Your cart is empty
+ Reply to Thread
Page 3 of 7
FirstFirst 1 2 3 4 5 6 7 LastLast
Results 31 to 45 of 91
Thread: The Drive Clean FAQ:
  1. Join Date
    Nov 2004
    Bram
    Gameroom Cash
    $500
    30 years and older car, my buddy gave away his dad's '72 Olds, went to get the ownership changed over with the transaction value of one dollar. The girl said they don't do that anymore, he had to go get an appraisal, and the tax would be on the appraisal amount. When are these laws changing, and not telling anyone, not even in the TO Sun ? I think we are turning into Russia and Russia is turning into how Canada used to be.
  2. Join Date
    Gameroom Cash
    $510
    Time Online: 2 Hrs 9 Mins 5 Secs
    A friend of mine just got his 93 318 4x4 Dakota tested today. He didn’t think it had a chance of passing, brought it to the mufflerman on Dundas here in London. His truck tried to jump off of the dyno because it was stuck in FWD. The mechanic told him not to worry about it and tested it as an AWD vehicle. A standing idle test was all it was required to pass. It passed without a problem (air filter removed).
    Food for thought next time you have to go in for a test, rig your t-case linkage so that its stuck in 4wd you may just get lucky and only have to pass the idle test.
    Toy List
    1964 VW dune buggy
    1947 Luscombe Silvaire Aircraft
    1986 Kawasaki X2 jetski
  3. Join Date
    Mar 2004
    Mississauga
    Gameroom Cash
    $510
    Time Online: 3 Hrs 12 Mins 49 Secs
    Question about the Hot Rod clause in the Act. I swapped a 1991 MPI block into my 1990 TBI YJ. Something was different between the two engines to the point that it now idles high. I bolted on the TBI manifold and swapped over the engine components like the flywheel, distributor and harmonic balancer. The 91 MPI engine has physical differences and is identified as such by Chrysler by having a separate identifier in the VIN. Therefore it comes under the "engine that was not available as an option in the model year of the vehicle clause. I documented this extensively with block codes then took it into the dealership to try to get it passed as a Hot Rod. Initially they said they'd test it as a Hot Rod but when I got there I got to speak to the Drive Clean manager. He explained that the vehicle can't be tested as a Hot Rod because the engine swap occurred after 1999. I would have to extensively prove that the swap occurred before 1999 to get the test. He wished me luck on that. By luck, they tested the vehicle while I was jabbering and it passed...man was I surprised. Going home I reread the Act and it seemed to be true what the tech said, that Hot Rod only applies to swaps done prior to 1999, not prior 1999 model year vehicles that have had engines swapped on them. It's subtle wording but makes a big difference.:
    "A hot rod that receives a motor replacement on or after January 1, 1999, shall receive a motor designed to meet emission standards at least as stringent as those achieved by the original motor with all its original emission control equipment attached and functioning, and the replacement motor shall have the original catalytic converter and all the original emission control equipment, or equivalent replacements, included or usually included with the replacement motor by the manufacturer of the motor. O. Reg. 361/98, s. 4 (2); O. Reg. 86/99, s. 3."
    Or is it? Does "designed to meet" imply "must be tested as" or does it mean "should be same standard as the original but tested as a 1980". Can anyone confirm that that is the way the regs are.
    Steve
    1999 TJ 4.0L, RE Superflex 4.5", 35" ProComp MTs, SYE, Warn Bumpers and rack, TJ Dana 44 w/ Detroit
    1990 YJ 2,5L, 4" spring lift, 32" Goodrich MTs, Rancho shocks, 2 inch shackle and body lift, Dana 35 Loc-rite Locker
    _________________________
    Where you want this killin' done
    Out on Highway 61
  4. Join Date
    Gameroom Cash
    $560
    Time Online: 1 Wk 22 Hrs 58 Mins 51 Secs
    Avg. Time Online: 46 Secs
    If they don't have a Kelly's Blue Book value for the car, then an apprasial is needed. Anything with a Blue Book value of under $1k is taxed on the selling price. Anything over $1k is taxed on the Book value or selling price, whichever is higher. But this is a DMV discussion, not Drive Clean.
    I ran into the same scenario a few years back. Oddly, it was a Dakota too. Owner told us the truck was stuck in 4x4 for the winter, so don't put it on the dyno. Since we had no way to disengage it, we had to idle-test it. Drive Clean investigated us, but was happy with the documented report.
