Page 2 of 8 FirstFirst 12345678 LastLast
Results 21 to 40 of 153
Thread: C-jk-8
  1. #21
    windsor
    Time Online: 2 Hrs 42 Mins 53 Secs
    Watching this one!
  2. #22
    Abbotsford BC
    Time Online: 2 Days 11 Hrs 1 Min 12 Secs
    Avg. Time Online: 12 Secs
    aaa
    www.4by4tech.com
    facebook: 4by4tech
  3. #23
    C-jk-8
    Still planning to run the stock tank?
  4. #24
    Abbotsford BC
    Yup, but going to add a 1 inch "body" lift for the cab portion the box won't matter. I am moving the forward most cross member back to another low spot on the top of the tank that you can see in the picture eliminating one cross member and just using two rather than three - worst case we will need to raise the floor slightly behind the passenger side seat to accommodate the higher tank position. As this is a two seater cab on a 4 door chassis not a 4 seater it won't bother the front seating position if I have to go this route.
  5. #25
    selkirk ont
    Time Online: 1 Yr 3 Mths 2 Wks 4 Days 7 Hrs 24 Mins 22 Secs
    Avg. Time Online: 39 Mins 2 Secs
    nice work!
    WHAT WOULD MACGYVER DO?
  6. #26
    Abbotsford BC
    Ordered the suspension today -Teraflex long arm LCG Elite 4 inch dual track bars but no shocks or bumps, sway bars via Currie Anti rocks. This thread will get more interesting once I have the parts in the garage and not at my USA border drop location...
  7. #27
    Abbotsford BC
    aaa
  8. #28
    Abbotsford BC
    aaa
  9. #29
    Abbotsford BC
    aaa
  10. #30
    May 2012
    Flamborough
    Time Online: 1 Mth 1 Wk 3 Days 19 Hrs 52 Mins 36 Secs
    Avg. Time Online: 3 Mins 22 Secs
    any reason why your putting in a 6l instead of all aluminum 6.2?
    2012 JKU Sahara, SD HP60 Front, GM 14 Bolt shaved rear, 5.38s, locked/Spooled, 4 link front 3 link rear, Oris, TR Double Beadlocks, 42" tsl sx2, PSC Full Hydro, D3 bumpers, D3 skids, D3 Rock Rails, D3 Cage, and lots more...
    OF4WD #5252
  11. #31
    I just had to bend those steering pump lines to clear my frame but they're scary close. I'm gonna put an off the shelf no resevoir pump and the biggest junkyard remote resevoir i can find or just make one out of steel that i can squeeze in somewhere.
    Lovin the progress!
  12. #32
    Abbotsford BC
    I paid 1800.00 for the engine and trans dressed (all assesories starter etc), the 6.2L are still pretty pricey. Also I've heard issues with the MDS engines having too swap the timing chains etc and the 6.0L is a bit tougher of a platform - same reason I stayed with a steel block rather than aluminum - durability was a big thing for me. I'm leaning towards a supercharger at some point, and the supercharger will fit a 4.8, 5.3 or a 6.0L so if I ever blow the motor up - I can stick any of those back in for under a grand. Same reason I went with the Holley injection set up - they make a main harness then you add on which ever end harness you need for the injectors supplied with the engine as GM used several different injector brands over the years. Rather than flash a computer for every change the Holley Dominator computer is self programming and laptop programable and also controls shift points in the trans. I had a similar set up on my 5.0L Ford in my TJ with the Holley Terminator injection.
    If those cooler lines are an issue i'll just add a block off plate - I'm not surprised you had fitment issues with the way the JK steering box sits on the frame. I'm good either way.
  13. #33
    Abbotsford BC
    aaa
  14. #34
    Abbotsford BC
    aaa
  15. #35
    Abbotsford BC
    aaa
  16. #36
    May 2012
    Flamborough
    C-jk-8
    Looks like lots of fun!!
  17. #37
    Oct 2015
    Mississauga, ON
    Time Online: 15 Hrs 59 Mins 37 Secs
    I see teraflex still uses those dang clevite bushings in their arms. Also that goofy rear trackbar bracket.
    Nice build up.
    OF4WD #8866
  18. #38
    Abbotsford BC
    aaa
  19. #39
    Abbotsford BC
    aaa
  20. #40
    Abbotsford BC
    Got some floor drawing from Aqualu today for the cab so I could double check the body mount locations for them.
    Cab will be 66 inches long with the extended cab hard top so some decent room behind the seats inside leaving me around a 55 inch long box - almost 5 feet so should look pretty good and not leave the box to "stubby" and out of proportion with the cab. Body is 68 inches wide at the back of the cab. I'll be tapering the box to almost the width of the back of the frame - so 48 inches at the tail gate. making for a 10 inch taper over the length of the box sides on each side.
    So it won't be overly "boat tailed" and again should not look to awkward once the flares are on and the outer edge of the flare sure to the tires on the outside edge and tapering to match the body taper of course... Think having your 4 door JK narrower than a TJ at the tail lights - nice for turning with this 116 inch wheelbase in the trees.
