Page 1 of 8 12345678 LastLast
Results 1 to 20 of 142
Thread: Project Chericon
    Apr 2004
    Grimsby, Ont.
    Time Online: 3 Mths 3 Wks 2 Days 13 Hrs 12 Mins 4 Secs
    Avg. Time Online: 9 Mins 20 Secs
    Project Chericon
    Well, as some of you know I have been gathering parts to build a TJ rubicon front axle for the front of my 97 Cherokee
    Here are some of the parts so far
    Diff housing
    Ring, pinion, seals and all other little stuff
    and the carrier unit.
    The ring and pinion are getting set up now and I will be bringing it back home this week.
    I will post more pics of the process as it come along.
    If all goes well it should be under the jeep before the beginning of may.
    #20OF4WD#3476
    "Will roll over for treats"
    97 XJ on 36's (with a few mods)
    Apr 2007
    Beamsville! Where else?
    Time Online: 1 Mth 2 Wks 6 Days 18 Hrs 37 Mins 53 Secs
    Avg. Time Online: 4 Mins 10 Secs
    Adam, bring that thing by anytime and I'll box in the lower control arm mounts for you. Better yet, if you are still running stock control arms I'll box them in too.
    D
    CHARLIE DON'T SURF!!
    DINGA DING DANG, MY DANGA LONG LING LONG
    OF4WD#5576
    BOOYAH!!!
    LugNutz's Avatar
    LugNutz is offline President of Post Whore Guild
    Time Online: 1 Mth 2 Wks 6 Days 9 Hrs 16 Mins 39 Secs
    Avg. Time Online: 4 Mins 8 Secs
    A Rubi axle in a Cherokee? Don't they plow the malls out that way?
    You never truly know your limits until you exceed them....
    Aug 2007
    Near Waterloo
    Time Online: 6 Hrs 52 Mins 37 Secs
    Rubi axle in a cherokee theres a good use for that axle. lol
    keep up the good work and info man
    2000 Jeep XJ 7" lift (long arm) with 33's warn front winch bumper(no winch yet) ,roof rack,roof lights,Currie HD tie-rod systeme and in need of much more.
    NEED TO GO BIGGER
    Apr 2004
    Grimsby, Ont.
    Quote Originally Posted by Chevy YJ View Post
    D
    Sounds good buddy, I have RE fixed arms upper and lower, so they should be good. I will give you a shout when I bring it home.
    Quote Originally Posted by LugNutz View Post
    Just because your jeep is a mall crawler/snow plow, and has "Rubicon" on the hood does not mean every other Jeep is the same.
    Quote Originally Posted by CheapJeep2000 View Post
    I thought it was a good "keep me busy" project.
    Cool
    Time Online: 3 Mths 4 Days 14 Hrs 20 Mins 13 Secs
    Avg. Time Online: 7 Mins 46 Secs
    Looks like you are coming along nicely
    Professional lunatic
    TJ V3.0 in the works "This is only temporary, unless uhhhh..... it works."
    I get confused once numbers get bigger than I can count on my appendages. I'm only good up to 21!
    one quarter turn before something breaks is a good torque spec.
    Apr 2004
    Grimsby, Ont.
    ^ thanx bud, everytime I look at the parts filling up my garage I get the urge to go wheeling.
    BTW how is your project comming along now with the little one in the house.
    I have not sen any updates on your thread.
    Apr 2004
    Grimsby, Ont.
    Well, gears are set up ready to go, now all that is left is to install it into the Jeep.
    If all goes well I will have install pics next week.
    Apr 2004
    Grimsby, Ont.
    Just an update.
    Installed the control arm drop brackets, locker pump, and axle.
    Had some issues with the front diff so it is getting re-built this weekend and as soon as I get some time at home I will post pics of the install.
    Apr 2004
    Grimsby, Ont.
    Well after some repairs by Race Car Services the front axle is set and ready to go.
    Just rolled into the shop
    partly torn down
    Here it is out
    New 44 going in
    Pump wired and mounted
    I have pictures of the switch and the diff cover (after fill plug was moved up to acomidate more fluid) but they are on my phone that is now dead so I will snap some more pics and post them up when I get a sec.
    Apr 2004
    Grimsby, Ont.
    Here are a couple more shots.
    Here is a shot of the diff cover with the fill plugs moved up about 2"
    And here is one with the switch in place.
    All that is left now is to paint the diff cover and install the front drive shaft,
    then it is time for a shake down run.
    Time Online: 3 Wks 4 Days 19 Hrs 17 Mins 39 Secs
    Avg. Time Online: 2 Mins 7 Secs
    Nice work, and thanks for posting.
    Did you source the housing from a salvage yard, or? Is the locker a stock Mopar part, or? As far as the axle mounts go did it bolt in with no problems?
    1991 Xj Gone to a new home.
    1948 willys Jeep pickup sitting and waiting.
    1984 toyota currently beating & building.
    OF4WD #6069
    Apr 2004
    Grimsby, Ont.
    This is a all new set up (housing and all). All parts, (locker housing ect) are for a 03-06 Rubicon. I re-used my knuckles, wheel bearings and brakes, and yes it was a complete bolt in.
    the nuclear waste depository
    Time Online: 1 Wk 1 Day 13 Hrs 17 Mins 56 Secs
    what do you figure you have in to it? 2g's? where did you get the axle? if from the junk yard why didn't you grab the rear axle?
    11 F150 tow rig/ DD
    87 Sami buggy
    99 XJ RIP
    91 XJ RIP
    86 CJ5 RIP
    Mar 2003
    Hamilton, ON, CA
    Time Online: 1 Wk 4 Days 9 Hrs 35 Mins 2 Secs
    Looks great Adam!
    The 35's give it a nice stance!
    Apr 2004
    Grimsby, Ont.
    Quote Originally Posted by BLSXJ View Post
    The cost is in that area, and if you look at the post above yours, you will see that it is all new parts (including the housing).
    Thanx pinners, I hope it works well this year, I am getting the itch to get out there.
    All that is left now is the front drive shaft needs to be shortened (should be done tuesday night.
    Than it's test time.
    Aug 2007
    Near Waterloo
    that cherokee is looking SWEET
    that's all i can say
    keep up the good work man
    Apr 2004
    Grimsby, Ont.
    Just finished up the install on my 1000w inverter.
    Here is the unit itself.
    Wires run to under ther passanger side of the rear seat.
    Opening up the inverter to move the plugs to the rear.
    Inverter mounted and wires run to the rear.
    Power switch and outlet boxes mounted.
    And open and ready to use.
    This unit works great with a grinder, drill and even electric impact gun.
    Niagra on the lake
    Time Online: 3 Days 5 Hrs 22 Mins 46 Secs
    Avg. Time Online: 15 Secs
    What 1000w inverter cost you? Thats a nice clean look for plugs
    1991 Mazda b2600i 4x4 35s(RYANS RIG) RIP
    oya 2008 dodge caravan looking for 31s lol
    IN NEED OF JEEP LOL
    My wallet is empty but the kids and wife are happy LMAO
    Apr 2004
    Grimsby, Ont.
    I don't remember what the inverter cost (think it was around 100.00 us)
    And thanx for the compliment.
