Results 1 to 20 of 24
Thread: Steering box seal on '97 TJ???
    Sep 2004
    The Rock
    Time Online: 21 Hrs 17 Mins 21 Secs
    I was driving around town yesterday and I heard a "growning" noise when I pulled into a parking spot. I knew it was my steering but never looked at it until i got back to my jeep about 1/2 hour later. I noticed there was fluid on the ground so I looked up and the steering box was covered in fluid. I think it is coming from the top where the steering shaft goes into it. I imagine there is a seal there but have never changed one before. Is it hard to change? Pull the box down and tap out the seal? thanks
    Oct 2004
    Ottawa area
    Time Online: 16 Mins 29 Secs
    Swap it with a better quality YJ steering box that can be had at almost any wrecker for $50-80.
    Sep 2004
    The Rock
    Why are they better?
    Oct 2004
    Ottawa area
    They're made better....they don't leak like the crappy TJ boxes.
    Oct 2004
    Ottawa area
    Do some research on the net. You will see this is a common swap to replace the leaky TJ boxes.
    Aug 2004
    Waterloo, ON, Canada
    Time Online: 2 Mins 52 Secs
    I just let mine leak. I have a sock wraped around the box to keep it from dripping
    2000 Honda S2000 (Silverstone)
    Sep 2003
    NY
    This just happened to me over the summer in my YJ. Very easy to fix, all i had to do was drox the box, pull the cover off were the input shaft goes into the box, replace two seals($12 USD), and put it all back in. The only thing i had a problem with was trying to find a 33mm socket for the drop pitman armnut. Good luck
    Oct 2004
    Ottawa area
    No worth fixing on a TJ....it just won't last.
    Easier to replace it with a YJ box.
    May 2003
    Cambridge
    Time Online: 3 Hrs 19 Mins 29 Secs
    I changed the exact same seal on my 98. Not a huge job. Its the one where the shaft goes in at the top. Get the parts from the dealer(you get a whole kit) and slap them in. Its best to remove the box from the jeep. I did mine two years ago and no leaky since.
    Sep 2004
    The Rock
    how much were they Drew?
    Sep 2004
    The Rock
    From where it looks like it is leaking it is called "adjuster plug seal". Does this seem right? according to the manual i have, you have to take out a lot of sh#t to get at it. I would like to get it fixed this weekend but i want to know if i have to rip this thing apart or what. nother question...where the steering shaft hooks on to the box, i assume its' splined, does something hold it on or when i take the box down does it slide right off? thanks guys
    Sep 2004
    The Rock
    btt
    Oct 2002
    Winnipeg, Manitoba, Canada
    1.) get rid of the crappy one in your jeep
    2.) go to a wrecker
    3.) get one out of a 99 dodge durango i paid 50 bux cdn)
    4.) bolt it in
    you now have a much stronger and better built steering box.
    DYSLEXICS OF THE WORLD UNTIE!
    Sep 2004
    The Rock
    i will try this again...I now know that the durango and YJ boxes are better but I don't have the money for them unless they are free, I already bought the seal, $7, so if someone can tell me what I am asking, I would appreciate it. thanks
    Sep 2004
    The Rock
    btt
    Sep 2004
    The Rock
    btt
    Oct 2004
    Ottawa area
    Buy a Factory Service Manual. All the answers to your questions are there.
    Sep 2004
    The Rock
    if i had money for a $100 manual, i would buy myself a yj box.
    Oct 2002
    whats your email, ill send you the FSM section for the steering box, its for a 98 but it is the exact same.
    MudThirsty Guest
    Hey my email is mudthirsty@uofj.ca. Can you send me the info as well. I have had a leaky box for over 2 years now. I just carry extra fluid with me whereever I go. I think its time to get this fix. However, I may do the YJ swap.
    btw, I have a 98 TJ
