Results 1 to 14 of 14
Thread: 1997 JEEP TJ - no engine kight no fuel gauge no amp gauge
    woodstock
    Time Online: 1 Wk 1 Day 10 Hrs 17 Mins 49 Secs
    Avg. Time Online: 41 Secs
    1997 JEEP TJ 4 litre. No Start. NO engine (bus) light, no amp,no fuel gauge. Fuses all good. Battery good. Cranks over. ASR good but switched just in case. Internet mentioned it was CPS sensor. I got 2 (dont ask) did not fix issue. Multimeter are strange. On ALL 3 wire sensors- I get a ground and 5 volts on both wires instead of just the one. Also the red/white main wire feeding computer is 12v when ignition off but drops to 4.1 volts when ignition on. Every electrical item still works on jeep. I also change computer as got overly frustrated with old one and got a used one from wrecker. It produces the exact same readings. I did notice that someone already had the wrecker computer so possible faulty. (unknown) Any suggestions.
    woodstock
    Also cant plug in code reader as there is no communication to computer
    woodstock
    Anyone? Its now at garage emptying every pocket testing wiring and so far no luck except for bill rising and still no start.
    Time Online: 10 Mths 3 Wks 5 Days 6 Hrs 28 Mins 58 Secs
    You said you have no gauge power - does this mean you have no ignition power to anything with the key on? I know you said electrical accessories work but I'm just trying to get this clarified.
    Have you checked for spark and injector pulse?
    woodstock
    Ignition on -cranks but no check engine light or amp gauge. no communication to computer.. All other electrical issues function. all sensors have a low 4.5 volts but jump to 5.1 when I indroduce 12 volts to orange wire. Changed relays. Changed CPS sensor-many times. Shop is having no luck.
    Whoever is working on it really needs to stop at the "No communication to computer" part. What do you mean by that? Was a code reader or scanner plugged in and a code came up for "No BUS" or " No Comms" or something else like that? Or was the scanner unable to connect with the computer?
