Results 1 to 20 of 29
Thread: Jeep YJ FAQ For Newbies Or Common Questions
    Frequently asked questions about the YJ
    Standard acronyms used on the forum:
    BL - Body Lift
    CV Joint - Constant Velocity Joint (used with SYE)
    I4 - Inline engine, 4 cylinder, 2.5L
    I6 - Inline engine, 6 cylinder, 4.2L or 4.0L
    MML - Motor Mount Lift
    RTI - Ramp Travel Index
    SYE - Slip Yoke Eliminator
    SOA (SPOA) - Spring Over Axle
    SRS - Shackle Reversal System
    SUA (SPUA) - Spring Under Axle (stock configuration)
    V6 - Engine from Ford, Dodge, AMC, Chevy - more power and normally used in a swap from the I4.
    V8 - Engine from Ford, Dodge, AMC, Chevy - more power and normally used in a swap from the I6.
    What size of tires fit without rubbing?
    Older YJ (sagged springs on stock rims with lots of miles) - 235/75r15
    Newer YJ (non-sagged springs on stock rims with few miles) - 30x9.5r15
    2.5" lift on aftermarket rims - 31x10.5r15
    4" lift on aftermarket rims - 33x12.5r15
    Backspacing on the standard rim is 5.5".
    Stock height of Jeep to rocker panels - 18"
    Wheelbase length of the YJ - 93.5"
    Wheelbase width of the YJ - 57"
    Ground clearance - 9"
    Towing capacity - 1,000lbs with proper hitch (officially) - 2500lbs with proper hitch (un-officially)
    What kind of transmissions are in the YJ?
    1987 - 1989
    AX-5 - Aisin 5-speed behind the I4
    BA-10/5 - Peugot 5-speed behind the I6
    TF904 - TorqueFlight Automatic behind the I4
    TF999 - TorqueFlight Automatic behind the I6
    1989 - 1995
    AX-15 - Aisin5-speed behind the I6
    How do I know what engine I have in my Jeep?
    If you lift the hood you will be able to count either 4 or 6 spark plugs.
    Early (pre 1991) 4-cyl engines were fuel injected via throttle body - 2.5L
    Second gen (post 1992) 4-cyl engines are fuel injected via MPI (Multi-Port Injection) - 2.5L
    Early (pre 1991) 6-cyl engines were carb'd - 4.2L
    Second gen (post 1991) 6-cyl engines are fuel injected via MPI (Multi-Port Injection) - 4.0L
    What gears do I have in my Jeep?
    I4 Automatic - 3.73:1
    I4 Standard - 4.10:1
    I6 Automatic - 3.54:1 (normally)
    I6 Standard - 3.07:1, 3.54:1 or 3.73:1 - must verify with the tag on the axle or by pulling the differential cover and reading the numbers stamped in the ring gear or by counting revolutions of wheel versus driveshaft.
    What fluids do I use in my Jeep?
    Axles - Gear oil - 80w90 weight for light duty and normally cooler climates - 90w120 weight for heavy duty and normally warmer climates Note: Some rear axles are equiped with factory posi - a limited slip additive must be put in with the gear oil to extend and protect the limited slip action
    Engine - 10w30 for good general usage in most climates - 5w30 for those colder climates (when temps are below freezing for extended periods of time)
    Transmission (standard) - 80 weight gear oil
    Transmission (automatic) - Automatic Transmission Fluid (ATF) Dexron III
    Transfer case - Automatic Transmission Fluid (ATF) Dexron III
    What is the easiest way to gain room for larger tires? - Suspension lift. When the springs are sagged out from years of use or abuse, a 2" suspension lift gains more clearance (and flex) than a 2" body lift. The other easy way to gain room for larger tires is to install Bushwacker or TJ flares and trim the sheet-metal of the body to allow for more room.
    Which is better, open diff, posi-diff, lock-diff or spool-diff in a set of stock axles? - The posi-diff situation is the easiest on the Jeep's axles with least chance of serious breakage. For more information regarding the different choices, try Randy's tech sheet. A locking diff is the strongest, and will carry you further down the road less travelled.
