M Transmission Cooler
    EBC Greenstuff Front Brakes Pads
    EBC Greenstuff Rear Brake Pads, Updated to ThermoQuiet Pads & Rotors
    Lighting:
    KC Hilites - LED Front Headlights
    Vision-X Tantrum LED Stroke Light & Rocklights w/ Magnetic Magnets
    Accessories:
    Seat Glovers Front & Rear Covers
    Euro X Antenna
    Rugged Ridge Arm Rest
    Rugged Ridge Front & Rear Grab Handles
    Daystar Hood Latches
    Daystar Dash Panel
    Locker MOD - Override Switches
    Uniden XL68 CB Radio w/Uniden CB Speaker
    Cool Tech LLC Versa Mount Mic
    Teraflex Mudflaps
    AeroForce Interceptor Dual Guages
    LoD Quick Fist Clamps
    Mopar Kicker Speakers Front & Rear
    McNally M-CUP Cellphone Holder
    Northstar Battery
    Rugged Ridge Grille Inserts
    Husky Floor Mats
    Oasis Automatic Trailhead Tire Deflators
    ARB Tire Deflator
    Titan Max Portable Compressor
    AEV Jackbase
    Smittybuilt Fire Extinguisher Holder
    Jeepswag DirtBagz - Black Saddle Bag Set, Baja Bag
    Hi-Lift Jack
    Macs Custom Tie Downs
    Some of you know by now I bought my dads Jeep. I've been wheelin, wrecking, wrenching and buying an assortment of new parts all spring and summer. Figured I'd throw up a build sheet of whats been done so far.
    Quick Teaser for you all before the parts were installed: My GF and I had to test out what I bought before I did the upgrades.
    Poly Performance Drag-link, Poly Performance Track-bar and Manual Swaybar Disconnects.
    Metal Cloak Control Arms.
    Old Man Emu Longtravel Nitrocharger Shocks & Torrent Offroad Decal.
    Ten Factory Chromo Shafts.
    Oct 2015
    Mississauga, ON
    New Cellphone holder aka The Command Center.
    New Hi-lift & Mount.
    Offroad Evolution Rockstars.
    Oct 2015
    Mississauga, ON
    Couple Updated Pics:
    A steering shot.
    Oct 2015
    Mississauga, ON
    UPDATE:
    -Ordered some Crown Extended Rear Braided Brake Lines
    -Nemesis Front Lower Shock Relocators
    -Broke a front unit bearing, Ordered a new one with a Timken bearing this time.
    -Bought a few New Spicer 5-1310X U-Joints for driveshaft trail spares.
    -Also my lovely girlfriend bought me the Milwaukee Power Drill and Impact set.
    -Bought another Front Unit Bearing
    -Ordered some Front Axle U-Joints
    -Bought some RCV Front Outer Axle Tube Seals
    -Bought an ARB 4x4 Sport Lawn Chair
    -Got some Rugged Ridge Front Lower Control Arm Skid Plates
    -Ordered a Brownline Digital Torque Wrench
    Now to find time to install all this crap.
    UPDATE:
    Transmission Flushed
    Transmission Lines Fixed
    New Power Steering Hose
    and... New 35x12.5x17 Nitto Trail Grapplers.
    UPDATE:
    New Tie Rod Ends
    New Drag-Link Ends
    Inner axle seals replaced
    Outer axle seals installed
    New wheel sensor installed
    Alignment finally completed
    Ready to rock maylong!!
    Oct 2015
    Mississauga, ON
    this will be a winter project. I'm collecting parts now.
    Alloy USA Ball Joints and EBC Green Stuff Front Brake Pads Installed tonight. Just in time for Sept Long Weekend. CHAAAAAA!!
    I borrowed a friends Garage, Compressor and BJ Press.
    I got the new 4th Gen LoD Offroad tire carrier adapter for my bumper and tire carrier. I had the first gen and it was a round tube and it wiggled and wobbled like crazy and I didn't like it. Plus this new one extends further out for different rims and tire sizing. Oh and I stripped a stud on the first gen so now I got all new studs as well. Should be good.
    Oct 2015
    Mississauga, ON
    Little late posting this but found it on my phone from the FALL.
    I was tired of the Synergy steering colors, and so the black and white theme continues... I painted up the Synergy Track-bar & bracket, Synergy Tie-rod, Synergy Drag-link, Bilstein Steering Stabilizer, Synergy Sway-bar quick disconnects, Old Man Emu Shocks, Dynatrac ProRock 44 Housing and Differential cover. I then decided, might as well clean up the rusty stuff, so I painted the coils, lower control arms, Rugged Ridge control arm skids and the backside of the housing as well.
    I then said I might as well do the rear end too. So the Dana 44 got a complete coat along with my Riddler Differential cover. The rear lower shock skids aka Evo Rockstars have taken a beating so they got a good cleaning and coating, I wish I had a photo of this. I then finished painting those damn bright yellow Old Man Emu Shocks out back. Sorry no booty pics.... hahaha biggrin]
    Oct 2015
    Mississauga, ON
    So, a few new things recently.
    COVER KING SEAT COVERS
    MACS TIE DOWNS
    This is just a photo with 2 bins... I'll be carrying 4 bins when on the trail. Just test fitting them.
