Results 1 to 11 of 11
Thread: Looking For opinions.
    Glencoe Ontario
    Time Online: 8 Hrs 9 Mins 15 Secs
    I have an 86 CJ-7 350chevy, T-5 Trans, Dana 300 Transfercase, stock diffs. SOA and a 1" Body lift.
    Two questions:
    1) 33's or 35's? (the prices aren't much different)
    2) Lockers or welded? Front or rear
    Apr 2007
    kirkfield
    Time Online: 2 Days 12 Hrs 43 Mins 48 Secs
    Avg. Time Online: 12 Secs
    my '86 cj is getting a front d44 from blazer and a welded 14 bolt SOA with yj springs .. cause thats what i have laying around !! i bust the stock amc20 already with 33's on the street .. havent decided on the powertrain yet; maybe a turbo buick v6/700r4 or a stroked xj 4 liter/adub, probably the latter
    at the risk of flaming; i wouldnt weld the rear if it's gonna be a street driven rig, unless it's a purely fair weather toy, even though a welded rear end is way more predictable than a locker .. and i definitely wouldn't weld the front unless you like fixing more than driving
    does not play well with others
    Glencoe Ontario
    Are the stock diffs that weak?
    Time Online: 1 Mth 2 Wks 1 Day 1 Hr 19 Mins 2 Secs
    pure stock amc 20 suck. they will live with 33" if you do a one piece shaft upgrade and the 30 will be okay with tight hub bolts with locktight and new spicer life u-joints. Oh, leave em open if you want any life out of them behind a V8 with a manual.
    I destroyed two AMC 20 and gave up on any idea of stock drivetrain after the first dana 30 $#!+ the bed.
    83 CJ9 LS5.3/4L60E/231/B4R/D300, 8274,D60/14b,ARBs,15"airbags susp, 18"stretch 39"PITBULLS
    09 Nissan
    Ford F350 CrewCab Long box 4x4 TowPIG/dd 165"wheelbase
    May 2005
    Up the Hill from "Shrek's Swamp" and down the road from "Cultural Hub of the universe"
    Time Online: 1 Wk 6 Days 9 Hrs 14 Mins 15 Secs
    Avg. Time Online: 1 Min 6 Secs
    35's & a rear lunchbox locker...
    MY $.02
    86 CJ Juggy
    67 Chevy Step side
    79 C20
    Apr 2007
    Beamsville! Where else?
    Time Online: 1 Mth 2 Wks 6 Days 18 Hrs 37 Mins 53 Secs
    Avg. Time Online: 4 Mins 11 Secs
    35's, welded rear, selectable front.
    CHARLIE DON'T SURF!!
    DINGA DING DANG, MY DANGA LONG LING LONG
    OF4WD#5576
    BOOYAH!!!
    Feb 2007
    nfld
    Time Online: 2 Mins 36 Secs
    Quote Originally Posted by Chevy YJ View Post
    x2....
    1999 WJ 4.7v8, np231, hp44/ford9" and some other stuff
    soon to be: hp d60/14 bolt, 231/300 tcase . 39.5x13.5x16 IroKs
    Bradford
    Time Online: 4 Wks 1 Day 7 Hrs 16 Mins 36 Secs
    Avg. Time Online: 2 Mins 25 Secs
    you should replace that amc 20 as chrisbuilt said with my d44 scout rear (matching bolt pattern, perfect cj width) with welded rear diff and finish the rear disc conversion
    http://www.jeepkings.ca/forums/showthread.php?t=68972
    you should then gear it low, grab some alloys, and run 35's all day.
    alloys:
    http://www.drivetrainoutlet.com/Prod..._Axle_Kit.html
    Glencoe Ontario
    I plan on upgrading axles eventually, but not right away.
    Apr 2007
    are they 2 piece shafts? if so, get the 1 piecers and weld it up, it's not a bad diff, just the 2 piece axles are shit.
    Glencoe Ontario
    Thanks Guys. I use to have 33's with the i-6 and still got 5th on flat roads. The SBC had no problem with the 33's and it tore the shit out of the 31's I had on after.