    I want to put a winch on my Jeep, which one should I get? - The rule of thumb is that a winch must be rated at least 2-times the weight of the vehicle. For a stock YJ running no doors or top, no back seat and minimal tools/spares a 6000lb electric winch will do the job very nicely. Once you start adding in extra weight-inducing extras (hard-top, full hard-doors, tools, people, etc), an 8000lb electric winch gets the nod. If you are into hard-core mud or rocks, 9000lb winches and higher will become the recommended rated unit.
    Can I swap my 4.2l engine for a 4.0l engine? - Yes you can. Its basically a bolt-together situation, but you will have to remember to remove all the wiring with the 4.2 and put in all the wiring for the 4.0 (all sensors, including O2 on the exhaust). While you are at it, install an electric fuel pump to provide the correct PSI and GPM for the 4.0. The guages on the dash should work properly once they are all hooked back up again.
    How hard is it to swap in a V8? - The Chevy and Ford V8's are very easy to put in with lots of room under the hood. AMC/Dodge V8's can be mounted infront of the I6 transmissions with minor modifications to the bellhousing. Using the existing transmission may not be best, and is not recommended to use the I4 transmissions behind V8 power. Standard tools with a welder, grinder and angle-finder are all you would normally need.
    If you are wishing to use all the stock power-train (transmission to the axles) with V8 power under the hood, check Advance Adapters to get their V8 swap book, their adapters and motor mounts to make the job real easy. Novak Adapters has a great knowledge base online about the V8 engine swap. It is an easy to understand article.
    My carb'd Jeep keeps stalling when I hit the brakes - why!? - Welcome to the world of the early YJ. It is a well known problem and a complete PITA! To start, check all the vacuum lines around the carburetor. Any that are cracked or missing - replace. Once that is complete, if there is no change in the way the Jeep runs, try a simple repair as listed at JeepTech.com. If that doesn't work, then its time to visit a professional, or go the route of thousands of other Jeep owners and get rid of the Carter carb and replace it with a Weber carb .. you can find these carbs from E-bay (used) or new at many autoparts stores.
    Which CB channel should I use when wheeling? - Channel 4 and Channel 16 are the two most used channels when 4x4'ing. If you are out alone, try both to see if there is someone nearby to join up with.
    I want a softtop for my Jeep
    - what should I get? - Bestop has been in business since 1954 and has very high quality product and service.
    What are the best mufflers to get? - Personal preference here - the cheapest ones won't hurt your wallet as bad when you bash them on the rocks, or rip them off on obsticles. A free-flow muffler and cat are good for a few more ponies. To check if a muffler and catalytic converter are free-flowing - look through it. If you can see your friend on the other side, its free flowing.
    I just put on ??? size tires - what should I re-gear to? - If you know what gears you currently run and the size of tires you just removed, you can use an online calculator to figure out what gears you should use to put your engine back into its proper power-band with the new larger tires.
    Normal available gear ratios for YJ axles are:
    # 3.07:1
    # 3.54:1
    # 3.73:1
    # 4.10:1
    @ 4.56:1
    @ 4.88:1
    # = Stock available gears
    @ = Aftermarket supplier like Randy's Ring and Pinion
    I want to run 35" or larger tires, what should I do to reduce breakage? - The front Dana 30 axle is fairly strong, and can handle up to 37" tires if you aren't too hard on the gas-peddle. The rear Dana 35 is not as strong, and its maximum recommended tire-size is 33". To strengthen the rear axle, Superior Gear has the Super 35 kit to increase the strength of the stock rear axle, combine that with a truss and you will have less chance of breakage. Replacing the rear axle with a Ford 8.8" (out of a 1995 or newer Explorer), or a Dana 44 (Metric-tonne Commanche (MJ), Towing-package Cherokee (XJ)) are a direct bolt-in once the spring perches are welded into place. .