    I'm honestly not surprised that your MPI passed the TBI standards. When swapping nearly identical blocks, it's not worth the hassle of trying to get the Hot Rod test unless you really need it. But, folks, damn near any engine can be made to pass with minimal expense. A Cat and an EGR will make 90% of the swaps we do pass no problem.
    '95 4Runner SR5. Air-Lift bags & OBA. 8K Winch, DD. SOLD!
    '97 4Runner Ltd, Stock w/E-locker, 5VZ-FE & 285's.
    ...Jeep search will commence in the spring.
  5. northjeep Guest
    what about this...
    I have an 88 YJ, 4.2, with a 4.0 intake and aftermarket injection. I'm pretty sure the evap canister is not functioning.
    I had a suburban and had to replace all kinds of e-crap to get it passing.
    Wil I have to install a bunch of factory crap on my jeep to get it passed?
    Spicifically:
    Will the evap can fail me?
    Will the e-tester fail me for aftermarket efi?
  6. Join Date
    Gameroom Cash
    $560
    Excellent questions. First, the evap can is a visual inspection only, so as long as your lines are hooked up, then the evap is fine. The 4.0 intake with aftermarket injection is not illegal or disallowed, so there is no penality there. In fact, if it's working right, you probably have a better chance at passing than a carb'ed 4.2 any day!
    In short, the only negative that may come from your vehicle is that if it fails, the shop may refuse to work on it. You are free to take it home and tune it, then rebook for a half-price retest.
    Make sure to get a paper print out!!. If you fail, you'll need to see the numbers.
    Good luck!
  7. northjeep Guest
    Quote Originally Posted by Noltz View Post
    Good luck!
    Thanks a bunch.
  8. Join Date
    Glencoe Ontario
    Gameroom Cash
    $500
    Time Online: 1 Hr 33 Mins 16 Secs
    I put a 350 Chevy in my 86 CJ when I got it in 2002. It was considered a hot rod but it still had to pass the emissions standards of 1980 it didnt pass so I couldnt get it on the road.
  9. Join Date
    Gameroom Cash
    $560
    Your 86 is now a "classic" and does not require emissions testing. You should not be required to provide an emissions test for your vehicle if you attempt to licence it now.
    That said, you should EASILY be able to get a chev 350 to pass Hot-Rod standards with a pair of Cats and an EGR. They routinely pass no problems at my shop. If you're gonna drive it, you should have cats & an EGR on it anyway.d
  10. Join Date
    Jun 2004
    in a van by the river
    Gameroom Cash
    $500
    I'm going to be renewing my tags up here for 2 years no etest needed. how far north do I need to move to avoid the annoying etest?? I'll be in the Alliston area
  11. Join Date
    Gameroom Cash
    $560
  12. Join Date
    Jun 2007
    Ontario
    Gameroom Cash
    $500
    need e-test
    I just bought a 88 wrangler, I had it e-tested and it failed it has a a holey 2-barrel carb that I had rebuilt, because when I had it e-tested I had a diagnostic done to let me know what it need to pass so I did the work. Had it e-tested 4-TIMES and it still didn"t pass I need to transfer the ownership into my name. Can i get a conditional pass even if it isn"t in my name ( it passed the safty no problem and it has a 4.2l ) any suggestions
    thanks
  13. Join Date
    May 2005
    hamilton
    Gameroom Cash
    $12000
    Time Online: 1 Wk 6 Days 16 Hrs 10 Mins 5 Secs
    Avg. Time Online: 1 Min 19 Secs
    nope,you cant get a conditional pass,it has to pass or you can not get plates.
    my wife (RIP) hated my jeep too so i ran her over with it and now we are both happier (me and the jeep)
  14. Join Date
    Gameroom Cash
    $560
    Original Post updated to reflect changes in Drive Clean rules .
  15. Join Date
    Acton
    Gameroom Cash
    $500
    Time Online: 1 Hr 24 Mins 31 Secs
    3 Bottles Of Gas Line Antifreeze And Go Down The 401 At 135 Km/h For 20 Min And The Take It To Get E-tested....it Will Pass Trust Me.
    P.s. Sorry For Caps My Keyboard Is Effed Up.
    Cheers
    You might be a jeeper when, You take your date home early on a Saturday night so you can work on your Jeep !
+ Reply to Thread
