Looking for a proper machined and bolt on solution for high steer on your 05+ Ford Dana 60? We've got you covered! You can send us your knuckle for machining or you can have it done locally, all the machine work is straight forward and can be done by anyone competent with a Bridgeport or similar vertical milling machine.
Compare TMR Customs arms to the competition and you will see there is no comparison! TMR Customs NEW Dana 60 Double Shear High Steer Arms are stronger and will survive years of abuse!
Pair up your arms with our optional "Knuckle Tie In Kit" to mount your Steering Joints in double sheer for the ultimate in strength.
Our new 2005-2008 Double Shear High Steer Arms are machined with a keyway - they are without question the strongest arm on the planet and the last arm you'll ever need.
2005-2008 Ford Dana 60 Double Shear High Steer Arms
