Results 1 to 20 of 32
Thread: Drowned Yukon
    Time Online: 9 Mths 5 Days 19 Hrs 53 Mins 49 Secs
    Avg. Time Online: 22 Mins 42 Secs
    Drowned Yukon
    So I know a guy that sunk his truck in a pond. Lol. He said he's having issues getting it fired. It's close to starting, sputters for a sec every crank and actually ran for a few seconds. Ran for about 10 seconds with brake clean in the throttle body. Oil was changed, plugs pulled and cranked over and drained water out of fuel tank. Mind you did try running it with watery fuel at first. Don't really think it's sensor issue cause it did run with the brake clean bypassing the fuel system. I'm suspecting injectors, plugged filter just enough to not supply proper pressure or weak fuel pump. I'm gonna swap out some injectors tomorrow and hook up a fuel pressure tester but thought I'd toss it out there more ideas or laughs. It's an 01 with the 5.3.
    Time Online: 10 Mths 3 Wks 5 Days 2 Hrs 48 Mins 56 Secs
    Avg. Time Online: 26 Mins 51 Secs
    So, uh, this guy...do you know if he checked for fuel pressure at the rail?
    Time Online: 3 Mths 2 Days 11 Hrs 18 Mins 47 Secs
    did said guy add new fuel to tank or just skim the water from old fuel......
    He checked. She's a squirter. Drained the tank jumping the pump relay. Hooked a hose to the incoming line at the rail out into a bucket.
    Time Online: 4 Mths 1 Wk 11 Hrs 29 Mins 36 Secs
    Avg. Time Online: 10 Mins 29 Secs
    If fuel is at the rail (sans pond water), this guy should check for an injector pulse. You...ahem...he can use a test light.
    selkirk ont
    Time Online: 1 Yr 3 Mths 2 Wks 4 Days 20 Hrs 58 Mins 37 Secs
    Avg. Time Online: 39 Mins
    subscribed, lol!
    WHAT WOULD MACGYVER DO?
    Was gonna swap injectors but maybe I'll check pulse to start. First I should get some pics up of said asshattery. Lol
    Started out with some skating and a nice fire in the middle of the pond. And of course a bunch of road flares. Lol
    Then some guy went for a rip
    Yukon down
    Next day damage report.* We've got a sinker!
    Some ice fishing for a trailer hitch
    Getting closer
    And she's out. Choked out my buddies 20k hydraulic winch. Had to arm strong it with the boom then tighten up slack and repeat
    Brush guard fail.....or win? Lol
    And she's still drying
    And that's all I have to say about that.
    Can't forget the fishing truck
    And the hitch had an iceberg in the way so figured a crafty J hook for the axle was the ticket. End of the day a strap through the windows and said iceberg underneath and she pretty much floated to shore with some crafty iceberg tetris. Lol
    Straffordville
    Time Online: 1 Mth 1 Wk 3 Days 6 Hrs 1 Min 27 Secs
    Avg. Time Online: 3 Mins 18 Secs
    Try starting it with the mass air flow sensor disconnected, see if that helps ya
    Tried that, no dice. Even swapped the intake with one here to see if new sensor made a difference.
    Straffordville
    Possibly a faulty submarine module ?
    ESM seems good
    Apr 2010
    Ontario
    Time Online: 1 Wk 21 Hrs 39 Mins 15 Secs
    Avg. Time Online: 39 Secs
    Silent running. It's a submarine thing. Jokes aside, the basic check list. Do you have good spark? If you do.....does it look like #1 gets that spark at TDC (no timing marks these days...so it's hard)? If it does...spray the throttle body with some gas....and hopefully it will at least kick or turn over faster. It's gotta be one or the other. Wish I was there to take a crack at it.
    Avg. Time Online: 1 Hr 4 Mins 37 Secs
    sub'ed
    Whitby, Ont
    Time Online: 8 Mths 3 Days 23 Hrs 39 Secs
    Avg. Time Online: 20 Mins 5 Secs
    I told you when you took the periscope out too plug the fawkin hole before going into the water!
    ᄅ# pɐǝɹʇǝɹ
    So we have fire, injector pulse and fuel. Swapped the entire fuel rail and injectors and same shit. Fires for a second then nothing. Starting to wonder about security kicking something out. Have a computer but not sure if it's tied to vehicle and don't want to fry something.
    Oct 2003
    London, Ontario
    Time Online: 1 Mth 2 Wks 3 Days 15 Hrs 44 Mins 21 Secs
    Security let's it run normal for 2-3 seconds. Was the ignition key area under water? Maybe need to take the immobilizer unit out and dry it
    Time Online: 1 Yr 5 Mths 2 Wks 20 Hrs 33 Mins 39 Secs
    Drowned Yukon
    Treat it like a phone, put the whole Yukon in a bag of rice for a couple of days. That'll fix it right up.
