Page 3 of 3 FirstFirst 123
Results 41 to 56 of 56
Thread: Swindled obsession tear down and re-build
  1. #41
    Sep 2010
    st.thomas
    Time Online: 1 Wk 1 Day 4 Hrs 58 Mins 47 Secs
    Avg. Time Online: 40 Secs
    Hopefully this will be completed in 9 weeks..... so stay tuned... i will try to keep up with pictures and updates... the good stuff is yet to come....
    Sent from my SGH-I337M using Tapatalk
    98 tj 4" lift 33"mudrovers
    95 firebird lift unknown???? but will be really high!!!---mud toy
    JUSCUZ
  2. #42
    Time Online: 4 Mths 3 Days 7 Hrs 6 Mins 39 Secs
  3. #43
    Sep 2010
    st.thomas
    Well the round flush mount led taillights are drilled!!!!
  4. #44
    Avg. Time Online: 33 Mins 22 Secs
    I see you!
    Sent from my SM-T810 using Tapatalk
  5. #45
    Sep 2010
    st.thomas
    Got more done on my beast lately.... motor sat in place and starting to put on all the goodies!!!! Fenders grill and hood went on temporarily to cover motor better.... Click image for larger version.
ID:	103309Click image for larger version.
ID:	103310Click image for larger version.
    And i have ordered a bunch of parts i needed... tcase shifter bracket front track bar and new mount and longarm upgrade kit....
  6. #46
    Sep 2010
    st.thomas
    Well after the weekends weather and a short workday today i got home and installed the transmission swapped out the tj power steering pump for a v8 grand cherokee pump, so the pully's will all have the same grooves. Also put on the steel heater hose line that comes off the water pump, had to use the v8 grand cherokee one for that too as the dodge one was in the way to install the power steering pump.Click image for larger version.
    Also had to source out a crankshaft sensor for manual transmission.the jeep one is different as is the auto transmission from the dodge ram donor . With some research i found a few different models of dodge trucks that ran them... next time I'd jus buy new... i didn't this time jus to save a few bucks....
    Gas tank and lines got installed as well , all the vacuum lines put on and hooked up. Click image for larger version.
ID:	103343Click image for larger version.
    And some fab work is needed hereClick image for larger version.
ID:	103345as you can see the shifter is sitting 2.5" forward from where it should be, the transmission mount also needs to moved forward 2.5"....
  7. #47
    May 2011
    eganville
    Avg. Time Online: 1 Min 8 Secs
    has this engine had the plenum gasket fixed? i see the kegger is nice and shiny so im guessing yes?
    91 Renagade
  8. #48
    Quote Originally Posted by H3lzsn1p3r View Post
    I'll field this question since he is probably outside working on it. Lol
    Yes he did change it.
  9. #49
    Sep 2010
    st.thomas
    Yes I did... jus got oil pan and rear main left to do.
  10. #50
    Sep 2010
    st.thomas
    Well now i have had some good wrench time in and got alot done.... shocks are in, breaklines and flex lines are in,
    Had to modify the bracket that mounts the power steering pump to the block... after sourcing a belt an getting it on after swaping a pully i found the power steering pump was sitting one grove of the belt forward from all the rest....
    Also got the rad in and all the hoses hooked up after making some hoses work....
    Also fired it up Saturday morning about 930am..... been messing around with crankshaft sensors, i ended up having to buy a new one.... motor sounds great!! But will be better when i get an exhaust on it... next up is to modify shifter, tranny mount and have both driveshafts shortened.....
  11. #51
    Sep 2010
    st.thomas
    So far as it sits.....Click image for larger version.
    Got a few small things done but nothing big... now trying to modify my tranny mount. .....Click image for larger version.
  12. #52
    Sep 2010
    st.thomas
    Tranny mount is done and painted and installed back on the jeep...
    Also got front bumper and winch back on as well as the new cb whip....
  13. #53
    Time Online: 9 Mths 3 Wks 2 Days 15 Hrs 4 Mins 23 Secs
    Avg. Time Online: 24 Mins 5 Secs
    **** yea bud.... Can't wait to see her on the trails
  14. #54
    Sep 2010
    st.thomas
    Ok fellas we are reaching the end point of the rebuild....
    I got the driveshafts in and set the front caster to 4.5 and at that the Pinon angle in damn close. Can't remember the actual numbers at the moment... the rear looks ok but im sure it needs to go down a degree or 2....
    Also got the shifter modified and installed!!
    I also finally got rid of the factory tie rod bar and swapped in a solid steel one from a grand cherokee....
  15. #55
    Sep 2010
    st.thomas
    Next up is getting the new track bar and bracket installed.... after that its jus a few small things to clear up set the toe in and double check all bolts tight oh and rear main and oil pan seal as they started to seep oil....
  16. #56
    Sep 2010
    st.thomas
    Ok so we are just a few days away from jk101 and my rebuild is almost complete...
    Track bar and mount installed!!! Rear pinion angle set
    Front caster set and the pinion angle is damn close
    Rearmain seal replaced
    Oilpan seal replaced
    Alignment set
    Electric fan installed
    Temporarily fixed rear end locker will be swapped in at a later date...
    All that's left is mount cb and
    lengthen the 4x4 shifter rod
    Wire up offroad lights
    Reinstall rocklights
    Now there is still some upgrades to be done, but they will be done as time/money allows as for paint well the wife has chosen candy apple red but again that has to wait...
    The v8 swap was a success and i believe that it should have been a factory option. I love the power, sound and the feeling it brings....
