Results 1 to 8 of 8
Thread: WORN SPLiNES DANA 44 AXLE SHAFT
    selkirk ont
    Time Online: 1 Yr 3 Mths 2 Wks 6 Days 4 Hrs 19 Mins 17 Secs
    Avg. Time Online: 38 Mins 58 Secs
    pulled my rear axles on my '04 tj rubicon to replace leaky seal and found that the passenger side shaft has a worn spline but the driver's side shows no wear. any idea what caused this?
    WHAT WOULD MACGYVER DO?
    2004 rubicon: 12,000 lb titan winch, 35" goodyear wranglers, staang's belly-up skid, cobra 29 cb, highline fenders, trailhead bumpers
    http://www.youtube.com/user/onehosereh#p/u
    VA3 HWG, OF4WD #5571, RETREAD #1
    Time Online: 10 Mths 3 Wks 5 Days 14 Hrs 8 Mins 41 Secs
    Avg. Time Online: 26 Mins 47 Secs
    This is technically possible on very high mileage shafts. However, if one side is fine and the other is not, it is because there is misalignment between the axle shaft and the carrier (typically a bent housing) or the shaft itself is slightly bent.
    You may want to remove the carrier and inspect the side gear as well. Side gear splines may also have excessive wear.
    One more possibility is the shaft did get properly treated for the correct hardness / depth.
    Aug 2004
    Woodstock
    Time Online: 6 Days 15 Hrs 10 Mins 2 Secs
    Avg. Time Online: 32 Secs
    Your lucky when I have to pull axle shafts this is what I get
    Half the fire wall/part of the hood & front grill its all CJ
    Etobicoke
    Time Online: 4 Wks 1 Day 6 Hrs 54 Mins 29 Secs
    Avg. Time Online: 2 Mins 24 Secs
    Quote Originally Posted by Stickybongsmoking View Post
    Bent axle housing causing spline wear?
    Who woulda thought of that!
    Even in the facebook era, jeepkings cognoscenti continue to teach us and are a valuable resource.
    2010 Rubicon 2dr wimp wagon
    selkirk ont
    thanks for the responses guys
    i don't think that a bent housing or axle would have caused such even wear all the way along the mating surfaces, i would expect to see signs of wear in the root of the spline (if that makes any sense) but there is none.
    so it looks like i'll be pulling out the carrier to see what kind of shape the spline is in and then decide what needs to be done from there.
    unfortunately it's and air locker so parts will more than likely be pricey with my luck, lol!
    Quote Originally Posted by onehoser View Post
    Root = minor diameter. If the mating splines never touch the minor diameter of the axle shaft, wear would be unlikely there.
    That is the next thing to check. If the side gear splines look good, I'm going with an inadequate depth of surface hardening treatment or improper after treatment of the alloy on the shaft. It is not common but it does happen. I have seen it before on some aftermarket shafts.
    selkirk ont
    turns out the internal spline on the carrier is badly worn so i decided to replace the locker with an eaton selectable e-locker rather than the more expensive factory locker
