Thread: Tire Question
    Pefferlaw
    Time Online: 2 Days 15 Hrs 43 Mins 39 Secs
    Avg. Time Online: 13 Secs
    Tire Question
    I have a Dodge van with 225/65 /16 winter tires. Can I replace them with 225/70/16 tires. (thats all dealer has in stock)
    Avg. Time Online: 43 Mins 40 Secs
    Probably... But it is almost an inch taller. Mount one and see if it rubs in any position. You are going 27.5" tall to 28.4" not much but you never know.
    Windsor, ON
    Time Online: 1 Mth 2 Wks 2 Days 13 Hrs 43 Mins 51 Secs
    Avg. Time Online: 3 Mins 50 Secs
    Quote Originally Posted by Drizit View Post
    An inch taller, not quite, but close. 225/65 and 225/70 are only 11.25mm different in radius (5% of 225), 22.5 mm in diameter (7/8'). The biggest concern would be snow packing in the wheel wells though, you want to go slightly smaller with winter tires, not bigger, so the tires aren't rubbing on the packed snow.
    May 2011
    eganville
    Avg. Time Online: 1 Min 9 Secs
    better to go 215/70r16 they should have them in stock the 225/70 will cause slight interference
    91 Renagade