    What is the best way to gain more flex from my Jeep? - Removing both the front and rear track-bars (bar from frame to axle, one mounting point on each side) will gain you alot of flex right from the start. Most are happy removing the rear track-bar and suffer no ill-effects. Removing (or temporairilly disabling) the sway bars on the front of the Jeep will be the icing on the cake for flex. Some find the ride horrible on the street with lots of body-lean in the corners. Others are happy without track-bars or swaybars. Try removing one at a time (starting with the rear track-bar) till you find the ride the easiest for your driving style without making you feel un-safe in corners.
    Why does everyone hate body lifts? - Its not that we hate body lifts on our Jeeps, its that most find their looks as being ugly, and the higher body lifts can become dangerous - especially in accident situations. Many instances the body lift has busted through the body and caused the body to sag at one or more places - even to the point of the body lift pucks breaking through at all mounting points and the body coming to rest on the frame again.
    Can I put a CJ-7 hardtop on my YJ? - Yes you can. There are a few things you must do in order to make it function properly with your tail-gate, but it will fit in place without any major issues. Look towards opening your rear-window before opening the tail-gate. You can also attempt to swap a YJ-style rear window onto the CJ's top.
    I want different rims. What will fit? - Within the Jeep line of vehicles, you can use rims from any YJ, XJ, MJ, ZJ or KJ. Outside of the world of Jeep, you can get Ford Explorer and Ranger rims, of course, the Mazada B4000 rims will fit (It is a Ford - or is it vice-versa). Pontiac 6000 cars also use the same bolt-pattern, but their rims are 14" in diameter - so its not a perfect match.
    You can also purchase brand-new aftermarket rims. All you need to specify is the bolt-pattern of 5-bolts on 4.5" diameter. The most popular after market rim for the YJ is the American Racing rim model 767.
    Why do I have water pouring inside my Jeep when it rains? - That is a fairly common occurance. The grill on the top of your engine area (just in front of the windshield) allows fresh air into the Jeep for the heater. It also allows water and snow to collect. There is a drain-hose on the firewall about 1.75" in diameter that can get plugged. Pull off the hose, and tip it upside down. Wash it out with the garden hose in the backyard and then wash the grill-area down as well pouring as much water down as possible to wash all the trapped dirt out. Place the hose back in place and enjoy dry feet again.
    You can also add a scoop to the grill area to limit the amount of water/dirt entering the fresh-air intake.
    What is the best way to clean my soft-top? - You can use a baking-soda/water mix to clean the canvas tops and doors. Using a soft bristle brush, work the paste into the top. Once completed, rinse with clean water. If that doesn't remove all the stains, visit one of your local boat-supply stores and ask them for some canvas cleaner (many boats use a canvas cover). While a little more pricey than the baking-soda, it might just do a good job for you.
    What should I look out for when purchasing a used YJ? - Depending on what you are looking for, any of the YJ's are great projects, wheelers, daily drivers, etc.
    1987 - 1988 - Major Project Jeep
    V8 swap with swapped in transmission and transfer case
    SOA, trimmed body panels, exo-cage
    Look for rusting in the floor near the roll-cage mounts
    1989 - 1991 - Minor Project Jeep / wheeler
    Lift kits/bigger tires
    V8 swap for I4 (also change transmission and transfercase)
    1992 - 1995 - Daily driver / Minor Project Jeep / Wheeler
    As with any vehicle, make sure that you know what you are getting. Check fluids, check bushings, check for rusting, check for accident damage, check for 4-wheel-drive (not just the light on the dash, but that is a good indicator) by "twisting" the suspension till you have one front and one rear tire spinning in the air, check for the doors closing properly (again, accident damage), check over any mods that may have been done (you don't want farmer mods on it - clean bolt-on's are great, or properly welded ones) .. and always get a saftey inspection done.
    How much is this Jeep worth - or - how much is my Jeep worth? - Modifications to the Jeep do not increase or decrease the overall value of the Jeep. In general visiting Kelly Blue Book will give you a good starting point for buying or selling a Jeep.
    How do I know if my VIN is correct or where was my Jeep built? - If you visit the VIN decoder, it will tell you where, when and what major options were built into your Jeep
    Originally found here http://www.jeepforum.com/forum/showp...17&postcount=1
    ADDED TECH WRITE UP: Homemade "posi-lock" to replace front axle vacuum disconnect.
