Thread: 1999 jeep tj sahara part out - complete 4.0
    Oct 2013
    Durham Region
    Time Online: 5 Days 12 Hrs 1 Min 54 Secs
    Avg. Time Online: 27 Secs
    Work in Scarborough live in Newcastle
    Quickest response text 416.791.9495
    Parting out an '99 4.0
    31 X 10.5 Wrangler DuraTracs with 90% tread $750.00...These reatil for $229.00 each at CrappyTire.....
    SOFT TOP PARTS
    * Door surrounds w/hardware $120
    * Factory soft top with frame $200. No rips or tares. Comes with Tinted windows and all zippers function
    HARD TOP PARTS
    * Hard top complete $350.00
    BODY PARTS
    * New KJC fog light brackets $60
    * Windshield with BLACK frame...Small stone chips NO CRACKS $300
    * Front grill complete $120
    * Hood $80 (BLACK)
    * Pair front stock SAHARA fender flares $30.
    * Pair rear SAHARA fender flares $30
    * Small SAHARA fender flares pair $20.
    * Black doors good condition with pins $325.
    * Green doors good condition with pins $325
    * Sprayed black doors, good condition with pind $280
    * Tailgate $100
    * Rear mirror $10
    * Side mirrors $40 pair
    * Stinger style rear bumper. Thin metal more for aesthetics than function $60
    * Factory fog lights (good shape) $45
    * Steering linkage from column to steering box $40
    * Steering gear box BOUGHT NEW $90 no leaks
    * Sound Bar W/Speakers $50.00
    * Center dash main trim with vents $35
    * Centre console with Subwoofer $65
    * Instrument cluster $50.
    * Ash tray $15
    * Carpet $50 needs cleaning but COMPLETE
    * Factory rims with decent rubber $200
    * Dana 30 /35 complete brake too brake 3:07 gears $250
    * AX15 tranny $250
    * NP231 23 spline t case $150
    * Front drive shaft 4.0ltr manual $80
    * Rear drive shaft $30
    INTERIOR PARTS
    * Dark grey sun visors with clips $50
    * Sun visor retaining clips pair $15
    * Steering wheel column $80 W/Ignition
    * Pair front SAHARA seats inc frames etc $150.
    * Rear bench seats $80
    * Front seat belts $80 pair
    * Rear seat belts $80 pair
    * Seat belt height adjusters $15 pair
    * Headlight switch '99 $15
    * Wiper Switch '99 $20
    * Wiper motors complete with full linkage $75.
    * '99 4.0 ECM with GREY key $80
    * Front marker light bulb holders $15 pair.
    * Front marker light and side marker light harness (one side only ) $35
    * Side marker lights $15 ea.
    * Rear lights pair $20
    * Rear license plate holder $15
    * Rear bumper with ends $40
    AIR BAG PARTS
    * Air bag on off switch panel with wire $30
    * Air bag module / ecm $30
    * Drivers side air bag $75
    * Passenger side air bag $60
    * Clock spring $65
    ENGINE PARTS
    * '99 4.0 Motor $250.00
    * Motor Mounts from block $45.00
    * Motor Mounts $25.00
    * Clutch Slave cylinder complete $50
    * Master Cylinder with Brake Booster $90.00 for both
    * Skid plate $30
    * Fuel tank with pump $80
    * 2 piece exhaust manifold 4.0ltr '99 Bought new $80
    * 4.0 exhaust from cat forward $90
    * Alternator 2.5 or 4.0 $30
    * Steering pump 4.0 $30
    * Factory airbox assembl, from throttle body $30.00
    * Intake w/ injectors $30.00
    * 4.0 Throttle body $20.00 w/tps,iac
    * A/C Compressor $80.00
    * A/C Condenser $45.00
    * Complete Inline 6 or 4 Engine wiring harness unhacked $100.00
    * Sway bar no links $20
    * Rear sway bar with links $35
    * Track bar front $25 rear track bar $25.
    * Sway bar jeep logo cover $20
    * Radiator $35
    * Rad shroud 4.0ltr shroud $25.
    * Rad support bars pr $15.
    * Rad top up bottle $15
    * Washer top up bottle with pumps $20
    MISCELANEOUS
    set 2 drive shaft retaining clips and bolts $10
    * Slider type heater controls no ac $35.
    * Turn style heater controls $45
    * Heater box set up from behind dash $50
    * Blower motor $30
    * Heater resistor 97-01 $15
    * E brake handle $15
    * 4 wdrv shifter $25
    * Manual shifter $30
    * hood hinges pr $20
    * Transfer case linkage $40
    * Roll cage covers stock denim style dark greay $35
    * Roll cage extn bars front with covers $30
    * Battery tray $10
    * Battery tie downs $15
    * Fender brackets (attach to fire wall then too fenders ) $35 pr.
    * Front cowl panels $30 (white or black) directly between windshield and hood
    * Pair of tatty fenders with fender flares and hood latches still attached good for flat fender flare project $40 pr
    I do NOT offer REFUNDS or a WARRANTY on any parts being sold. Once parts have been exchanged, they are YOUR responsibility.....
    Mar 2016
    Brampton
    Time Online: 21 Hrs 16 Mins 44 Secs
    do you have the engine wiring harness and computer? can you post a picture of the computer vin number and code?
    99 Jeep Tj 4 Inch Lift With The Legendary Front Stinger/Rad Hoop
    96 GMC 6.5 Detroit Turbo Diesel- First Truck
    02 Cavalier- DD
    Let's Build Some Sh*t!
    May 2005
    Blind River
    Time Online: 1 Mth 3 Wks 2 Days 8 Hrs 45 Mins 55 Secs
    Avg. Time Online: 4 Mins 24 Secs
    hey, i'm interested in the green doors and heater box.
    what is the mileage on the 99 motor? i may want that too. if it's out of the jeep, has it been stored inside?
    proud OF4WD member #3875
    Jan 2012
    Time Online: 2 Mths 1 Day 6 Hrs 31 Mins 28 Secs
    Avg. Time Online: 5 Mins 3 Secs
    Are you selling the frame? If so, how's the condition of the frame?
    Jan 2013
    Midland ON
    Time Online: 4 Mths 2 Days 20 Hrs 3 Mins 15 Secs
    Do you have the climate control unit from the dash. Im looking for a buddy.
    Beamsville
    How are the windshield hinges?
    Professional lunatic
    Apr 2013
    Smiths Falls
    Time Online: 18 Hrs 18 Mins 35 Secs
    I am interested in the windshield frame, if you still have it I will take it
    text me, 613-206-1428
    Feb 2006
    east of toronto and north of 401
    Time Online: 18 Hrs 54 Mins 37 Secs
    I am interested in your motor
    Lawrence (boatguy)
    gotta have a jeep
    Time Online: 10 Mths 3 Wks 5 Days 36 Mins 55 Secs
    Quote Originally Posted by strat View Post
    This post was from over a year and a half ago and the OP has not once replied to this thread or logged in since January so you might want to try PM'ing him.
    May 2005
    Blind River
    yeah, gave up on this posting a long time ago.
