Results 1 to 12 of 12
Thread: Electric supercharger
    jordansportsfan76 Guest
    My cousin bought a crappy electric supercharger the other day, and I must say it looks like a piece of crap. There is no way these things can work, right?
    I don't know, but I have found the idiots that sell these things www.electricchargers.com
    Dec 2006
    Kingston, ON
    Time Online: 4 Hrs 18 Mins 7 Secs
    Here's an informative write up on the subject: http://www.wildweasel.ca/j-body/HowTo/eturbo.asp
    Mar 2006
    dunnville
    Time Online: 5 Days 11 Hrs 21 Mins 10 Secs
    Avg. Time Online: 26 Secs
    so i wonde if you could inject compressed oxygen and put in bigger injectors...prolly be more expensive maybe it wouldnt work at all....just a thought
    if it aint broke... i dont own it!
    I got yer jeep thing.......now it hurts when i pee......
    Dec 2006
    Kingston, ON
    Quote Originally Posted by monsterj View Post
    I think you would have problems with pure O2 due to it's volatility(no smoking please). You'd have all sorts of issues with premature ignition. That's why most use N2O systems, you get more oxygen than you get in regular air, it's stable, it's cooling, but it's easy to use and much cheaper to produce than pure oxygen.
    Mar 2006
    dunnville
    plus it smells good...lol
    I've seen GAS powered leaf blowers add ~10hp to a 140hp civic on a dyno. Try that same leaf blower on something making +200hp and I doubt you'd see any gains. They're a total scam.
    As for injecting pure oxygen. Gottafly hit the nail on the head. Pure oxygen is way too volatile and would explode/detonate instead of having the controlled burn you want in a combustion chamber. N2O and Alcohols are your best bets for alternative injection fuel.
    Mar 2006
    dunnville
    would propane injection work on gas?.....i know about diesl
    Oct 2006
    Leamington
    Time Online: 1 Wk 4 Days 10 Hrs 37 Mins 38 Secs
    Ever pull the trigger on an oxy-acetalyne (spelling ???) torch all that does is add more O2 humm anybody want to cut there cylinder walls
    Dec 2006
    Kingston, ON
    What is the purpose of adding some sort of propane injection or converting to propane? It's a much shorter chained hydrocarbon(C3H8) than those found in gasoline, so there are fewer carbon bonds to break, so you get less energy out of it. If you don't use it in conjuction with some sort of turbo or supercharger, the propane would just displace oxygen, reducing power again, right? It's cheaper than gasoline, but wouldn't you need to use a lot more of it to get the same performance? Is it better for the environment?
    Sep 2004
    Welland
    Time Online: 2 Hrs 20 Mins 25 Secs
    to all the above ^^ HAHAHAHAHAHAHA
    TF
    NIAGARA TERRAIN CRAWLERS - FOUNDER
    Freakbuilt 4X4s - Rigs that actually perform offroad, not just big lifted junk.
    Time Online: 8 Hrs 57 Secs
    i want to see nitrous if we are going compressed gas induction
    97 TJ 4.0
    4" Tomken/BDS
    SB disco's
    33" BFG M/T
    Mar 2006
    dunnville
    i wouldnt use any of it im not a drag racer so to have power adders is pointless for 90% of the populus
