Your cart is empty
+ Reply to Thread
Page 1 of 3
1 2 3 LastLast
Results 1 to 15 of 42
Thread: Pa bender...
  1. Join Date
    Aug 2005
    Barrie ontario
    Gameroom Cash
    $500
    Pa bender...
    I'm looking to buy one of these benders... But I want to see just how bad of a job they do. Everyone seems to hate them... So I was wondering if someone had one I could use for a week or two? The closer to Barrie the better.
  2. Join Date
    Mississauga
    Gameroom Cash
    $560
    Time Online: 4 Days 17 Hrs 19 Mins 38 Secs
    Avg. Time Online: 27 Secs
    They're pipe benders and do an OK job on pipe - they kink tube. I have one I used once and determined it wasn't my "cup of tea".
    If you want to use it on pipe, I'll sell you one for $50 - location is Mississauga.
  3. Join Date
    Gameroom Cash
    $730
    Time Online: 1 Wk 2 Days 7 Hrs 8 Mins 49 Secs
    Avg. Time Online: 54 Secs
    50.00 bones?
    I'll take it!! PMMe!
    Built from Blood, Sweat and Beers:
    91 XJ, 109" WB, Comp Cut, Dove Nose, Belly Up Tuck, 4Link Air/Hydro, 4Link Bagged Rear, 44" Boggers, 32bolt Beadlocks, D60/14bolt, Full Hydro/Hydroboost 350SBC sniffing BBQ, TH400 NP203/D300, Trying to keep it looking full bodied.
  4. Join Date
    Mississauga
    Gameroom Cash
    $560
    PM sent to JKMotorsports.
  5. Join Date
    Malton
    Gameroom Cash
    $500
    Time Online: 1 Day 14 Hrs 7 Mins 9 Secs
    Avg. Time Online: 9 Secs
    Quote Originally Posted by Alfons View Post
    They are only as good as the operator. If you have the rollers too close together or try to put too much of a bend in one location they WILL kink. You have to move the bend to radius it properly and sometimes use heat.
    Even with large automated benders they will kink unless you have one with internal "gadgets" like an Eagle precision bender that keep it from collapsing or a large enough radius.
    93 YJ 4.0
    32" Bridgestone MT, RE SOA w/1.5"SOA springs, DANA HP30 OX-locker / Posi-Lock /8.8 disk
    9500lbs Superwinch
    Dodge 3500 Turbo Diesel dually 4x4 tow rig 5 speed 215hp/440fpt
  6. Join Date
    Mar 2003
    oshawa ont
    Gameroom Cash
    $500
    I heard that if you fill the tube with sand it helps
    2000 Jeep WJ
  7. Join Date
    Gameroom Cash
    $10142
    Time Online: 1 Mth 2 Wks 3 Days 3 Hrs 23 Mins 44 Secs
    Avg. Time Online: 4 Mins 34 Secs
    made this out of pipe with a PA 16 ton pipe bender, quite simple, surprized how strong it was, i'd do it again
  8. Join Date
    Gameroom Cash
    $0
    Crappy
    Time Online: 2 Days 9 Hrs 59 Mins 42 Secs
    Avg. Time Online: 14 Secs
    roll it yet^?
  9. Join Date
    Gameroom Cash
    $530
    Dead
    Time Online: 2 Days 2 Hrs 49 Mins 49 Secs
    Avg. Time Online: 12 Secs
    HREW tube in a pipe bender works awsome
    -don't heat it or the outside of the radius will collapse in
    -no need to move the tube part way through the bend
    -no need to fill the tube with anything
    -make your bend slowly and don't try to go any more than 90*
    I've built a few cages, a full tube chassis buggy, bumpers and many other things with a PA pipe bender using HREW tube and have never had any problems.
    Yes one of the cages was tested in a low speed roll and it held up fine, not even a dent. If I were driving a race car I would build a dom cage, but for offroad dom is not nessicary.