    Oct 2015
    Mississauga, ON
    TERAFLEX ROD END REBUILD
    NEW COAST DRIVESHAFT SLIP... I broke mine when I blew a u-joint in the fall.
    And Lastly... Yep... I did it. Rennie attacked me on our winter run. dirol]
    New driveshaft slip and u-joint installed. Also new front lower control arm rod ends installed.
    Nemesis Shock Relocation Brackets FINALLLY Installed. 2 yrs later... LOL
    Oct 2015
    Mississauga, ON
    So its been a long time coming for this moment but it finally has arrived!!!
    -Shrockworks Front Stubby Bumper with Winch hoop, Grill hoop & Front Lower Skid Plate
    -Smittybilt X2O Gen2 10K Winch
    -Cascadia4x4 Front License Plate Flipper
    Finally got some better pics....
    Oct 2015
    Mississauga, ON
    Been a little slow at the upgrades, busy enjoying summer!!!
    Anyways.... here's whats new.
    My last set of Teraflex Rebuild Kits for my front lower control arms didn't work out so well. After one 4x4 run the freaking snap rings all broke. Teraflex stepped up and sent out all new kits for free. So I got these bad boys all prepped and ready to go in.
    Since I got the new front bumper this year and I opt'd out for the front fog lights, my lighting department was lacking. I scored a good deal on the RRJC Forum and got these KC HiLites LED's.
    Here are the LED Headlights Installed. You'll notice that the eyebrow trim rings are now gone as they don't fit with the new headlights. The LED Headlights stick out a lot more the OEM.
    And lastly... yeah I had tooo. hahahahaha MALL RATED!
    Oct 2015
    Mississauga, ON
    Well.... since my bud Lloyd brought up the topic in his build thread of maintenance and control arms and such I guess it was time for me to follow suit and do the maintenance thing. Well lucky for me it was perfect timing since my Synergy trackbar kinda gave up on life quite recently and the "death wobble" had begun. Needed to tackle this job quickly before my newish balljoints and tres took a beating.
    So I Installed:
    - New trackbar heim & bushing from Synergy
    - New front lower control arm rod ends & bushings from Teraflex
    - New steering stabilizer from Bilstein
    - New wheel center cap from MB Wheels, I broke one lol.
    - Ordered new swaybar bushings from Synergy as spares
    - Ordered new tie rod ends from Synergy as spares
    Back on the maintenance train again....
    Front and Rear differentials serviced and looking minty!
    Clock spring replaced, I now have an airbag. lol
    Front Brake Pads & Rotors
    Rear axle seal and bearing replaced.
    Transfer case shifter cable replaced, dont ask how... but ya its broke.
    Installed new Teraflex rear upper control arm bushings
    Time Online: 3 Mths 2 Days 12 Hrs 58 Mins 11 Secs
    looks great dude! keep the pictures coming......
    Dundalk Ontario
    Time Online: 1 Wk 6 Days 13 Hrs 20 Mins 16 Secs
    Avg. Time Online: 1 Min 6 Secs
    It's a beauty. You're giving me some ideas
    My jeep wears a bra, maybe you should too
    selkirk ont
    Time Online: 1 Yr 3 Mths 2 Wks 5 Days 4 Hrs 52 Mins 56 Secs
    Avg. Time Online: 38 Mins 58 Secs
    nice work!
    WHAT WOULD MACGYVER DO?
    2004 rubicon: 12,000 lb titan winch, 35" goodyear wranglers, staang's belly-up skid, cobra 29 cb, highline fenders, trailhead bumpers
    http://www.youtube.com/user/onehosereh#p/u
    VA3 HWG, OF4WD #5571, RETREAD #1
    Oct 2015
    Mississauga, ON
    Thanks guys, its been 2 years of sweat and joy.
    Flamborough
    Time Online: 1 Mth 1 Wk 3 Days 19 Hrs 52 Mins 36 Secs
    Avg. Time Online: 3 Mins 21 Secs
    looking sick well have to meet up!
    2012 JKU Sahara, SD HP60 Front, GM 14 Bolt shaved rear, 5.38s, locked/Spooled, 4 link front 3 link rear, Oris, TR Double Beadlocks, 42" tsl sx2, PSC Full Hydro, D3 bumpers, D3 skids, D3 Rock Rails, D3 Cage, and lots more...
    OF4WD #5252
    Jan 2005
    Soon to be Michigan
    Time Online: 2 Mths 3 Wks 3 Days 17 Hrs 2 Mins 19 Secs
    Avg. Time Online: 6 Mins 57 Secs
    Sweet Jeep. Thanks for sharing and welcome to Ontario
    Tri-City Jeep Club
    Oct 2015
    Mississauga, ON
    Quote Originally Posted by just-lift-it View Post
    ill make the trek out in november and we'll get all the bs outta the way and D3 can maybe get me a skid plate for xmas.
    Time Online: 1 Mth 1 Wk 3 Days 15 Hrs 38 Mins 51 Secs
    Avg. Time Online: 3 Mins 20 Secs
    Looks great, you've been busy guy.
    Oct 2015
    Mississauga, ON
    made it to sauga.... just getting a safety today. Hope all goes well.
    EDIT: Passed.
