Thread: power fluctuations???
    Sep 2004
    millbrook, ontario
    Time Online: 4 Hrs 25 Mins 27 Secs
    hello,
    I am having some driving issues with my jeep. I have checked all the vaccuum lines i can see and there doesn't seem to be any leaks. Does this sound like a vaccuum issue?? any ideas??
    I am still having issues when i am driving though. I was on the hwy yesterday. i would be driving witht the peadl to the floor with no problems. As i slowly let off on the gas you can feel the jeep hit power spikes. if i hold the gas at about 75% you can feel the jeep slow down. if i let off on the gas a bit you will feel the jeep pick up speed(more power) then if i let off more the jeep would feel like it is sputtering. All dfifferent power fluctuations depending on where i hold the gas pedal. Yesterday i was doing 90km/hr and going downhill in 4th gear and was picking up speed at 100% throttle. when i let off to about 90% the jeep would imediatly slow down like i let off on the gas totally. then at about 80% throttle the jeeep would be speeding up again. what would cause all the different power stages in the gas pedal???
    thanks
    Sep 2004
    millbrook, ontario
    it is for an 89 YJ 4.2L. i have done the mc2100 carb swap. new cap rotor and coil.
    Sep 2004
    millbrook, ontario
    would a vaccuum tester figure this out??
    Jun 2007
    brantford
    Time Online: 20 Hrs 19 Mins 35 Secs
    i would definately give the vacuum tester a shot
    Time Online: 2 Wks 3 Days 6 Hrs 35 Mins 8 Secs
    Avg. Time Online: 1 Min 25 Secs
    stick a hose onto a funnel for a cheapo stethescope. Pretty useful for finding vacuum leaks. I had kind of a similar problem with the old 1bbl. and it had worked loose from the intake letting air suck in. Maybe double check your new carb and try some locktite.
