Page 5 of 8 FirstFirst 12345678 LastLast
Results 81 to 100 of 153
Thread: C-jk-8
  1. #81
    Abbotsford BC
    Time Online: 2 Days 12 Hrs 1 Min 11 Secs
    Avg. Time Online: 12 Secs
    Yes there are things in the way on the TJ for sure mostly the steering box - the cross member can be modified but if you need a place for a sway bar that also becomes an issue. As the JK has the pitman arm pointing forward and the box sits further back and above the frame, and typically aftermarket sway bars are mounted below the frame its possible to lower the winch between the frame rails. Lots of aftermarket bumpers to do this but none that fit the 8274 so I had to improvise.
    www.4by4tech.com
    facebook: 4by4tech
  2. #82
    Time Online: 1 Yr 5 Mths 2 Wks 1 Day 18 Hrs 17 Mins 58 Secs
    Looks great, I really like the idea to.
  3. #83
    Abbotsford BC
    aaa
  4. #84
    Abbotsford BC
    aaa
  5. #85
    Abbotsford BC
    aaa
  6. #86
    Abbotsford BC
    aaa
  7. #87
    Abbotsford BC
    aaa
  8. #88
    Abbotsford BC
    aaa
  9. #89
    Jan 2013
    Midland ON
    Time Online: 4 Mths 3 Days 7 Hrs 11 Mins 30 Secs
    Avg. Time Online: 10 Mins 6 Secs
    Love the build. Always looking forward to updates.
    Sent from my SGH-I747M using Tapatalk
  10. #90
    Windsor, ON
    Nice work, I thought you were going with a Dana 70 rear, switched to a 14 bolt now? Assuming for gearing choices and ground clearance, at least after the shave.
    Sent from my Nexus 5 using Tapatalk
  11. #91
    Abbotsford BC
    Yes had to switch, I wanted the Dana 70 so I could use the new Eaton 4 pinion e locker in the back and it had better natural ground clearance than the 14 bolt. However they only make it for the HD housing and try as I might i could not find a HD dana 70. What I did learn though is damn there are a lot of different Dana 70s out there. So for now its a Detroit in the back - but going new style 14 bolt gave me factory disk brakes, better E brakes and a matched width within an inch of the Ford king pin 60 I have up front. I wanted a selectable locker in the back to get better use out of the steering brake. I typically have a Detroit in the back so that doesn't bug me but it seemed kinda silly to put an E locker in the front and a ARB in the back - time will tell.
  12. #92
    Abbotsford BC
    aaa
  13. #93
    Abbotsford BC
    aaa
  14. #94
    selkirk ont
    Time Online: 1 Yr 3 Mths 2 Wks 6 Days 2 Hrs 3 Mins 34 Secs
    Avg. Time Online: 38 Mins 58 Secs
    beautiful work!
    WHAT WOULD MACGYVER DO?
  15. #95
    By the lake
    Time Online: 1 Mth 3 Wks 5 Days 2 Hrs 25 Mins 28 Secs
    Sweet build. I love you're mixture retro and new. Like the cj dash components etc.
    84 CJ7
    03 Hummer H2
  16. #96
    Abbotsford BC
    aaa
  17. #97
    Just picked up a set of the ends from that kit to replace the heim joints on my swayloc. Way cheaper than replacement heims, greaseable and rebuildable to boot. I suspect the rest of the kit is just as nice.
  18. #98
    Abbotsford BC
    Yeah I was pretty please when everything came out of the box. Ill be welding on the sway bar brackets not bolting them on though. I had my TJ Currie Anti rock still and I was going to use that in the front but decided to keep all the suspension parts the same and ordered two of these and sold off my Currie which was 8 years old anyway. I've been happy with every part of the Teraflex kit so far, arms are serious beef, flex joints look good and lots of thread on them for adjustment way more than most, all brackets nicely welded, only thing I didn't do was buy their shocks as I went with Fox JK internal bypass shocks and Fox air bumps - the Tera bumps are foam filled. Should have my shocks in two weeks. Build date was Sept 7th.
  19. #99
    Abbotsford BC
    aaa
  20. #100
    Abbotsford BC
    aaa