    Apr 2004
    Time Online: 1 Mth 3 Wks 2 Days 12 Hrs 45 Mins 53 Secs
    Avg. Time Online: 4 Mins 24 Secs
    great topic
    This is a sticky
    janetville
    Time Online: 4 Mins 31 Secs
    alot of good information , also a bit of info that is incorrect.
    xj with stuff
    Apr 2004
    if the info is incorrect post it up and then changes can be made
    janetville
    far as i know wj is not 5 on 4.5 its 5 on 5 and i thought 4.88s were the biggest gears you can get in a 30. nothing major
    ^fixed
    As far as engine swaps go, does the info apply to the XJ as well?
    Sarnia Ontario
    Time Online: 1 Day 4 Hrs 4 Mins 57 Secs
    [QUOTE=RBJeepThing;590321]Frequently asked questions about the YJ
    Adrian
    What is the preferred V8 GM engine/tranny/T-case that is swapped into a jeep? If I was to look for this engine what type a vehicle do I want this engine drivetrain combo from? Is fuel injection and computers a problem with the V8 engine swap
    LAJOC Member
    ---Just one more part to buy and I'm done--- I know I'm going broke owning this f#$%n Jeep
    Nov 2003
    Welland
    Time Online: 1 Wk 3 Days 10 Hrs 33 Mins 37 Secs
    Avg. Time Online: 51 Secs
    You might want to change the part about the gearing in the 6 cyl. w/Auto to 3.07, with 3.54 optional. I just went to check at the dealership and they tell me 3.07, and thats what I have been told a couple times here too
    1987 Jeep YJ - Daily driver/trail rig - On the road but Currently under construction
    Thanks everyone for helping me realise I really do dislike people in general
    I'm just a regular Joe, with a regular Job, I'm your average white Suburbanite slob
    I like Football, and Porno, and Books about War
    Brantford On
    Time Online: 1 Day 9 Hrs 49 Mins 59 Secs
    Great thread. Have had my YJ for sometime an djust looked at this. Very informative. Thanks
    Durham, Ontario
    help me im dumb lmao !
    I was wondering if a 4.0 or 4.2 l will bolt right up to the tranny on my 95 yj 2.5 l 5 spd? if not what tranny do I need to find or what engine will bolt up without messing around too much?
    Brampton
    Thanks for this......Excellent info for us Newbs
    Member
    Love my 87....
    Sudbury Ontario
    Time Online: 6 Days 10 Hrs 20 Mins 29 Secs
    Quote Originally Posted by BO BO the love donkey View Post
    no,your tranny is an ax5,a 6 cylinder 4 litre would use an ax15,and the 4.2 would use a ba10 [used until march9,1989 ]or the ax15 used after that date .
    Amazed
    Avg. Time Online: 4 Mins 50 Secs
    Yj Faq
    Hey all, I just thought I'd add a link to the YJ sticky... when I lived in Whistler and had 2 cherokees and a 95 YJ Rio Grande I always used BC4x4.com for info they have a pretty good bunch of guys on there and a huge YJ FAQ
    http://www.bc4x4.com/faqs/
    hope this helps someone out.
    Jun 2009
    kitchener,ontario
    Time Online: 13 Hrs 32 Mins 49 Secs
    what kind of tcase is in a 1990 yj and how much is it worth if i sold it?
    np231 they usualy go for around 150
    they come in a few diferent spline counts 21 and 23 the 21 is less wanted and is found in 4 cyl models
    Sep 2009
    Sarnia, Ont
    Time Online: 4 Days 16 Mins 37 Secs
    Avg. Time Online: 19 Secs
    great thread.. Learned alot about what I want to do and where I should go with this..
    thanks
    Quote Originally Posted by mud bros.1 View Post
    Also found in the automatic 6cyl and ones equipped with the Peugot trannies.
    Aug 2010
    Acton Ontario
    Time Online: 2 Wks 4 Days 3 Hrs 48 Mins 25 Secs
    Avg. Time Online: 1 Min 29 Secs
    if changing stock carb on 4.2 to a weber, is there a kit required, or just bolt on ?