    The biggest downfall of the pipe bender is that you cannot get 2 bends close together because of the roller dies.
    Definately worth the money if you take your time, bend slowly and think things through before you start to build.
  10. Join Date
    Nov 2002
    Keswick
    Gameroom Cash
    $500
    Time Online: 13 Mins 40 Secs
    I used 1.9 hrew (crew will work too) with a 2" pipe die, worked really good, it does put a few slight wrinkles but no kinks, I have yet to have one person notice it until I point it out.
  11. Join Date
    Aug 2003
    Ottawa Eh!!!
    Gameroom Cash
    $500
    Time Online: 2 Hrs 46 Mins 19 Secs
    Another trick is to put a piece of flat between the rollers and the tube/pipe. A piece about 3" long x 3/4" wide x 1/8" thick. This will help stop the dimples where the rollers meet the tube/pipe.
    #1-85 Suzuki Hybrid, 4.3 TBI, 700R4, Dana 18, Dana 44's locked and spooled, Disc brakes, 38.5x14.5x15 TSL sx's, bead locks, warn 8000 , full cage, OBA with 5 gal Tank. Running Fox Shox and 4 link in rear.Full Hydro
    #2 -52 M38 Winter, toy gear, 8274, 35" Boggers, Sunday Driver.
    #3- 97 JEEP TJ Sport, 4" Trailmaster, 2" bodylift, custom bumpers, 8,000 Warn, 35" MTR's, JKS Disco's, Super 35 Ox ,Daily Driver and local run machine.
    #4- 73 International School Bus/ RV/Ramp Truck. Sleeps 5 ( 2 comfortably) 500 Caddy motor, TH400, AKA Shaggon Waggon. Still for Sale!!
    #5 2000 GMC Savana Extended w/raised roof and 5.7. MaxxiVan used to tow my shit ;-)
  12. Join Date
    Gameroom Cash
    $0
    Crappy
    i just dont see the point, why spend $100 on a crappy PIPE bender, when for $300 you can get a good TUBE bender, and then use DOM in your cages and actually be safe
  13. Join Date
    Aug 2003
    Ottawa Eh!!!
    Gameroom Cash
    $500
    Show me where you can buy a tube bender comptete with dies for 200.00?????
  14. Join Date
    Dec 2003
    Parry Sound , Ontario
    Gameroom Cash
    $555
    Time Online: 2 Days 11 Hrs 13 Mins 52 Secs
    Quote Originally Posted by JoeL View Post
    I'm so sick of this DOM debate.
    Are you doing 200MPH in a race car ??
    no.
    Nobody has given any proof on any of the dozens of threads here, on pirate.com or any other sites that using pipe in your Jeep rollcage isn't safe. No stories. No pictures. We have researched this extensively.
    We have , however, heard from one member who built a complete competition-style tube buggy using pipe and a pipe bender, as well as rock-rails, bumpers and other items. And this particular member works in a welding/fabricating business and knows his stuff.
    Pipe is cheap, pipe benders are cheap, and they both are just fine for most.
    DOM has it's place but is overkill for most offroaders.
    Placement,configuration, frame tie-ins, gusseting and proper welding is more important that the material used.
    The Nebuchadnezzar
    '95 YJ lifted and locked.
    MUDDER INC.
  15. Join Date
    Mar 2005
    Pickering
    Gameroom Cash
    $505
    Time Online: 6 Hrs 9 Mins 8 Secs
    Quote Originally Posted by Pallister View Post
    Go get one, you won't regret it. I've been using one for a few years now. Sure I'd love a tube bender, but I can't justify the cost for the limited use it'll see. I've put together a few trucks, for myself and for a few friends. Here are pics of my very first bending project. I bent it up on the sidewalk infront of the house. No measuring devices at all, just some string and masking tape.
    I'll see if I can find some pics of the others.
    -CZ
    Someone please give me a cookie
+ Reply to Thread
